Question about Hitachi Televison & Video
Does there exist a manual for Hitachi Natura Tv, progressive scan on net?
  • 10,594 Answers
Please intimate exact model number of your Hitachi TV to look for user manual. Model number would be written on sticker pasted at back of TV.
Posted on Jun 15, 2009
  • ManinderM Dec 02, 2010
    c32wf523n-311
How do you get higher than 480p resolution on playback?
Hi Chuck, I copied this from the MWD7006 manual - I hope it helps.
If your TV is compatible with 525p (480p) progressive scanning and you want to enjoy that high quality picture, you must use Component Video cable connection and progressive scanning mode.
To set the mode, set "PROGRESSIVE" to "ON" in SETUP menu, so that the "P-SCAN" indicator on the front panel lights up.
When "PROGRESSIVE" is "ON", video signals from the unit's VIDEO OUT and S-VIDEO OUT jacks will be distorted or not be output at all.
If your TV is not compatible with progressive scanning, use this unit in interlace mode and set "PROGRESSIVE" to "OFF" either in SETUP menu, or by pressing and holding [PLAY B] on the front of the unit for more than 5 seconds, so that the "P-SCAN" indicator on the front panel lights off.
Download Magnavox MWD7006 Owner Manual
Jan 25, 2014 | Philips Magnavox MWD7006 DVD Player
When i try using prgressive scan it comes up error why and how can i get progressive scan to work
In order to use progressive scan you must have a progressive scan compatible tv. Check your users manual to find out if its compatible. If it is it should give instructions to turn on the progressive scan option for tv.
Aug 26, 2011 | Zenith XBV442 DVD Player/VCR
We see a yellow anouncement that says PSCAN and it splits the image
Hello
PSCAN; means Progressive Scan. To get the splitted picture together you have to change the scan system of your tV to progressive scan. Now it runs on Interlace Scan. If your TV has Progressive Scan function; refer to its user manual; set it to progressive scan. An other way is to change the scan system with DVD. Try either. OK.
Jun 20, 2011 | Memorex MVD-2045 DVD Player
Need to hook up a TV,VCR-DVD player,and CD player
Progressive scan video output would be available on Component Video terminals of dvd player so set connections between TV and dvd player via Component Video cable.
Please intimate model and brand of product that you need instruction manual.
Thanks.
Aug 31, 2009 | Sanyo Cinematic Progressive Scan DVD...
I bought a Natura Classica camera and I can't translate the Japanese manual. Does an English version of the manual exist?
The Fuji Natura Classica is a Japanese only model so no English manuals were produced.
The website below does give some translations though:-
http://moominsean.blogspot.com/2007/12/fuji-natura-classica-black-and-white.html
Jun 24, 2009 | Fuji Photography
Unlock zone Hitachi DVD player
I can't get my hitachi natura to connect to my dvd player using RCA plugs. I can't actually see how to switch to the av mode! Please help - small children going BONKERS!
Apr 13, 2009 | Hitachi DV-P745U DVD Player
Split screen on DVD player
This sounds like a progressive scan issue (unit in P.Scan Mode) here is a C&P from the manual
Set "Alt Video Out"
Highlight "Alt Video Out", then press the RIGHT button to select
one of the following options:
• S-Video - Select this if you are using the S-Video OUT jack on
the rear panel to connect to a TV.
• Component - Select this if you are using the COMPONENT
VIDEO OUT jacks on the rear panel to connect to a
Progressive(480p) or Interlaced (480i) TV.
• See your TV owner's manual to determine what type of TV you
have.
- Interlace : Interlaced Scan mode will work.
- Progressive : Progressive Scan mode will work, and Video
and S-Video will not work.
• Press the Progressive button on the front panel if you have a
Progressive scan TV only. Otherwise, the picture will be
disturbed.
Feb 04, 2009 | Samsung DVD-V3650 DVD Player/VCR
Natura Hitachi 36in TV - Not turning on.........
Check the flyback transformer for cause of the odor . If it is a cap look for a cap that is buldging at the top of it . The flyback is the transformer with the red lead going to the picture tube . You might see it is cracked or a tiny hole in it . Good luck
Mar 04, 2008 | Televison & Video
Showing red image
Make sure red is matched up to red, green to green, and blue to blue first. Then, try a different set of YPbPr (component) cables if you have a set available. If it still shows up red, then read this:
If you are using a Progressive Scan TV
(TV must indicate Progressive Scan or
ProScan capability), to activate TV
Progressive Scan, please refer to your TV
user manual. For DVD system Progressive
Scan function, see page 28.
Helpful Hint:
– If your TV does not support Progressive
Scan, you will not be ab le to view the picture.
Press and hold OPEN/CLOSE button and
press ‘1’ to deactivate progressive scan.
Progressive Scan - turning on/off
To select this item, you must set “Video
Output” to Y PR PB and ensure that your
TV has progressive scan (See page 11.)
Follow the steps of “Using the Setup
Menu” and select :
> PROGRESSIVE
OFF
ON
PROGRESSIVE SCAN OFF
TV SHAPE
TV SYSTEM
VIDEO OUT
PROGRESSIVE
SCR SAVER
SMART POWER
OFF
Select this to disable Progressive scan
function.
ON
These are pp. 11 and 28 of your owner's manual for the HTS
If these methods still fail, try turning your TV's progressive scan off or on.
-Tha Mp3 Doctor
Jan 08, 2008 | Philips HTS3410D/37 700W DVD Home Theater...
DVD recorder: Changed the settings, now
we could go through the setting like, you can see the monitor. using the remote do the following steps:
Step 1. press set up button.
Step 2. press down arrow once. ( playback)
Step 3. press OK.
Step 4. press down arrow once. (video (selection))
Step 5. press OK. (progressive scan)
Step 6. press OK, again.
Step 7. press down arrow once. (progressive scan off)
Step 8. press OK
you have now turned progressive scan off.
Dec 19, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Televison & Video Logo
430 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
