Question about Kodak Cameras
Hoe do I reset a sdhc ard for kodak easy share M552 digital camera
My easy share camera keep saying memory card needs to be unlocked
  • Kodak Master
  • 5,389 Answers
All SD cards have a write protection switch on the side opposite the little notch near the contacts; that's the left side. Remove the card from the camera and look at the card. Move the switch towards the contacts if it is in the locked position. Replace the card in the camera without moving the switch. Check if it works now.
Check if the switch moves very easily when you toggle it. (If you don't see the switch at all, the card is damaged.) Plan on replacing the card. There are ways to temporarily unlock the card. That involves cutting any remaining plastic from the switch. Then wrap the switch area with a small piece of invisible (Scotch) tape. Make sure that the tape is completely flat against the top and bottom of the SD card around that slot. Do not cover the contacts on the end with the tape.
One additional thing to try: backup the files on the card. Then try to format the card (with the switch in the unlocked position).
I hope this helps.
Posted on Mar 29, 2014
  • 34 Answers
SOURCE: new memory card and the camera says its full
The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
Check the installed firmware and try a firmware upgrade. Maybe the supporting now the 2 GB memory cards.
Why download firmware version 1.07?
This firmware version improves memory card compatibility and provides general performance updates.
KODAK EASYSHARE C330 Zoom Digital Camera Firmware
Posted on Jun 08, 2009
  • 34 Answers
SOURCE: 4gb sandisk sdhc card
I think the C330 is not compatible with the SDHC cards.
Click
But try an firmware upgrade.
Posted on Jun 09, 2009
taran_2005
  • 10515 Answers
SOURCE: will Kodak Easy Share DX 6340 support SDHC 4GB
It does support SDHC 4GB memory card.If you wish to purchase, you can go to ebay and purchase the one for you.There are so many brands to select from like Kingston, Panasonic etc.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 15, 2009
Testimonial: "Thanks very useful info and so quickly answered. Eric Harrold"
SOURCE: I have a Kodak Easy Share C310. It keeps saying
"internal memory card is full" There is no more space in the camera's internal memory. Your camera has 16 MB of internal memory. The number of pictures you can store depends on the Picture Size setting you have selected on your camera.The following are approximate number of pictures you can take at each setting: 4.0 MP: 16 pictures 3.1 MP: 18 pictures 2.8 MP: 20 pictures 2.1 MP: 29 pictures 1.1 MP: 48 pictures Internal Memory?the camera always uses internal memory, even if a card is installed. Auto (default)?the camera uses the card if one is in the camera. If not, the camera uses internal memory Image Storage Choose a storage location for pictures and videos. To correct the issue your getting follow this steps: 1.Press the Menu button. 2.Press to highlight the setting you wish to change, then press the OK button. - The settings you need to look for is Image Storage 3.Choose an option, then press the OK button. - The option you need to choose is Auto the camera uses the card if one is in the camera. 4.Press the Menu button to exit.
Posted on Nov 18, 2009
  • 11967 Answers
SOURCE: I have a kodak digital easy share cd33 camera,
1. With no card in the camera, go into the menu and find "reset"....follow the on-screen instructions. 2. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. 3. Insert card, go into the menu and do the "format" thing again. Be sure to download any pics from the card first.
Posted on Feb 27, 2010
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
WHAT DO I DO WHEN THE MEMORY CARD SAYS FULL I HAVE A Z885 KODAK EASY SHARE
What type and size memory card? The Z885 works with MMC and SD cards. It won't work with higher-capacity SDHC cards.
Jan 17, 2013 | Kodak EasyShare Z885 Digital Camera
I have a Kodak Z990 easy share camera and memory card is protected came up and said reset switch on memory card. How do I reset memory card
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 06, 2012 | Kodak Easyshare Max Z990 12mp 30x...
Says to reset switch on memory card kodak easy share dx4530.how?
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jul 06, 2011 | Kodak EasyShare DX4530 Digital Camera
I have a kodak easy share C315 the message keeps telling me to reformat the memory card, I say ok and then it gives me an error. I tried to reformat in the computer but I don;t know how. The memory card is...
Maybe it is having trouble with the size of the memory. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards. It is often difficult to find out the maximum capacity a camera will use, as today's memory cards are much larger that those available when the manual for the camera was written.
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible. If the card you are trying to format is above 2GB, it will be an SDHC card.
Nov 30, 2010 | Kodak EasyShare C315 Digital Camera
Just purchased new Toshiba SDHC 8 GB memory card to use in Kodak Easy Share C743 digital camera. Put disk in camera prompt says "Memory Card requires formatting"...press continue, and go to formatting and...
No. Can you get into the camera menu when you turn the camera on? If so, go to "format" by way of the menu rather than clicking on continue. Also, be sure the slide switch on the side of the card is in the unlocked position.
Sep 01, 2010 | Kodak EasyShare V550 Digital Camera
When camera is turned on it says memory card is
If you're using an SD card, it doesn't have a reset switch. It does have a switch to lock (protect) and unlock the card. It should be in the unlocked position.
Jul 21, 2010 | Kodak Easyshare C813 Digital Camera
How do i format a kodak memory card 4 gb sdhc for my kodak easy share z612
Unfortunately. you don't. The Z612 works with SD cards, not SDHC cards. You're limited to cards 2GB and smaller.
Jun 14, 2010 | Kodak EasyShare Z612 Digital Camera
Cameras Logo
29 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
