Question about Garden
Talon at3351 How to replace starter cord on talon 25cc petrol line trimmer model AT3351
moretons
  • 155 Answers
SOURCE: Homelite Mighty Lite Lawn Trimmer Magneto Air Gap setting 25cc
Normall setting is 10 thou but if there is no play in the crank bearings you can set at 8 thou
Posted on Jul 26, 2009
  • 420 Answers
SOURCE: adjusting the carburator on a craftsman 25cc line trimmer
Replace all of the lines before any adjustments, too small to see air leaks are a common cause the issue you have.
Posted on Mar 03, 2010
SOURCE: replace recoil starter for Homelite trimmer Model UT21546
My UT21546 has 2 springs, the regular recoil one and a what I'll call a anti kickback one. the top of the anti kickback spring kept coming unsecured and finally I just deleated it alltogther and screwed the 2 plates tightly togehter and the near new unit works better than new now.
Posted on May 26, 2010
bbap
  • 71 Answers
SOURCE: i have a 25cc homelite weed trimmer.... the fuel
You will need the correct size fuel line first. Follow this:
1. Remove the old filter/weight from the fuel tank.
2. Take a new fuel line piece about 8 inches long and cut about a 45 degree angle cut on one end.
3. Lightly moisten the cut end of the fuel line and insert it into the tank from the outside, pushing it in while turning as far as possible.
4. Use a needle nose plyers to reach in and pull the line to the fuel line cap. Cut the line and replace the filter.
5. Pull the line back the way you put it in leaving about 4 inches within the tank and re-attach to the carburetor or primer bulb (depending on the actual model/age)
It will work, but it is extreemly important to have the correct size fuel line to work with.
Posted on Sep 27, 2010
vincob
  • 718 Answers
SOURCE: I need to replace the
Try psep.biz or Talon website. I have never seen this name brand on this side of the pond. Good Luck... Cheers...
Posted on Apr 21, 2011
Where can I buy a pull start Spring for a Talon At3351
Hardware Store, or local mower repair shop.
Oct 13, 2014 | Garden
Talon at3351
Choke is an adjustment to air intake to adjust fuel/air mixture and is heat related. Do not fully open choke as soon as it starts. Gradually open as the trimmer warms up. If a happy medium can not be found then fuel adjustments will be needed on carburetor.
Jun 05, 2014 | Electronics - Others
Keeps cutting out
Possible cause: Never use gasoline unless it is properly mixed with 2-cycle engine lubricant. Permanent damage to engine will result, voiding manufacturer's warranty.
I had a trimmer that I put straight gas into and I couldn't keep it running.
Jun 05, 2014 | Garden
Just brought new mech choice 25cc petrol line trimmer put petrol with oilmix in ,follwed instructions cant get it to start why,did we miss something out in getting it to start
How did you mix the fuel? Best to make it up in a jerry can. Mix the fuel and oil in the can. It may well be flooded. Try starting with ignition on, choke open and full throttle, might take up to ten pulls.
Sep 26, 2013 | Craftsman 25cc Gas Line Trimmer
Yes, I have a Craftsman 25 cc Gas Trimmer and we just snapped the starter cord. Do you have to open up the head to fix this? Does it need a special type of cord?
Yes you have to remove the plastic recoil assembly and install a certain size cord. We use a #3 or 3.5 cord on all our string trimmers, blowers with that size engine.
Aug 09, 2011 | Craftsman 25cc Gas Line Trimmer
I NEED TO REPLACE THE STARTER CORD ON MY CRAFTSMAN GAS LEAF BLOWER MODEL NO. 358-797180
Try Sears...They sell/have appl. parts. You'll be amazed at what they have.
Apr 21, 2011 | Craftsman 25cc Gas Line Trimmer
Need ratio for craftsman gas line trimmer
i think the mixture is 50:1 50 petrol and 1 oil
Jul 21, 2010 | Craftsman 25cc Gas Line Trimmer
The starter line on my trimmer will not pull at all.
Remove spark plug to see if problem is in engine or drive unit
May 20, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
153 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
