Question about Miele 23 in. KM360G Gas Cooktop
1993 chevy S10 no spark from coil
1993 S10 has no park fron the coil. changed everything except distributor
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 117 Answers
Are we talking motor cars or Miele cooktops?
Posted on Jun 11, 2014
Smeg mod nu.sar93xlpg gas cooktop is 20 years old and in good condition The gas igniter recently has been sparking once every 5 mins. works fine except one spark every 5 minutes,any ideas
probably find that after so long the igniter is starting to fail
call smeg and see if there is a replacement one available
there may be after market units from your local gas shop
Jun 25, 2016 | Smeg Cooktops
2 of 5 burners do not start
The spark gap needs to have flow of gas across it for ignition to occur. The gas outlet holes at the point where the igniter sparks may be blocked, clean and inspect these for any blockages. Also check that the igniter spike is in the correct place. Careful evaluation of the position of the igniter in reference to the gas ring on the other rings may help you here. Good luck
Feb 02, 2008 | DCS CT-365 Gas Cooktop
95 dodge colt 1.5ltr.engine it has no spark to the distributor,replaced dis. with new one still no spark
Make sure that you have spark coming from the coil to center of distributer. Distributer gets its spark from the coil.
May 23, 2014 | Miele 23 in. KM360G Gas Cooktop
I have 250 chainsaw change coil an plug wires not corroded still on fire what can i do next.
Check to make sure the ground wire going to the on/off switch is not grounding out anywhere. If that wire is making contact with the metal case it will stop it from creating a spark
Mar 17, 2014 | Miele 23 in. KM360G Gas Cooktop
Maytag/Jenn Air JGD8130ADS one burner will not ignite but all others will. solutions?
Turn off gas. Remove the cartridge and remove back cover. Clean the ignition spark area. Re-install the cartridge without the back cover. Try to ignite the spark. If the spark works. The spark wire is too close to the back cover. Use an electrical tape to insulate the wire from the back cover. Other swap the two spark to see if you have a faulty spark.
Jan 02, 2012 | Maytag JGD8130ADS 30 in. Gas Cooktop
My whirlpool gas cooktop on sparks on left front burner. Model scs3014gq1
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Apr 01, 2010 | Whirlpool SCS3014 Gas Cooktop
Spark ignitors on ge jgp636 either don't work or lght wrong burnr
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Dec 19, 2009 | GE Profile JGP636 Gas Cooktop
Jenn Air Gas cooktop burner ignition
Hi JHMcdona
Most likely the electrode for the right burner is defective. As well as the switch may also be defective (is shorted because of pressing hard on it trying to make it work!!). Change the electrode and igniter switch of the right front burner.
Regards
Aug 26, 2009 | Miele 35 in. KM326G Gas Cooktop
Electric shock
Hello butterfly777,
Remove all traces of foil ( with power off) and make sure the coil is fully seated into the electrical terminal block.. these are typically just pushed in to seat them.. Run the heater up to full power and let it stay there for 10-15 minutes.. if you don't see any problems with it... in all probability its ok.. and can be run that way..
I am speculating on what may have happend... perhaps a piece of foil flashed on you and sparked a little.. foil is electrically conductive but the coil element itself is grounded externally so if it doesn't spark after it is run up during your test.. it should be ok.. If you are uncompfortable or feel it poses a threat..get a replacement heating element...
Hope that helps..
Regards,
Rick
Nov 29, 2008 | Cooktops
Miele 23 in. KM360G Gas Cooktop Logo
83 people viewed this question
Top Miele Cooktops Experts
Dan Webster
Dan Webster
Are you a Miele Cooktop Expert? Answer questions, earn points and help others
