Pump does not come on
Water does not empty, tub agitates, Is problem the selector switch or pump or other another item??
  • Washing Mach... Master
  • 15,478 Answers
Check the pump filter first. It is under the tub. The panel under the door comes off it is a front loader.
Posted on Mar 29, 2014
  • 159 Answers
SOURCE: Maytag stacked washer/dryer Model LS7804
OK it may be one of 2 things. I would check the lid switch first. On some maytags the have a lid switch that if it is not working properly it will not let the washer fill. If it will not fill the washer will not wash because the pressure switch did not activate the timer to wash. If the switch checks good you might have a bad timer. If you open the control panel you will find a tech sheet with the wiring diagram. I would follow the fill cycle and check the components. You might also check the water valve to make sure its ok too. But its very rear that both the hot and cold would go at the same time. Good luck!
Posted on Jul 12, 2007
  • 67 Answers
SOURCE: won't empty water slow spin in spin cycle
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
if this helps please vote a fix ya
Posted on Jul 15, 2008
  • 1122 Answers
SOURCE: washing machine is not rinsing and spinning
LID SWTICH BAD,THANKS-MIKE
Posted on Jul 23, 2008
vanni7
  • 163 Answers
SOURCE: Water pumps in timer cycles but machine will not agitate or spin
Hii!! yo check your washer belt.if on the you have a tranny problem.good luck
Posted on Jan 20, 2009
  • 653 Answers
SOURCE: Maytag MAV7650AWW spins during agitate cycle
If the tub spins during the agitate cycle, the the problem should be in the timer. It sounds like everything else is working properly. A new timer is fairly expensive, but your Atlantis is fairly new so it should be worth the money.
Posted on Feb 28, 2009
Unit acts like it has received water then continues to cycle as if it hasn't, no water is pumped???
Symptom Check
Click on underlined items for further information Washer does not work and makes no noise Washer does not work but it does make noise No water is entering the wash tub
- or no hot water
- or no cold water The water fills the wash tub too slowly The tub does not fill with enough water
  • Test the water level switch
  • Check that the drain hose is positioned roughly as high as the top of the inner tub
The water overflows the wash tub Water drains out during the wash or rinse cycle
  • Check the drain control lever
  • Test the drain control coils
  • Check the cam bar
  • Test the timer control
Wrong temperature of water is used
  • Water supply hoses may be reversed
  • Hot or cold water supply valve may be turned off
  • Water supply hose may be kinked
  • Check water inlet valve
Water drains out while it is filling
  • Check the drain hose, it should be at least as high as the top of the wash tub, about 38 inches.
  • The drain hose must sit loosely in the house drain. Do not seal the air gap around the drain hose or a siphon will occur.
  • Check the cam bar
Water drips into the wash tub when the washer is off Water does not drain out of the wash tub Water is leaking onto the ground
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
Agitator does not move Agitator movement is weak or moves in only one direction
  • Inspect the agitator
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the pump coupling
Drum does not spin
  • Test the lid switch
  • Test the centrifugal switch
  • Test the motor
Clothes are too wet after spin cycle This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
Spin:
  • Test the motor
Cycle does not advance
  • If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
  • If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
  • If the timer does not advance during the rinse cycle, check whether water has filled the tub, if not, it is likely cold water related. Check the cold water supply valve, check the supply hose for kinks, check the filter screen and check the water inlet valve
Burning or electrical smell
  • Unplug the washer
  • Locate the source of the odor then read the instructions in the related section
Foul or stale odor coming from washer or clothes
  • Check that the drain line is clear
  • Check the drain hose for kinks or blockages
  • Check pump for blockages
  • Check for build up of soap in the outer tub
  • Check for article of clothing stuck in the outer tub
Noisy or vibrates too much
  • General tips
  • Balance the load
  • Level the machine
  • Inspect the water pump for a blockage
  • Inspect the coupling
  • Inspect the transmission
  • Adjust the drive belt tension
  • Check the motor bearings
  • Check the drum brakes
Goes out of balance too often Clothing is damaged
  • Inspect agitator for cracks or rough spots
  • Inspect for rust spots
Jul 11, 2015 | Washing Machines
Machine not spinning dry
Top-loading washing machine has an outer tub that fills with water and sits stationary as well as an inner tub with holes in it. The inner tub has an agitator that attaches to the drive shaft. A drive belt turns the drive shaft, causing the agitator to move back and forth. Broken seals at the bottom of the agitator, or a broken belt, may cause the agitator to perform inefficiently and leave your clothes dirty
In order to properly wash clothes and prepare them for drying, a washer must agitate or spin the load. This helps wring excess water out of the clothing. If your washer has suddenly stopped spinning properly, you will notice that your clothes will be sopping wet when the washer is done. Typically, there is a simple reason for this problem that you can fix without calling in a professiona
1 Check the lid switch. You will notice on the lip of the lid there is a small stem that hangs down. This fits into a hole on the top of the washer housing and tells the washer the lid is closed and it is safe to spin the load. If the switch is faulty or has been blocked, the washer will not agitate or spin.
2 Clean out the switch receptacle. Use a multipurpose cleaner and a sponge (not a paper towel, it can shred and get caught in the switch receptacle.) Thoroughly clean the area around the switch and the receptacle.
