Question about Vacuums
Vacuum brushes are turning but not picking up dirt and is blowing a lot of air out of the top air filter thing
I sucked up a shirt accidentally while I was using the hose but it didn't brake the belt since the brushes are still rotating. It's blowing a lot of air out through the vent infront with a bunch of holes. (not sure what it's called) it will pick stuff up if the tilt the vacuum up a little but when it's flat on the floor it wont pick up. I've cleaned the filter and checked the hoses and all clear as well as a clean canister. I have a Eureka maxima 12amps
    Master:
  • 435 Answers
Did you check carefully for splits? After sucking something up that big, you may have split something, like in a fold of the hose. When it is in a position where the split is somewhat sealed, it works. Move it just a bit and the split separates and it won't work.
Posted on Mar 29, 2014
SOURCE: blows dust and dirt out of brush area
Did you make sure to cut all the strings, hair, etc. out of the brush attachment on the bottom? Look in the corners too to make sure none has gotten stuck on the sides that needs to be cut out.
Posted on Aug 10, 2007
  • 48 Answers
SOURCE: no suction
Is there a blockage in the small hose in the bottom of the machine
take of the pod and you will see the small hose,
Is the main hose pushed into the bottom housing
Posted on Nov 22, 2007
SOURCE: vacuum is sucking but dirt is just shooting out behind the vacuum
I bought this same vacuum and have all the same problems. It seems it is always the filter but if it out and use the air hose and clean it it really really well then it sucks really well it will pick up anything but who wants to always do this. As one person asked about the bare floors not working well I read on another blog that company knows it does not work well on barefloors but has failed to metion this. One more thing besides the clog always being in the back were the hose connects I always find a clog in the yellow part above the canister. I always pull out so much crap there. Oh sorry one more thing I found that helped with the power was that I completely took the duster part completely off and just use the hose. Hope you have better luck than I do or did..
Posted on Nov 19, 2008
SOURCE: Dirt Devil Upright Bagless Vibe Vacuum no longer sucks
Sounds like there's a clog in the long hose that connects to the dirt canister. Remove the hose completely and check for clogs. There is a blue plastic piece that the hose is attached to. You can remove it by taking out the two screws in the back, and the four screws behind the dirt canister. Once those are removed, the hose comes away from the vacuum with the blue plastic piece attached. That should allow you to check for clogs. If necessary, take the hose outside or a place that is well lit, so you can visually verify the absence of clogs.
Posted on Oct 29, 2009
  • 58 Answers
SOURCE: dirt devil mvp not sucking
These Red Devil vacuums (like the similar Hoover uprights from the 1970's) rely on the sealed rigid bag case to pull the air through the bag before it reaches the vacuum motor. Any air that leaks into the case without passing through the bag decreases the available useful suction.
As a side effect, the motor runs slower when the case isn't sealed because ironically there's more air coming in for the vacuum motor to move and its working harder. The vacuum motor spins fastest when the vacuum is sealed up and the hose is blocked and no air passes through the machine.
Posted on Jul 28, 2012
I have a hoover Dust Manager DM6200. actually it is my friend's. She said it wasn't working well, so I took a look. It wasn't picking up, and seemed to be spreading dirt in fact. I emptied...
Hey Julie,
Hopefully we will get this solved together.
To me, this problem sounds like either the filters are choked up and cannot breathe, OR.... the bagless cannister is not quite sitting in the machine properly.
Honestly, I am more leaning towards the cannister not quite in properly, that is assuming that everything is out of the suction hose.
Start with the process of elimination. Remove and clean the filters with a paint brush or other brush. Get as much dirt and debris off of them as you can and replace them into the machine.
Turn on the machine, and using only the hose attachment, feel if the suction is there. If not, try a re-alignment of the cannister and check the hose. a small coin or marble running through the hose will tell you if there is still a blockage in there.
Where the attachment hose connects to the bottom of the machine could also be blocked up as well. This will also give the same effect of the dirt blowing out the bottom of the machine.
Lastly, it is also quite possible that the belt has stretched or worn out. This too will contribute to it not picking up.
Let me know if this helps, and we will go from there.
Good luck,
Mark
Jan 24, 2012 | Kirby Ultimate G Bagged Upright Vacuum
Eureka Maxima 12 amp vaccum cleaner is not picking what can be done to make it pick up?
remove and clean the filter ( tap and brush filter or use a air compressor to blow out filter ) --- also check the vacume hose near the floor attachment for any dirt and debris that may be clogging the line. this should bring your vacume to full operation.
c...
Jan 22, 2011 | Eureka 4700A Maxima Bagless Upright Vacuum
Kirby g2000 not picking up dirt
I would check to make sure he put the filter bag in correctly.
Dec 16, 2009 | Vacuums
The vacuum is blowing out a lot of air, doesn't ****
make sure the dirt cup is empty and the filter cleaned .. once the filter is clogged it wont work ...make sure everything is assembled correctly to seal the cup ... this nice little vacuum should work good except on deep carpet ..
Sep 28, 2009 | Eureka Boss SuperLite Bagless Upright...
Motor runs fine and hose not clogged will not pickup dirt
This may sound silly, but have you checked the belt? A lot of Eureka vacuums use the vac motor to run the brush, and if the brush is not running the vacuum won't pick up. Another thing to check is the condition of the fan blades.. if they get worn they will push air out of the exhaust ports, but not push enough air to pull the dirt into the vacuum bag. Another thing to check is the length of the bristles on the brush... you can change a lot of the bristle strips and save the cost of a whole brush roll.. All of these fixes are under $10.00 (Belt: $1-2, Brush Strip $3-6, Fan $5-10) at most places.
Jan 19, 2009 | Eureka Vacuums
Vacuum Cleaner sucking dirt out of the cannister instead of into it.
You didn't give you model number, but check by the brush roll to see if the inlet there is clogged, hose still has a clog, filters are bad and need replacing. Does the brush roll turn, belts stretch after short usuage and will not drive the brush roll under load, may need to replace the belt.
Oct 29, 2007 | Eureka Whirlwind 4496 Bagless Upright...
Blows dust and dirt out of brush area
Jun 03, 2007 | Kenmore 25812 / 25813 Progressive Bagged...
My dirt devil vacuum won't suck up anything and its brand new!!
Take the vac bag off and turn on the vac , it should blow air out, if not unclogg the hose where the bag connects, also when you check the roller and belt, unclog the flex hose(located inside base near roller assembly) that sucks up the dirt. As long as the motor works fine the rest is just maint.
Mar 30, 2007 | Dirt Devil M085805 Upright Vacuum
Vacuums Logo
82 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
