Question about Whirlpool Dryers
Du1050 dishwasher drain/cancel is only button that works
Wont turn on
  • 76 Answers
SOURCE: dishwasher won't start
jamcdani Most likely the problem with your dish washer is bad key pad. It is not repairable and has to be replaced. Whirlpool does not sell it separate and you have to by the whole console assembly. The price range is between $95 and $115 (different colors) and it is not very complicated to replace it. I can help you with the complete step by step instructions and, if you provide the complete model number of your dish washer, I get the part number and the best price for you. Gendos post back...
Posted on Jun 29, 2007
SOURCE: keeps flashing clean Kenmore dishwasher 665.17019401 need a new owners manual
i was trying to install my kenmore elite 665 dishwasher but i cant find the plug do they come with one? or were do i hook it up?
Posted on Dec 19, 2007
SOURCE: WHIRPOOL DISHWASHER WILL NOT DRAIN
I had this problem too & found the discharge hose was clogged. To fix it I had to pull out the diswasher , disconnect the drain hose and blow it out.
Posted on Oct 05, 2008
  • 338 Answers
SOURCE: Kenmore Ultrawash QuietGuard 3 Dishwasher not draining or rinsing
Not draining may either need new drain motor. or something is blocking the drain pipe.
Spots on dishes means you are using to much detergent or the wrong kind of detergent.
Your owners manuel should tell you what type to use.
Posted on Nov 25, 2008
tzweeb
  • 318 Answers
SOURCE: dishwasher not draining - Kenmore dishwasher model 15754
depending on the age of this unit it may have food blocking what is called the "check valve".
on most models it is mounted right on the outlet of the pump housing. one model uses a 4 inch plastic tube style device and is about 1/2 inch on the pump and 1" on the hose. inside of it is where the food items can block the check valve. remove the hose and unscrew the check valve from the pump and see if something is blocking it.
on newer units the check valve is built into the drain hose, if you hose has a 90 degree elbow molded into it where the hose hooks up to the drain pump. once again take the hose off and look inside the hose or try to blow through the hose and see if the hose is clear.
good luck tom
Posted on Dec 31, 2008
Dishwasher wont start models 6651345
Really need more information... Do the selector buttons and lights work? If you press Cancel, will it drain (i.e. does the drain pump run)? If lights work, but nothing else does, then it is probably a bad door latch, or at least a bad door switch inside the latch.
Jan 17, 2015 | Kenmore Dishwashers
My dishwasher DU1050 is stuck on Lock and I've
Hi! cccole
Dishwasher may be in bind. remove kick plate and make sure adjusters are not putting case in a twist, or pressing unit to tight to top of cabinets.
InMrFixIt.
Jun 19, 2011 | Whirlpool 24 in. DU1050SS Built-in...
Want to stop buschh dishwasher shx43p15uc from beeping at end of cycle
To turn off the cycle completion signal on a Bosch dishwasher, please do the following:
1. Press and hold the right "CANCEL/DRAIN" button then press and hold the "ON/OFF" button
2. When the light above the "CANCEL/DRAIN" button illuminates and the beeping starts, release both buttons
3. Press the right "CANCEL/DRAIN" button repeatedly until the tone is at the desired volume, i.e. silent
4. Press the "ON/OFF" button again to confirm/set the desired volume.
Happy Holidays!
BElectric
Dec 24, 2010 | Dishwashers
How do I turn the finished washing alarm off?
You don't actually turn it off, you simply set the volume to zero. To turn off the cycle completion signal do the following:
1. Press and hold the right "Cancel Drain" button then press and hold the On/Off button
2. When the light above the "Cancel Drain" button you are pressing illuminates and the tone begins to sound, release both buttons
3. Press the "Cancel Drain" button until the tone is either at the desired volume or silent
4. Press the On/Off button again to confirm/set desired volume
Hope this helps.
Regards, BElectric
Nov 18, 2010 | Bosch SHU9952 Built-in Dishwasher
Bosch dishwasher will not drain
drAIN AND CANCEL BUTTON WILL RESET UNIT;)
Feb 25, 2010 | Bosch 24 in. SHE44C05UC Stainless Steel...
Have a whirlpool dish washer it wont work the cancel drain button is blinking how do i reset that thanks
have you tried refilling salt and rinse aid?
if that do'nt work it probably needs servicing it could be drain pipe blockage.
Jun 17, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
The only button that works is the cancel drain
Sounds like a keypad malfunction or the control board has gone bad.
Feb 13, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Hi: How do I turn off the beeping signal when the cycle is completed on my Bosch dishwasher? It's a fairly new model, with the control on the top of the door. Thanks, Jean Ferrario
I just tried this and it worked.
The Cycle Completion Signal
this Cycle Completion signal is a tone that sounds to alert you when your dishwasher finishes washing and drying your dishes. You can either disable the tone or set the volume.
to activate:
· press and hold the right “Cancel Drain” button then press and hold the on/off button.
· When the light on the “Cancel Drain” button you are pressing illuminates and the tone begins to sound, release both buttons.
· press the right-most “Cancel Drain” button until the tone is either at the desired volume or is silent.
· press the on/off Button. the Cycle Completion signal is now set.
Jan 22, 2009 | Dishwashers
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
