Question about Whirlpool duet Washing Machines
I have a code f 51 what do I do
Want to know how to fix problem
  • Whirlpool Master
  • 15,639 Answers
There are two possible solutions to the problem. First is to replace the speed sensor on the drum. If that does not fix the problem the next thing is a new control board. If you buy the parts yourself and install them, it is less than 200. This is a known issue with these machines.
Posted on Mar 29, 2014
Toyota Yaris 51 plate will not select a forward gear when clutch is pressed
  • uK car, with REG codes, nobody knows. 51 is 2001 ?
  • use years so all readers can understand what reg means.
  • the clutch linkage is bad, easy fix. get it serviceD or read the the sevice manuals ???
  • if car has hydraulic clutch pedal check fluid level if low biNGO
  • BAD Master cylinder or slave. (some engines (no stated) THE SLAVE IS BURIED DEEP
  • NAME YOU ENGINE PLEASE. SIZE OR REAL NAME
Jan 02, 2015 | Toyota Cars & Trucks
What repairs should be made for diagnostic codes 13 and 51 .
which engine, that be first. no? look at it and what is it?
ill pretend 4.0L I-6
old car, with OBD1. code 13 and 51 are fully covered in the FSM.
ever seen and fsm? login to aldata.com and read.
and is discussed , infinitely on all jeep forums on the net. endless.
google that.? yet?
here ill google for you
i google jeep 13
http://www.allpar.com/fix/codes/faults/code13.html
and jeep dtc 51
http://www.allpar.com/fix/codes/faults/code-51-52.html
13 would cause 51s so,...... work that.
Oct 02, 2014 | 1994 Jeep Grand Cherokee
F 51 code
my hhot point washing machine door won't open and is displaying F5 and door block
Nov 20, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
F-51 code on kenmore elite oasis washer - how to prevent and or fix
Please see the following Whirlpool Cabrio installation and service manual, the Oasis is essentially the same washer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
The F and 51 code relates to the motor rotor.
"F then 51 flashes when there is a motor rotor position sensor (RPS) failure. See TEST #3."
The "test #3 is a bit complicated but can be completed if you are reasonably comfortable with test equipment.
Oct 20, 2009 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Hi, I get code number 51. Not sure what I can do to find and fix problem. Thanks
Code 51 is Wide Open Throttle Problem. You need to replace your fuel filter, possibly drain fuel tank and clean fuel pump pre-filter. That is in the fuel tank. If you have the cash, I would replace fuel pump while inside the tank.
Sep 25, 2009 | 1994 Chrysler LeBaron
Unable to print 51 - what doe it mean? I have had Brother MFC-440CN, it has worked well... However, I got error msg "no paper" althought the tray was full of paper; tried to fixed - on/off; delete/add......
Hi Ok try this it may work.
1.Go Menu
Type in *2864
Type in 10
Code WSW00 shows
Type in 51
Code WSW51 0000001 will show
Try different values, eg change to 000000 or 0000010
BUT remember original code to get back to
To exit type 99
Also can try.
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one
All The Best: Pineworks
Jul 11, 2009 | Brother MultiFunction Center MFC-440CN...
Whirlpool Cabrio HE washing machine displays error code F51. What is it and hw to I fix it?
I work for an appliance repair company and I had a recent service call for the same exact situation on this washer. I also know that Rotary Position Sensor is linked to the F-51 error code. I have found that this is not always the case. On this paticular call the F-51 error code was caused by a piece of clothing (sock, wash cloth, etc.) being stuck or jammed between the internal basket and the outer tub. I removed the cloth and the washer ran fine, so give that a check first before you spend the money.
Jul 27, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Error code
and even if you did get rid of error 51 that you have created, you will find that you still cant print in black, original problem is the print head is stuffed probally from dodgy non gen ink running threw it and the fix is to replace head. I don't know who is telling all you brother mfc owners to clean your print head but your paddling up the wrong creek, these heads are electronic deivices that dont take kindly to cleaning, they are not the same as other brands. Re error 51 goto different machine same engine post
http://www.fixya.com/support/t277162-brother_420
Dec 04, 2007 | Brother MFC-5440CN All-In-One InkJet...
Washing Machines Logo
22 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
