Question about Epson Stylus NX400 InkJet Printer
How to change the cartridge
How to move the cartridge home to the middle
    Problem Solver:
  • 6 Answers
Turn off the printer power supply, in some printer wen power is off the cardridge head becomes free and it can be moved.
Posted on Mar 29, 2014
Lights do not come on to show which cartridge needs changing
The MP640 uses the PGI520 and CLI521 cartridges.
When you lift the top and the carrage moves to the middle all full cartridges should be lit up. If the light is off on any/all cartridges it means they are empty. If the light is flashing it means it is running low.
Each cartridge has a clip on the back of the cartridge. Push this clip towards the cartridge and it releases the cartridge for replacement.
Oct 09, 2014 | Canon Pixma MP640 All-In-One InkJet...
Ink holder will not stop in middle to change ink
Hi, normally when changing ink cartridge, once you open the cover the printer head move from home to the center of the printer and halted,if in case this not happen something wrong with the sensor, if the printer move from home to center just pull off the power cord to stop the printer at the middle or nearly at the middle just to remove the cartridge and replace it. Upon replacing the ink cartridge, just power on the printer and it will return home to its position.
Jun 17, 2011 | Office Equipment & Supplies
Will not print. says code 2200 just replaced black carterage
Power off the All-In-One (AIO) off and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved. 2
Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover and check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Contacting Lexmark.
No: Continue to step 3. 3
Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No: Repeat step 3 and install the black / photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved. 4
Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black / photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black / photo cartridge. If the printer fails again, continue toContacting Lexmark.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved. the 2200 error is a scanner error means the scanner motor failed to initialize. lexmark recommends that you unplug the unit remove the power supply wait a couple of minute reinstall the p/s and power the unit back up. step to is repeat step one but us the belt to move the scanner carriage to the middle and power it up.
on top of this i would inspect the guide bars for dirt build up and clean them if need be. one thing to consider the ccd knows that it has reached home by the reflecting of the light to the carriage home photo cell within the scanner itself. this light is reeflected back off of the mirrors inside of the ccd. dust on these mirrirs will prevent the photo cell from nowing where home is. these can be cleaned with q-tips
plz rate the solution
Nov 02, 2010 | Lexmark X7170 All-In-One InkJet Printer
I am out of several of the color inks, but the Canon says "Check Printer" and the cartridge won't move to the middle so that I can change the ink.
If you are gentle you can manually move the print head to the middle by hand. You don;t want to force it or push very hard. There will be a bit of resistance but it should just move smoothly. You may find it works when the printer is unplugged.
When you power it back up after changing the cartridges it will return to the side and print normally.
Apr 21, 2010 | Canon MultiPASS F50 All-In-One InkJet...
Epson sx 200 printer cannot change ink cartridge
Ive just pressed the 'stop' button on mine and it moved the cartridge to show which ink needed replacing and then when pressed again it moved to the replacement gap
Mar 24, 2009 | Epson Stylus CX3200 All-In-One InkJet...
WRONG CARTRIDGE and Printhead does not move MP780
your printer ink cartridge can not access (move to middle) when you open up the cover, you may try
1) try to open right side cover you move the cartridge by hand (power off) to middle position, then take out the cartridge and reinstall it then power on, the cartridge moving right, you may open up the cover again if the cartridge go back the middle position which means your printer works normal. still stop moving go next
2) check the cartridge initcial sensor at righe side, the cartridge moving to the end of right should be touch this sensor, find out it and check there is good touch (click) by the cartridge body. adjust the sensor position maybe needed.
3) cartridge is stucked sometime also check the cartridge moving rail hard moving, need to drop oil to lubricate.
Feb 07, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Out of ink. Can't get cartridge to stop in middle to change
hi turn off the printer open lid move cartridge carrier to the middle, this should allow you to change the cartridge, then close the lid and turn on printer this should reset carrier to home position.
Jan 15, 2009 | HP DeskJet 810c InkJet Printer
Can't install the ink cartridge
To get your cartridge installed, first turn your printer off. Open the lid like you normally do to change it. You can physically pull the cartridge carrier to the middle to change it. It will not hurt anything. Just be sure your printer is powered off. You see when it is on, the software keeps track of what character position the printer head is in. Like when you tried to stop it from printing it went to the left or home position because the printer software detected that it was not moving and printing in the right positions of whatever it was that you were printing. So good luck and God bless you. Once you power the printer back up after changing the cartridge everything will work and position itself just fine.
Jan 08, 2009 | Dell 942 All-In-One InkJet Printer
Epson Stylus NX400 InkJet Printer Logo
22 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
