Question about Siemens Washing Machines
Code f 51
Need to wash
  • Siemens Master
  • 16,010 Answers
That is a drum speed sensor failure. Replace the sensor and if it wont work, replace the control board.
Posted on Mar 29, 2014
What is error code 51?
search for it on Google make model and error code 51
Jul 28, 2015 | Washing Machines
F 51 code
my hhot point washing machine door won't open and is displaying F5 and door block
Nov 20, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
I ran the diagnostic on my fisher and paykel gwl 11 and it has a fault code 51. Is that more than just a diverter value?
This is error code 51
51. (00110011) Phase 5 and 6 Eco - Diverter Valve Fault
Primary: The motor controller has registered a drop in water level in the
recirculation phase of the wash cycle, water is being drained instead of recirculated.
Or water has been sprayed onto the Valve from an external source and caused the
solenoid to blow.
Action:
Turn the power off at the machine but leave the power on at the wall, then measure
the voltage across the terminals of the wax actuator, if a reading of 230V is
achieved the motor controller has failed due to the valve and both will need to be
replaced.
Secondary: Check for blockage in the valve itself or a broken hinge mechanism.
Mar 12, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Panasonic na-168vg3 h51 code flashing
Hi Rick, What does H 51 mean on the display of my Panasonic NA 140vg3. However, after that code has flashed a circle symbol will appear, then it will disappear. The door won't open. I would appreciate your help. Cheers
Jan 16, 2013 | Washing Machines
What is that mean code f 51 on my wash machine
1) motor RPS failure, this mean SENSOR faulty between the motor vs board.
2) clean the sensor from oxide, dirty, and tight the wires connector very well.
3) This is a difficult process for to access him. If you do not have enough experience, you must call a service tech.
God bless you
Jun 29, 2012 | Maytag Washing Machines
What does fault code 51 mean?
Error code 51 usually means a faulty diverter valve. Try and run a wash cycle, and observe the drain hose. If water comes out, the diverter valve should be fine, if no water comes out you should take your diverter valve out and check for debris, or continue to read through the following possibilities of why your washing machine is acting up, and the actions to take.
1. Diverter valve
Action - Check diverter valve continuity. If open circuit, replace diverter valve.
2. Motor Controller Board (drive circuitry blown).
Action - Replace Motor Controller Board
3. Diverter valve harness/connectors.
Action - Replace wiring harness
Jul 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
Error code 51? F & F intuitive washer
Hi just read your posting.Error code 51 means you have a Recirculation Fault.This means while the machine is filling or washing it loses water.Error code 37 means you have Pump Block error which means the machine is not draining.Please look under the machine to the front right and you should see a pump with a red or black fan attached.Can you confirm this please? I think there is a problem with your diverter valve and the information on your type of pump will help me rectify this problem for you.Please reply with additional information on the type of pump in your machine.Looking forward to your reply.
Jul 01, 2010 | Fisher and Paykel Washing Machines
Washing Machines Logo
162 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