3 Test the washer. Close the lid, allow the washer to fill with an inch of water, and move the selector to the spin cycle. Pull out on the selector. If it does not spin, stop the cycle (push the selector in) and turn the washing machine off. This means there could be three problems with the washer: the switch might be broken, something might be caught in the agitator, or the motor for the agitator may be burned out.
4 Check underneath the agitator. Small items such as underwear, panty hose or bra straps can become caught underneath the agitator and keep it from moving. Run your hand underneath this area and see if you feel anything. If you do, unwrap the item and test the washer again. If it still does not work, move to Step 5.
5 Contact a repair person. If the washer still will not agitate or spin, it will need to either have the switch replaced or the motor replaced. Contact a certified appliance repair person to have the machine inspected. If it is still under warranty, the repair person's visit should be covered.
However if its only the agitator arm, then
Instructions to Remove/replace the Agitator
1 Unplug the washer.
2 Slide a putty knife under each side of the washing machine top to release the springs holding the top in place. Lift up the top on its hinges.
3 Pull the tub clips from the inner tub using a pair of pliers.
4 Pull up on the agitator top to expose the nut holding it in place. Remove the nut using a socket wrench. Lift up on the agitator to remove it from the machine.
5 Turn the agitator upside down and remove the seals from the bottom. Replace them with a new set of seals. If the agitator is cracked, replace it.
6 Reassemble the washer.
Removing the Belt
7 Unplug the washer from the wall outlet.
8 Pull out on the bottom panel on the front of the machine. Look underneath to locate the drive belt.
9 Pull on the drive belt at the washer tub to remove it. Push down on the idler pulley near the motor to remove the belt from the machine. Route the new belt around the pulleys in the same way as before.
10 Reassemble the machine, plug it in and test.
Apr 20, 2012 | Whirlpool Washing Machines
Washer won't change gears from water fill to agitate
Hi and welcome to FidYa, I am Kelly,
If it does not agitate or spin suspect the lid switch. Listen for a microswitch click as the lid just opens or closes. No Click = bad lid switch.
If it spins then the lid switch is fine and there is a problem with the water level control pressure switch or possibly the control.
Since you did not include a model number this is my best guess for a 3.2 cu ft machine
MVWC300VW0
This lid switch is item 6 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5519632
The water level control switch is item 4 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5519632&diagram_id=28626536#d28626536
The timer item 7 of the above link can also cause this symptom. You must elimiate the water level control as a possible cause first. There is a FOLDED wiring diagram in the literature packet insde the top panel 3 x 5 envelope you can use to jumper the wires on the water level control switch. If the motor agitates then the water level switch is the problem. If it does not agitate it can be the timer or the motor. (More troubleshooting required via the wiring diagrams following power through the circuit to the motor.)
At this time I think you may just have a water level control switch problem. If you do end up replacing it... the wash tub must be empty or it will overflow when testing.
Thanks for choosing FixYa,
Kelly
Sep 15, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Beginning of wash cycle starts agitating instead of filling w/water.
the water pressure/level switch contacts are welded together,usually the load selector switch for the amount of water lets it fill to a determined water level and the water level creates pressure in a tube from the tub to this switch and stops water fill and starts the wash agitation cycle,replace this switch inside the control panel
Mar 19, 2011 | Whirlpool Washing Machines
Have a hotpoint top loading that A..would not stop filling even unplugged, and B. will not drain/spin. Hence, ended up with a flooded room while I was trying to get the water turned off. Any easy way to...
Hi
If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
When it doesnt spin or drain...
The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump.Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port.
Thanks for contacting fixya.com
Nov 02, 2009 | Washing Machines
My washing machine overflowed and would not drain. When it is on water keeps coming in even though the machine is full iof water but there is no movement of the agitator and I could not get it to...
H i there.....sounds like you've got either a failed water inlet valve....or a disconnected /ruptured capillary hose from the pressure switch to the tub....or a failed pressure switch........turn water to appliance off.....turn program selector to drain or drain /spin..is drain pump running...if not it may be blocked or burned out....or with machine empty of water.....turn program to spin....if no spin...check motor....
regards Sir Galahad
Aug 21, 2009 | Washing Machines
Washing machine overfills
Grab the tube off the water level switch that comes from the bottom of the tub and blow it out so that the sand in the bottom won't be blocking the operation,pump out the water, secure the tube tightly to the pressure switch and retry.aff8f03.jpg
Jun 10, 2009 | Washing Machines
Last cycle water will not emptying
Your pump is more than likely shot!
Defective Lid Switch
Check lid switch for proper operation. Check the switch for continuity. If it is found to be open, replace the switch assembly.
Defective Water Pump
If the motor is running and water is not pumping it could be a defective water pump. Ensure the tub to pump water hose is clear. If so, replace the pump.
Defective Motor
If the motor is not running, the pump will not work. Most washing machine use a reversible motor and it is possible for the machine to agitate and not spin or drain.
Please leave a goo rating
Dec 01, 2008 | Frigidaire ATF6000ES Front Load Washer
Won't empty water slow spin in spin cycle
Jul 15, 2008 | Maytag PAV2300 Top Load Washer
Frigidaire stackable will not stop filling with water or agitate.
yes unless pressure switch(water level switch)detects proper fill level wash will never start agitating some washer will not spin if switch does not detect empty tub
Jun 02, 2008 | Whirlpool LTE6234D Top Load Stacked...
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
