Question about Equus 2004 Toyota Celica Obd2 Can Code Reader For Vehicles Built After 1996
Toyota obd1 code - Equus 2004 Toyota Celica Obd2 Can Code Reader For Vehicles Built After 1996
    Master:
  • 435 Answers
Same as your other post---"code" problems means you need to take your car in and have a computer diagnostic ran on it. You probably can't fix this at home without the equipment.
Posted on Mar 29, 2014
Where is the obd1 connector on a 1986 toyota tercel
located on the driver's side strut tower.
codes etc = https://www.autozone.com/repairinfo/repairguide/repairGuideContent.jsp?pageId=0996b43f8038fb23
Feb 04, 2018 | Toyota Cars & Trucks
What is the number 12 trouble code on my 95 camry dx 2200 engine
1995 Camry 2.2L OBD1 Code 12
Trouble Code 12
Trouble Code 12 Definition:
Engine speed (RPM) sensor -circuit
Trouble Code 12 Meaning:
Wiring, RPM sensor, ECM
Diagnoses Time:
Voltage reading between Engine Control Module(ECM) and RPM sensor.
http://www.troublecodes.net/toyota/toyota-camry-cressida/
Mar 08, 2017 | 1995 Toyota Camry
Toyota Camry 1990 V6 2.5L obd1 codes 11 and 14 Check Engine Light on. Codes 11 and 14. Hooked up a good pulled hopefully ECU and check engine light came on again after driving 1/5 of a mile.
code 14 - ignition signal. No IGF signal to ECU 4-5 times in succession.. need check: • Ignition circuit (+B, IGT, IGF) • Igniter • ECU
Jan 03, 2017 | 1990 Toyota Camry
Where is the diagnostic-obd port on a 1994 geo prizm?
what tool are you using, ?
the car is not OBD2 but is OBD1, (non standard)
and only factory tools work on that OBD1 port. (full support)
the port in under the hood.....
you will only be able to use the FLASH codes,.
lacking special Toyota tools (its a Corolla in Snake skins(suz)
also there are many ports. most have 2 ports.
one for ECU and one for the transmission, (if electrically shifted)
so ill try to ask the question for you, better.
"how to I get the DLC codes from my EFI system , for engine issues." No symptoms stated, so im lost........
right> not transmission.. right?>
http://www.troublecodes.net/Toyota/
Toyota had 9 pre 1996 OBD2 cars. but not one is a corolla or prizm.
so is 2 digit flash codes.
OBD1 the DLC port can be in many places, do to OBD1 is not a standard, and the makers of all cars moved it year by year.
until 1996 and federal laws, changed ALL that.
1998 in Canada.
May 23, 2015 | 1994 Geo Prizm
Check engine light
You first need to run an OBD1 fault code test of the engine control module(ECM), if nothing shows up as far as fault codes goes then you may have a defective MAF (mass airflow) sensor or TPS (throttle position sensor). You can buy the OBD1 system scanner you need on eBay for around $100.00
May 04, 2012 | 1990 Toyota 4Runner
When i push the gas my check engine light comes on
You need to run a OBD1 fault code test, this requires a OBD1 scan tool.
Obd1 toyota corrola 95 diagnostic code 27
Code 27: Sub-oxygen sensor signal or heater circuit fault.
Jan 20, 2011 | Toyota Corolla Cars & Trucks
Trouble code 34
is this car turbocharged? I found that in obd1 vehicles toyota trouble code 34 generally represents a fault in turbocharger pressure signal.
Feb 06, 2009 | 1992 Toyota Pickup
Obd1 trouble code
25) is mixture control continuously lean
42) is VSS circuit - vehicle speed sensor
43) is starter signal circuit
Good luck and I hope this answers your question. And remember to rate all the solutions that you get, thanx.
Oct 30, 2008 | 1995 Toyota Camry
Equus 2004 Toyota Celica Obd2 Can Code Reader For Vehicles Built After 1996 Logo
94 people viewed this question
Top Equus Computers & Internet Experts
Andrew Taylor
Andrew Taylor
ray gallant
Kyle Shockley
Kyle Shockley
Level 1 Expert
Are you an Equus Computer and Internet Expert? Answer questions, earn points and help others
