Question about Siemens Washing Machines
How to fix a code f 51
Need to wash
  • Siemens Master
  • 16,194 Answers
See other post on this. There is nothing that you can do right away.
Posted on Mar 29, 2014
F 51 code
my hhot point washing machine door won't open and is displaying F5 and door block
Nov 20, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Repairclinic com
follow this steps and fix it. God bless you
Error Code
  • Clear the error code and stop the beeping by pressing the "Stop" and "Start" buttons at the same time. Unplug your washer so you can examine the problem.
Function
  • The error code displays because something is wrong with the motor sensor. This can be for a number of reasons. After you clear the code, try washing clothes again and seeing if the error appears. If it does, then you need to take further steps.
Read more: http://www.ehow.com/facts_7565280_kenmore-elite-error-code-f51.html#ixzz2aTwM1Z2u
Jul 29, 2013 | Kenmore 24032\24036 Top Load Washer
F-51 code
Motor RPS Failure--F then 51 flashes when there is a motor rotor position sensor(RPS) senses rotation after stop command.F-51 ERROR CODE IS DEALING WITH THE SPIN CYCLE. THE CONTROL DOES NOT DETECT IT SPINNING.THE RPS SENSOR ON THE BOTTOM OF THE UNIT NEEDS TO BE TAKEN OFF AND PUT BACK ON ABOUT 10 TIMES. SOUNDS WEIRD BUT USUALLY FIXES IT.But if that does not help then it needs to be replaced. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Sep 01, 2010 | Kenmore Oasis HE 27082 Top Load Washer
What does fault code 51 mean?
Error code 51 usually means a faulty diverter valve. Try and run a wash cycle, and observe the drain hose. If water comes out, the diverter valve should be fine, if no water comes out you should take your diverter valve out and check for debris, or continue to read through the following possibilities of why your washing machine is acting up, and the actions to take.
1. Diverter valve
Action - Check diverter valve continuity. If open circuit, replace diverter valve.
2. Motor Controller Board (drive circuitry blown).
Action - Replace Motor Controller Board
3. Diverter valve harness/connectors.
Action - Replace wiring harness
Jul 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
F-51 code on kenmore elite oasis washer - how to prevent and or fix
Please see the following Whirlpool Cabrio installation and service manual, the Oasis is essentially the same washer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
The F and 51 code relates to the motor rotor.
"F then 51 flashes when there is a motor rotor position sensor (RPS) failure. See TEST #3."
The "test #3 is a bit complicated but can be completed if you are reasonably comfortable with test equipment.
Oct 20, 2009 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Whirlpool wtw6200 cabrio washer error message f 51
I work for an appliance repair company and I had a recent service call for the same exact situation on this washer. I also know that Rotary Position Sensor is linked to the F-51 error code. I have found that this is not always the case. On this paticular call the F-51 error code was caused by a piece of clothing (sock, wash cloth, etc.) being stuck or jammed between the internal basket and the outer tub. I removed the cloth and the washer ran fine, so give that a check first before you spend the money.
Dec 13, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Fix
sears has a update out on f 51 error code.there could be a problem with your motor sensor.]
Aug 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool Cabrio HE washing machine displays error code F51. What is it and hw to I fix it?
Jul 27, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Code 51
Saw this in other area of blog (see below). I had same problem and Whirlpool service replaced RPS control board...fixed problem. Best Solution posted on Oct 20, 2007 2%20stars.png
446a518.jpg By wizard_s.gif eagle338
Rank: Wiz
Rating: 75%, 482 votes
there is a motor rotor position sensor(RPS) failure.
Refer page 10 of the manual below
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567036.pdf
If you still cant fix it come back here..and ask i will help you out..
And please dont forget to rate if its solved..
Aug 19, 2007 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
166 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
