Question about whipper snipper stihl fs 38
Stihl Too much cord use
Stihl chainsaw 036 will not start and cannot pull cord more than about 8 inches. feels like compression brake is on
Remove the spark plug and see if you can pull the cord though its full travel. This will help future troubleshooting. Please provide the full model number in any response.
Feb 10, 2015 | Stihl Garden
Weedeater troubleshooting
bad extension cord ???
Aug 28, 2014 | Stihl Garden
How do I rerpair broken starter rope on Stihl FS 45 trimmer
Pretty simple. You will have to take the housing off to access the coil. Depending on your type of pull start you may have to tie the end on to the cord reel and hand crank the tensioner while you feed the cord on. Once that is complete fee the line through the hole in the housing and tie on the rubber pull. You should be set.
Jul 26, 2014 | Stihl Garden
How to replace starter cord stihl 35
i do not show Stihl as having a 35. usually on the trimmers there are 3 screws on the starter housing that come out and the cover comes off. after that you need to remove the old rope put in a new rope on the rotor, wind it up, put the cord through the grommetted hole, let it slowly rewind itself to a point that is almost in then put the handle on put the cover back on insert 3 screws and you should be done
Feb 13, 2013 | Stihl Garden
Replace pull cord on Stihl MS 180 C chainsaw
Are you asking something, or telling someone to replace a pullcord on a chainsaw?
Nov 08, 2011 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
How to fix a retractable winding for the start cord on a sthil weed eater. cord is hanging out and will not retract back in.
Have never worked on a Stihl, but it's evident ..you are going to have to remove all the covers to get to the recoil unit itself and when you get there, you will see the problem. Don't know what kind of fasteners Stihl uses on their equipment, but the cheaper manufacturers use TORX screws in their applications.
Jul 18, 2010 | Garden
Unable to crank Stihl 034 chainsaw because pull cord jams.
i had the same thing with a stihl hedgecutter its a part in the centrefruge that locks if you pull to hard pull slow and let all the cord come out let it in half way full choke on start just where it used to lock and it will start . the bad news .it wont last for long before you smash the wheel thats plastic and if its over about 5 years old they dont have a replacement part hope this helped
May 23, 2009 | Garden
Garden Logo
21 people viewed this question
Top whipper snipper Garden Experts
richie46
ray gallant
Bill Boyd
Are you a whipper snipper Garden Expert? Answer questions, earn points and help others
