Question about Frigidaire ATF6700FS Front Load Washer
Washer comes on but no water comes out
Machine turns on goes through cycle but no water us coming out
  • Frigidaire Master
  • 16,166 Answers
Check the water valves to be sure they are on. Then if they are, you may have a controller issue because one of the water valves should work, either hot or cold. If they both stop working it is usually not the valve.
Posted on Mar 29, 2014
Testimonial: "They are working just no water coming out the machine is humming like its going through the cycle but nothing is happening every once in awhile a spurt of water will come out...."
  • 1294 Answers
SOURCE: washing machine
Probable your outlet filter is clogged, find this out from your manual, clean and refit. Plug off the wall first. This requires periodic cleaning, according to your usage.
Posted on Sep 11, 2007
  • 209 Answers
SOURCE: water only fills the machine in certain parts of cycle
a 90* wash will fill mainly with hot water / a 40* wash will fill mainly with cold water, this is normal action, rinses fill up with cold water only
is this what you are describing, if so thats normal, especially if its doing the job correctly
Posted on Oct 14, 2007
Master_Tech
  • 770 Answers
SOURCE: washing machine error code on Frigidaire ATF6000E
No E20 on that model# Heremis a list of the codes
Failure code Fault condition Check
E11 Fill time to long. Refer to test (1).
E13 Water leak in tub or air leak in air bell. Refer to test (2).
E21 Water not pumping out fast enough. Refer to test (3).
E23 Drain pump relay on control board failed. Replace control board orwire.
E24 Drain pump relay on control board failed. Replace control board orwire.
E31 Pressure sensor not communicating with control board. Refer to test (4).
E35 Pressure sensor indicates water overfill. Refer to test (5).
E36 Control board problem. Replace the control board.
E41 Control board thinks the door switch is open. Refer to test (7).
E43 Board communications problem. Replace the control board.
E44 Board communications problem. Replace the control board.
E45 Board communications problem. Replace the control board.
E46 Board communications problem. Replace the control board.
E47 Board thinks the door PTC circuit is open in spin. Refer to test (7)
E48 Board thinks the door PTC circuit is closed. Refer to test (7)
E52 Bad signal from tacho generator. Refer to test (8)
E56 Highmotor current. Refer to test (9)
E57 High current on inverter. Refer to test (9)
E58 High current on motor phase. Refer to test (9)
E59 No tacho signal for 3 seconds. Refer to test (10)
E5A High temperature on heat sink. Test first if bad replace
speed control board.
E5B High temperature on heat sink. Replace the speed control
board.
E5C High temperature on heat sink. Replace the speed control
board.
E5D Communication problem. Refer to test (11).
E5E Communication problem. Refer to test (11).
E5F Communication problem. Refer to test (11).
E66 Heating element relay failure. Refer to test (14).
E67 Input voltage on microprocessor incorrect. Refer to test (15).
E68 Current leakage to ground on heater or fuse opened. Refer to test (14).
E74 Wash temperature does not increase. PlaceNTC in correct position.
E75 Water temperature sensor circuit. Refer to test (12)
E76 NTC temperature for the cold water valve over the limits. Hot and cold water hoses
switched.
E82 Console control problem Replace the control board.
E83 Console control problem Replace the control board.
E91 Selector LEDs do not light up Refer to test (16)
E93 Console control problem Replace the control board.
E94 Console control problem Replace the control board.
E95 Communication error. Replace the control board.
Posted on Apr 01, 2008
philbran
  • 242 Answers
SOURCE: washer fills up than starts draining while in wash cycle
Hello , here is the fix-your drain hose is placed to low in the drain line in the wall, it can not be placed in water or it will siphon the water out of your washer into the drain pipe and it wont stop until it hits air. try pulling your drain hose up and out of the drain and get a zip tie or cable and tie it to one of the water valves by the drain pipe placing the end of the drain hose about 5-6 inches inside the drain pipe. Let me know if you have any other questions and good luck it will work.
Phil
Posted on Jan 28, 2009
SOURCE: Washer won't fill on wash cycle
Sounds as though you need to disconnect the hoses, inspect the
screen inside the hose to see if it has a collection of copper oxides
and other mineral deposits. Remove the screen and use an old
tootbrush to clean it thoroughly. This usually does the trick.
Tried to post this earlier but could not get past the "code" entry
censor! Guess when you are 80 and female it is harder to post to
a "solution" page.
adavisw@gmail.com
Posted on Apr 04, 2009
Amana washer will not go through rinse cycle
WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
Mar 28, 2015 | Amana Washing Machines
My washing machine stops at the rinse cycle everytime. it is a hand-me-down washer that worked fine at the previous owner's home. not to mention this is the second washer i have received as a hand-me-down...
when a washer goes into the rinse cycle it only uses cold water,i think you have a problem with your cold water supply and if it happened to two washers it's not the washer.shut down the water valve,remove the cold water hose off the back of the washer,stick it into the washer and turn it back on.if no cold water comes out this will be your problem.
Jan 23, 2011 | Maytag Performa PAV2200
Kenmore 800 washer no water comes in turn dial and it only goes into spin cycle
check water supply to the machine if you have water check the inlet valve screens located at the back of the washer where the supply hoses hook up at
Nov 17, 2010 | Kenmore 22422 Top Load Washer
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
Won't spin or drain, have tried to rerun cycle and checked drain hose
Check pump / outlet filter , refer to instruction book , clean and replace then re- try
Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water will not shut off in washing machine
Check to load size selector switch, sounds like tube came off of it. The tube goes from switch to bottom of tube, tells machine what size load and when to turn off water.
Jul 19, 2009 | GE WBSR3140DW Top Load Washer
My lg washer turns on but i cannot select which cycle I want
The LG washers are very buggy. Yes buggy. They have an on board computer that to this day still has issues. This sounds to me like the computer is confused about cycle changes. The component is also quite difficult to change. On ether side of machine are screws that need to be removed to lift lid. There are 3 modules inside. you will need to look at the wires to see where the largest sum of wires come together. That will be the main unit. Hope this helps. Good luck.
Apr 25, 2009 | LG WM-2277HW Front Load Washer
Bosch Next Pemium Washer-intermittent detergent dispensing cycle
Hi.
Sounds like the valve that lets the water in on the dispensing cycle is sticking, if you can hear the valve buzzing i would certainly suspect it to be faulty
Nov 23, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing machine
turn power off then turn tap on if water comes in then the valve is faulty,if it doesnt then check the pressure tube for leaks or the pressure switch.hope this helps
Mar 24, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Open Questions:
See all Frigidaire ATF6700FS Front Load Washer Questions
Frigidaire ATF6700FS Front Load Washer Logo
115 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
