Question about Visual Land Prestige 7 ME-107-8GB 7" 8 GB Tablet Computer - Wi-Fi ARM
Got it months ago, never got it on wifi. just got wi-fi paword, but after charging battery, i'm unable to recall the touch pattern. Also, tried to reset but afraid to stick anything in the reset hole.
IT'S a pattern of 9 points, sort of a Connect-the-dots. Every "pattern" that comes to me has failed. Only music was downloaded into it, so i'm ok w/"losing my data" & start again.
  • 210 Answers
Use a safety pin or needle press till you feel the button is pressen down and hold for a few seconds ..some devices require you power them on whilst holding this down check your manual for instructions
watch this on how to do it , and leave a rating if it works pls
Visual Land Inc
http://www.visual-land.com/manuals.html
your manual should be availble on their .
Posted on Mar 29, 2014
How do I stop continually trying to connect to wifi and failing
Unable to Connect to wifi problem - Solved for me ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Jun 7, 2012 - I tried the "forget the connection" workaround but it always came back. ... recognizing and joining the wireless network, but are not connecting ... Ipad won't connect to wifi after update iOS 7.0.6
Mar 1, 2014
New iPhone 5s - constant "Incorrect WiFi" password
Nov 25, 2013
Wifi ISP keeps failing
Sep 10, 2013
New Macbook Air - wifi connectivity problems
Jun 13, 2013
More results from discussions.apple.com
How to fix limited or no connectivity Wi-Fi issues in Windows 8
www.fixedbyvonnie.com/.../how-to-fix-limited-or-no-connectivity-wi-fi...
The connection is limited ... He couldn't connect to Wi-fi on battery power. ..... Will this work if we have limited connectivity when trying to connect through a LAN cable? .... I found another solution, If you are running Windows 8 and your laptop keepsdropping the WiFi .... Investigate router or access point issues Failed
Dec 28, 2015 | Tablets & eReaders
Wifi will not turn on, I press wifi on and turns off. I did a reset twice. How do I fix it?
It comes on but all it shows is tablet pc, it will not show any of the apps.at all. I want to know is what is wrong with it? The battery is charged.
Nov 10, 2015 | ZEEPAD 7DRK Dual Core 4.2 Red Android...
9" Inch Google Android 4.2.2 Allwinner A23 Tablet PC Dual Core WiFi 8GB UK how do i connect to my television?
You can try this and see if it works for you:
Connect to Wi-Fi networks Some of this information applies only to devices running Android 5.0 and higher. If your device is running 4.4 or lower, the Menu icon looks like this 01640868e1517a345806b8352772a19a6aa8. If your device is running 4.3 or lower, the Settings icon looks like this snp_2918920_en_v1.
You can connect to Wi-Fi networks with your device, as well as add networks you use often or remove networks you don't use any longer. You can also change the settings for saved Wi-Fi networks on your device.
Keep in mind that your device will remember networks you connect to, along with security details, and connect automatically when in range.
Turn on Wi-Fi and connect to a network
  1. Open your device's Settings menu snp_bee8810a5fcd80173673b4b15a1804eaee99_3529219_en_v0.
  2. Under "Wireless & networks," touch Wi-Fi.
  3. Touch the Wi-Fi switch to turn it to the On position.
  4. You'll see a list of saved and available networks.
    • Secured networks display a lock icon 9708aea66a4ca95cd2dda6f363c600366de9 and ask for a password to connect.
    • Your device will remember networks it connects to and automatically connect to them when in range.
    • You can forget a saved Wi-Fi network if you don't want your device to connect to it automatically.
  5. Touch a network name from the list of available networks to connect to it.
    • Android 5.0 or higher: If the saved network you want to connect to isn't showing up in the list of networks on your screen, touch the Menu icon e0c84b16c85d9e9f1f5eb1d0111d3421b872 in the top right corner of the screen. Touch Refresh to reload the list of networks. Touch Add network and enter the network's name (SSID) and other security details, if needed. Then touch Save.
  6. Once connected, your device will say "Connected" under the network name.
Once you've connected to a network, it will show up in your Saved networks list. If you have trouble connecting to Wi-Fi, try the following steps:
Nov 11, 2014 | Tablets & eReaders
With iPad must I join an internet even tho it is connected to my desktop usb?
Simply go to Settings-second down on the left menu, choose Wi-Fi and on the right menu, your home (or wherever you are) wi-fi connection should appear by name. Then simply touch the one you want to connect to. You should see the choice you made on the left menu next to the word Wi-Fi. I only connect my iPad to my computer to charge it occasionally via USB.
Sep 20, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Will not connect to wifi
  • Touch the Apps Menu button on the Home screen.
  • Open the Settings app.
  • Choose Wireless & Networks.
  • Choose Wi-Fi Settings.
  • Ensure that Wi-Fi is on.
    When you see a green check mark next to the Wi-Fi option, Wi-Fi is on.
  • Choose a wireless network from the list.
    Available Wi-Fi networks appear at the bottom of the screen. When no wireless networks are listed, you're sort of out of luck regarding wireless access from your current location.
    Optionally, type the network password.
    Touch the Password text box to see the onscreen keyboard.
    Touch the Show Password check box so that you can see what you're typing; some of those network passwords can be long.
    Touch the Connect button.
    You should be immediately connected to the network. If not, try the password again.
  • May 12, 2013 | Samsung Galaxy Tab Tablet PC
    Too many pattern attempts to unlock my iview 754tpc but my wi-fi was switched off so how do i sign back in
    only by putting a sim card with a active data connection in the device then attempt to unlock, you can not remotely turn on wifi very easily, may be a bit more simple if you have debug mode turned on but most people don't-Good Luck.
    Jan 27, 2013 | Iview 754TPC with WiFI 7" Dual Camera,...
    I cant get my tablet to connect to wifi
    Android tablets, unlike Android phones, don't require mobile phone service or a contract with a mobile phone company, and several models use Wi-Fi for network connectivity. The Android 3.0 operating system, known as Honeycomb, is designed specifically for tablets, and has the same features for Wi-Fi connections that are available with earlier versions of Android. Android tablets support wireless connections encrypted by both WEP and the more-secure WPA.
    Tap the "Apps" menu on the tablet screen. Touch "Settings." Touch "Wireless and Networks" and select "Wi-Fi Settings." Tap the "Wi-Fi" box to turn on Wi-Fi. The Android tablet scans for available Wi-Fi networks and displays them on-screen under "Wi-Fi Networks." Tap an available Wi-Fi network. Touch "Connect" if it is unsecured, or enter the password or passcode for the encrypted connection.
    Tap "Connect."
    Jan 14, 2013 | Polaroid 7 in. Internet Tablet
    Visual Land Prestige 7 ME-107-8GB 7" 8 GB Tablet Computer - Wi-Fi ARM Logo
    78 people viewed this question
    Top Visual Land Tablets & eReaders Experts
    Steve Mason
    alex metro
    alex metro
    Lawrence Oravetz
    Are you a Visual Land Tablet and eReader Expert? Answer questions, earn points and help others
