Question about TruTech PVS31170S1W 17 in. LCD Television
PLV 31199S1 DVD says INVALID region! have not moved! why?
When I insert a disc, message on screen comes up INVALID REGION. It was working, I have not moved, cannot figure out what to do.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 197 Answers
Factory reset the screen
Posted on Mar 29, 2014
  • Barbara
    Barbara Mar 29, 2014
    How does one reset the screen?
4 Suggested Answers
  • 57 Answers
SOURCE: When I insert a dvd it says no disc
DVD need replesment of optical lens,then its ok
Posted on Jul 09, 2009
  • 178 Answers
SOURCE: The DVD player will not play anything. It says
Ok, this interesting. I don’t see this much. The region is a code that is set in the dvd player to limit the unit to playing dvd's for a specific country. It is a copyright protection that is built into a dvd player. USA is regon 1. DVD's can be made without region codes and these dvd's will play on and dvd player.
So to answer your question: Either the tv was bought in a foreign country, or the dvd's were bought in a foreign country.
Posted on Oct 10, 2009
  • 178 Answers
SOURCE: I have been playing DVDs for the last two years on
You were the one to post the question little earlier. A region error is a strange error to get for a malfunction. But in any case it will be a fault with the decoder board / laser in the dvd player. These usually don't have firmware updates and are rom based so re-programming is not an option. The region error may also be cloaking the real problem. The more likely problem is that the dvd's laser pickup has failed. The first thing it tries to get is the region code, so if it cannot read this maybe that is why it is throwing you this error. Try to clean the lens, i don’t give that much hope but it is the only remedy other than repair that i can offer.
I have a Philips BDP2100/05 blu ray dvd player. I have put a dvd in to playand on the screen appears "Invalid Region." how ca I fix this?
You can make the Player to play all-region DVDs [not Blu-ray discs]. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Procedure to make it region-free to many DVD brands are given.
Sep 12, 2014 | Philips Televison & Video
Invalid region When I put a disc in, I get this
This means that the region code on the disk (which determines where it may be played) does not match up with the region of your DVD drive.
Normally the region code can be changed, but only a limited number of times.
Try to make that if you buy a DVD online, it has the correct region code for your player
This may help https://images-eu.ssl-images-amazon.com/images/G/02/help/dvd-regions-mapv2-465x286.gif
Oct 22, 2013 | Televison & Video
Is it possible to change the region code to region 3 so we can watch movies from Thailand? No need to switch back as I have another DVD on region 1. Charlie (cleggett1937@aol.com)
You can make this player REGION FREE so all discs operate on it.
Power up, no disk in. Status says READ then INSERT DISC.
Press MENU (status reads invalid key icon)
Press 1 (status reads invalid key icon)
Press 9 Menu is displayed.
Press ENTER on the region, digit turns to "-"
Press 0
Press ENTER again
Press EJECT to clear the special menu.
If you reset (unplug) the player for any reason - this will need to be re-entered.
Thanks for using FixYa!!
Mar 18, 2010 | Cyberhome CH-DVD 300 DVD Player
My durabrand sts98rw displays invalid region
If you go into your factory settings setup screen check there for what region its set to and if it is possible to change it, change to the correct one.
Mar 10, 2009 | Televison & Video
DVD recorder model DBRH 197 will not play zone 1 DVDs, is there a solution for this.
1. Power on
2. Open DVD tray
3. Press HOME
4. Select/choose SETUP
5. Use arrows to move to LOCK icon
6. Press 0000000 (press the number 0 (zero) seven (7) times)
- You get the REGION FREE message
8. Confirm OK
OR
Insert a non compatible dvd disc, when the dvd player spits it out again press 0 seven times and the dvd player will congratulate you on making it regionfree.
Aug 08, 2008 | LG Televison & Video
Can u please tell me the code to unlock a matsui dvd 3307 player for playong region 1 ta
Switch on with no disk.
Open the draw
Enter 7777 on the remote (ignore the invalid entry message that comes up on the screen as you do this)
A menu will appear allowing you to switch regions
Jul 12, 2008 | Televison & Video
Disc region incorrect
Press 0
Press ENTER again
PS If you're gagging to get at this and the remote doesn't work, pull out the tab that isolates the supplied button cell in the remote control :-)
Region 1 NTSC
Region 2 PAL
Region 3 NTSC
good luck
please mark the post with a fixya!
Jan 15, 2008 | Cyberhome CH-DVD 300 DVD Player
Unlock LG DVD
The following hack worked for my player. It works for most LG and Aiwa players too. To hack the player try this:
  • Power on player with no disc inserted and wait for "No Disc" message on screen
  • (using the remote) Press PAUSE
  • Press the numbers 314159 in order. (player should now show "COdE - -" the same as below)
  • Press the number of the region you desire ( 0 = any region, 1 = US&Canada etc.)
  • Press PAUSE
  • Power off the player for a few seconds..power back up and insert your DVD disc
Jan 08, 2008 | LG Televison & Video
TruTech PVS31170S1W 17 in. LCD Television Logo
Top TruTech Televison & Video Experts
Radames Pagan
Radames Pagan
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
