Question about Bear GIANT 40" 3-FEET-LONG " I LOVE YOU " BALLOON BOUQUET - 26 Total Balloons and Large Soft Teddy Bear in a ONE-PIECE - ABSOLUTELY HUGE GIFT
Where is the crankshaft sensor located on a 1991 toyota pickup. is it hard to replace
My truck turns over but wont start I checked for spark but don't have any. also replaced the computer, distributer cap & rotor and the coil and igniter
    Problem Solver:
  • 10 Answers
Try on the passenger side under neath by the flywheel
Posted on Jun 25, 2014
Where is the crankshaft sensor located in a 1991 honda accord
I don't list a crank sensor for a 1991 - probably because it has a distributor. Do you have spark to the plugs ? If not, you'll need a repair book to diagnose the ignition wiring.
Feb 16, 2015 | 1991 Honda Accord
It cranks but wont start. replaced starter, coil, spark wires and plugs. crankshaft position sensor, distributor and cap. still wont turn over. fuel pump turns on fine, and there is pressure at the...
the ignition module probly bad-replaces points and located in distributer area--batt must also read 12.6v and alternator must be healthy--fuses may not all be good--take a light tester to um--make sure inline safety fuse on the batt line is workn
Oct 10, 2013 | 1991 Jeep Wrangler
95 toyota camry wont start wont crank turn of the key and nothing
the (knock sensor) crank position sensor...is just behind the harmonic balancer, (lowest pulley on the motor) on the block, usually on the left side.
i would check the coil first though. sounds to me like a no spark issue.
Apr 05, 2013 | Toyota Camry Cars & Trucks
I have dodge ram 1500 v8 model 2002 no start can you help me
If the spark is getting right.Get the fuel system checked.Its quite possible that fuel pressure is low or fuel pump not starting up right.
CAR NO START PROBLEMS:-----
It can be the issue with weak battery or faulty battery or if battery is ok,then its faulty starter causing the issue.
From start to end troubleshooting these problem i suggest you to click the link below and follow its procedure:-----
What to Do When Car Turns Over But Won't Start?
http://technoanswers.blogspot.com/2012/11/what-to-do-when-car-turns-over-but-wont.html
Car starting issues?
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
Car Starting Problems
http://whoisbyme.blogspot.in/2012/06/car-starting-problems.html
1991 Toyota Trecel: Engine Starts fine but dies when gets Warm?
http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
1994 Toyota Pickup: Starts fine but dies in few seconds?
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
1999 Chrysler Cirrus: 8 IGN Fuel Starter Fuse Blows?
http://whatisbyme.blogspot.in/2012/06/1999-chrysler-cirrus-8-ign-fuel-starter.html
2001 Toyota Camry: No start After replacing Battery?
http://whatisbyme.blogspot.in/2012/05/2001-toyota-camry-no-start-after.html
1989 Toyota Pickup Truck: Turns over but not start?
http://whatisbyme.blogspot.in/2012/05/1989-toyota-pickup-truck-turns-over-but.html
Car dead and will not Start?
http://whatisbyme.blogspot.in/2012/05/car-dead-and-will-not-start.html
1995 Lexus LS400: Running Hot?
http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
2001 Toyota Prius will not start?
http://whatisbyme.blogspot.in/2012/05/2001-toyota-prius-will-not-start.html
1996 Jeep Grand Cherokee: Engine will not start?
http://repairhelpcenter.blogspot.in/2012/06/1996-jeep-grand-cherokee-engine-will.html
Mitsubishi will not start
http://www.howtorepairguide.com
These will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
Volvo s40 will not start betting spark and gas
It can be the issue with weak battery or faulty battery or if battery is ok,then its faulty starter causing the issue.But if these basics are checked ok,then the problem is low fuel pressure or no spark:------
1989 Toyota Pickup Truck: Turns over but not start? http://whatisbyme.blogspot.in/2012/05/1989-toyota-pickup-truck-turns-over-but.html
Car dead and will not Start? http://whatisbyme.blogspot.in/2012/05/car-dead-and-will-not-start.html
2001 Toyota Prius will not start? http://whatisbyme.blogspot.in/2012/05/2001-toyota-prius-will-not-start.html
1996 Jeep Grand Cherokee: Engine will not start? http://repairhelpcenter.blogspot.in/2012/06/1996-jeep-grand-cherokee-engine-will.html ------------- Mitsubishi will not start
These will help.
Thanks.
Nov 26, 2012 | 2000 Volvo S40
I have a 2001 honda civic if i try to start it without pressing the gas pedal which seems to be sticking it will not crank it makes no noise whatsoever
Low fuel pressure or problem with spark plugs or crank sensor is got dirty and needs cleaning or its time to replace crank sensor.
Check out the help links shown below for no start problem and cranks but no start problem.
Click the link :-----
These will help.
Thanks.
Nov 25, 2012 | 2001 Honda Accord
Have a 91 dokota 5.2 has no spark i changed the coil and the pickup in the dist do you know where the crank sensor is located
The crank sensor is on the front of the engine it triggers off the front crank pulley. The pickup you changed is the Camshaft position sensor and will cause hard starting but not a complete no start. A picture of the Crankshaft position sensor is below.
May 17, 2011 | 1991 Dodge Dakota
Car wont start, not getting spark
crankshaft sensor, or computer on toyotas then it was usually the distributor or the computer, but the crankshaft sensor might be bad too thats what helps to get you spark.
Jul 31, 2010 | 1991 Toyota Corolla
1991 toyota pickup dies when you release the gas pedal
There are couple of things I would check out that would cause this problem.
1. The Mass Air Flow Sensor. It measures how much air is going into the engine. Should be located on top of air filter box.
2. The air tube that goes from the Mass Air Flow Sensor to the throttle body. Check for leaks that would bypass air from going through the Mass Air Flow Sensor.
3. The Throttle Position Sensor. Located on the throttle body. This tells the computer what position the butterfly plate is on the throttle body. You control this plate with the gas pedal..
Oct 11, 2009 | 1991 Toyota Pickup
1990 toyota pickup wont start/turns over no spark or fuel
there may be a bad contact problem check the wire running into the fuse box and look at the relay for the efi
Nov 25, 2008 | 1991 Toyota Pickup
Bear GIANT 40" 3-FEET-LONG " I LOVE YOU " BALLOON BOUQUET - 26 Total Balloons and Large Soft Teddy Bear in a ONE-PIECE - ABSOLUTELY HUGE GIFT Logo
54 people viewed this question
Top Bear Toys Experts
NOEL
NOEL
Are you a Bear Toy Expert? Answer questions, earn points and help others
