Question about Frigidaire ATF6700FS Front Load Washer
Washer not dispensing water
Washer comes on with no error on panel but nothing happens no water comes out
    Master:
  • Frigidaire Master
  • 753 Answers
There is a trap in the large hose between the tub and the pump it needs to be cleaned out, make sure you re-install it properly or you will have worse problems. If you need further instructs I will help you
Posted on Mar 30, 2014
Our Kenmore HE 2Plus Front Load washer model # 110.475*4753 is haveing an F03 Error and we can not get it cleared. Any ideas? We have hit stop twice, and cleaned the hoses, nothing clogging them..help
The problem with the fabric softener not dispensing is not likely related to and F03 error code due to the washer not draining.
For the dispenser problem, I recommend that you pull the dispenser drawer out and clean it thoroughly.
The fabric softener dispenser works on a siphoning principle.
Make sure that the siphon hole in the dispenser is clear and not restricted or plugged.
You can fill the fabric softener compartment with water and make sure that it is siphoning properly while you are cleaning it.
Make sure that the cover is properly replaced on the fabric softener dispenser when the drawer is replaced in the washer.
You can use the diagnostic test described below to test the fabric softener dispenser.
If the softener dispenser does not fill and dispense properly, you could have a failed dispenser valve, a failed control board or a wiring failure between components.
You indicated that you tested the pump and that it is good. You could have a clogged drain hose or a clogged washer drain that would prevent the washer from draining.
You could also have a failed drain pump even though it runs. If the impeller is jammed or damaged, it will not pump out the water in the washer.
You will likely need to unplug the washer and drain the water out of the tub using a wet/dry shop vacuum.
To check the pump and drain hose at the bottom of the washer, remove the bottom front service panel and remove the drain pump. You may find a clog or restriction in the drain pump or connecting hoses. If the drain pump is damaged or will not work, it will need to be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 13, 2010 | Kenmore Elite 45986 Front Load Washer
Whirlpool duet sport front load doesn't wash and shows code F2O and some times F13
f13 is a Dispenser circuit error
If the dispenser motor is not able to be driven to it's proper position.
Check mechanical linkage from dispenser motor to the top of the dispenser.
Check Wire Harness connections to the dispenser motor and Central Control Unit (CCU)
Check Dispenser Motor
"F20" is a No Water Detect error. It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed. This can be a potential problem with the following:
If you have NO water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Drain Pump operation.
- Verify the Pressure Switch hoses are intact and connected properly.
- Verify wire harness connections at the pressure switch, inlet valves, drain pump and Central Control Unit (CCU).
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Pressure Switch - remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a plastic air hose attached. Verify the electrical connections are intact, and the air hose is attached and not cracked or leaking.
To access the Central Control Unit (CCU) - with the top panel of the washer removed, the CCU is located directly behind, and just above the rear of the wash tub. There should be a tech sheet directly behind the lower panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics and to verify the wire connections at the CCU. In addition, the tech sheet will also assist in how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore front load washer is leaking water from soap
We had a similar problem with water coming out of the soap dispenser when the washer was run. I assumed that it was a problem with the water draining as everyone else posted here. I took off the front panel, got rid of the junk and drained it. Although this was great, it did not solve the original problem. It turns out that there was a sock stuck in between where the water comes out of the soap dispenser and in to the main compartment. Pulled it out with a needle nose plier and good to go. Thanks to everyone for their input here.
May 28, 2010 | Kenmore HE2 Plus Front Load Washer
Dispenser is stuck on the water function. The
Ok, If nothing happens with any other functions and during our conversation earlier sounded different. Now it points to the dispenser board itself. Give me some time to look over the wiring diagrams closer and I will come back with some better solutions.....Sea Breeze
Jul 03, 2009 | Jenn-Air JSD2695KES Side by Side...
The washer stopped and error code f70 displayed. It would not reset. I unplugged it and now nothing happens but a beep beep when I attempt to turn on the power
The F70 and F71 error codes on this model of washer indicates a communication problem between the user interface control board and the central control unit (main control board). These error codes can sometimes be caused by a power surge or glitch through the electrical lines. Try unplugging the washer to completely disconnect electrical power. Wait 1 minute and then plug the washer back in to the see if the fault code clears. If it does, then the washer may work normally.
If the code reappears, then you could have a wire harness connection problem, a failed user interface control board or a failed central control unit. I recommend calling a service technician to properly diagnose and repair this type of problem so that the correct component can be replaced.
Be sure your unit is plugged into a 3 prong grounded outlet as well.
F71 is a "heatbeat failure" which means that your front interface control board is shorted and will need to be replaced. it's actually fairly easy to replace and can definitely be done by yourself. To access the part, just pull the unit forward and remove the 3 screws coming in from the back of the top panel. Remove the top panel by pulling it back, up, and off. Then remove all the screws going into the top of the control panel. Remove the dispenser drawer and remove the screws coming in through the dispenser. Remove the screws coming from the inside of the dryer going forward into the control panel, then remove the control panel (it's just clipped in on the bottom. After that you can disconnect the wire harnesses to the front interface control board and replace that part.
May 08, 2009 | Kenmore HE2 Plus Front Load Washer
Bosch Next Pemium Washer-intermittent detergent dispensing cycle
Hi.
Sounds like the valve that lets the water in on the dispensing cycle is sticking, if you can hear the valve buzzing i would certainly suspect it to be faulty
Nov 23, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Kenmore HE5t washer
Sep 06, 2008 | Kenmore 67082 Electric Dryer
Water pouring out from the detergent dispenser
Remove the washer top panel by removing the three screws in the back of the washer that hold the panel in place. With the three screws removed, the panel will slide back, then lift off. This will give you a full view of your dispenser and components. I strongly suspect that you have a hose leading from the dispenser to the fill tube along the door that may be either kinked or clogged. Inspect the hose for any kinks. You may have to remove it and flush with hot water. Let me know what you find. I hope this helps.
Sep 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Gold Washer Cataylist
The F4 error code on your washer indicates a problem in the electrical circuits of the washer... and not end-user repairable.
This problem requires a technician to test the wiring circuits to diagnose the problem.
Jun 17, 2008 | Whirlpool GSW9800PW Washer
F 13 code
"F13" is a "Dispenser Circuit Error". If the dispenser motor cannot move to its correct position, the error code is generated. You will need to check the following:
- Check the mechanical linkage from the dispenser motor to the top of the dispenser. NOTE: 9 times out of 10 the small spring that connects the motor to the armature comes off and needs to be reconnected.
- Check the electrical connections from the Central Control Unit (CCU) and the dispenser motor. NOTE: The CCU is the Main Computer located directly behind the wash tub.
- Check to make sure the dispenser motor is running.
In order to see all of this you will need to remove the top panel of the washer. Remove the three screws holding the top panel in place in the rear. Once the screws are removed, the panel slides back then off. Locate the dispenser. Make sure there is a small spring attached from the dispenser motor to a small plastic armature on top of the dispenser. Without it the dispenser will not function. Place the washer in diagnostics mode by performing the following:
Select DRAIN/SPIN, NO SPIN and press any key under OPTIONS (must be the same key) 4 times. "C00" will be displayed on the console as the washer enters a series of diagnostics tests. The first portion of diagnostics tests the operation of the dispenser. You should see the armature moving as the different compartments of the dispenser are being tested. If not, I would suspect a possible dispenser motor failure. As a long shot, the CCU can also fail, but may cause different symptoms and multiple error codes. Press PAUSE/CANCEL twice to exit diagnostics.
I hope this information is helpful to you. Please post back if you need further assistance.
May 22, 2008 | Kenmore Elite 45986 Front Load Washer
Open Questions:
See all Frigidaire ATF6700FS Front Load Washer Questions
Frigidaire ATF6700FS Front Load Washer Logo
41 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
