Question about Whirlpool WED6200S Electric Dryer
No heat on whirlpool dryer
No heat but have power
    Problem Solver:
  • 21 Answers
Should also tryif you have a old house with fuses sometimes you only blow a partial fuse your dryer might run but not turn the element on for the heat
Posted on Apr 06, 2014
The dryer still runs and the drum is turning. No heat. Yesterday I did notice the outside of the dryer got very hot for a while.
The thermal cut-off has blown open due to the high-limit thermostat failure to cycle off in order to regulate the heating element temperature as the noticed extreme dryer temperature indicates. These two components are wired in series with the heating element as a safety measure to cut power to the element should the dryer temperature go extremely high like your case.
Disconnect power then make sure the lint filter is clear, the vent system is not restricted, and the inside of the cabinet is clean. A vacuum cleaner may be used to extract lint built up inside the dryer cabinet particularly the bottom. Replacing both the thermal cut-off and the high-limit thermostat is a must but only after the all areas mentioned are cleaned.
Click on the links below for more troubleshooting and repair details.
Whirlpool and Whirlpool-made Electric Dryers (With Removable Back Panel) Not Heating
Whirlpool and Whirlpool-made Electric Dryers (Without Removable Back Panel) Not Heating
Jun 19, 2011 | Dryers
MY DRYER WON'T HEAT.
This is usually caused by a blown thermal cut-off which blows and cuts power to the heating element due to the failure of the high limit-thermostat to cycle off and regulate the heating element temperature. Check the dryer for clogged lint screen and/or restricted vent system then replace both thermostats when either of them has failed. Both are located on the blower housing.
Click on the links below for the detailed troubleshooting of this dryer problem. Just follow the instructions that are applicable to your dryer since you did not specify the dryer's exact model number.
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (Filter on Top with Removable Back Panel) Running But Not Heating
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (With Bottom Panel) Running But Not Heating
Jun 17, 2011 | Whirlpool Dryers
Whirlpool AWZ7303 condensing tumble dryer . Drum not turning although it is heating
If your Whirlpool dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers, thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F. Thankfully, troubleshooting the thermal fuse in a Whirlpool dryer is easier than it sounds. Instructions:
  • Clean out the lint screen in your Whirlpool clothes dryer. Lint buildup can cause your dryer to overheat, triggering the thermal fuse to disrupt power to your dryer's heating mechanisms. Take the lint screen out of your Whirlpool dryer and wash it in warm water. Dry the screen thoroughly before replacing it.
  • Look behind the dryer to check its flexible exhaust hose for kinks or obstructions. Disconnect the exhaust hose from the back of your dryer and clean out any lint that has built up.
  • Go outside and check your Whirlpool dryer's exhaust vent for obstructions. Lint buildup, bird nests or other obstructions in the outside exhaust vent can trigger your dryer's thermal fuse.
  • Disconnect your dryer from its power source before attempting to access its thermal fuse.
  • Access the thermal fuse in your Whirlpool dryer by removing the back panel. Remove the screws that hold the back panel in place and it should easily come free.
  • Look between the dryer's blower housing and exhaust to locate its thermal fuse. The thermal fuse in a Whirlpool dryer looks like a white plastic strip that has two wires connected to it.
  • Bypass the thermal fuse in your Whirlpool dryer while you perform a quick diagnostic test. Use electrical tape to tape together the two wires connected to the thermal fuse. Reassemble your dryer and plug it back in. Set the dryer to a timed heated drying cycle and press "Start." If the dryer produces heat with its thermal fuse bypassed, it means the thermal fuse needs to be replaced.
  • Replace a blown thermal fuse in your Whirlpool dryer. Disconnect the power and remove the back panel. Remove the electrical tape that you used to perform the diagnostic test and disconnect the wires from the thermal fuse. Remove the screws that secure the thermal fuse to the dryer and discard the blown fuse. Attach the replacement thermal fuse by replacing and tightening the screws. Attach the wires to the new thermal fuse.
  • Apr 20, 2011 | Whirlpool AWZ7303 Electric Dryer
    My whirlpool leb 6000 pqo will not heat
    check heating coils, high limit, temp selector switch.
    Apr 05, 2011 | Whirlpool Dryers
    Heat cycle stops/goes off
    1. Changing from 3 to 4 wire hookup on a electric dryer
    2. Door switch replacement help for a common door switch
    3. Dryer basics - Venting problems and power supply
    4. Dryer basics - timers and how they work
    5. Dryer basics - power cord problems
    6. Dryer basics - dead dryer
    7. Dryer *general* repair flow chart....Click here
    8. Gas dryer smell
    9. How do dryer thermostats work?
    10. How long can my dryer vent be in length?
    11. How to change a common rear drum seal
    12. How the belt is suppose to look at the motor and idler pulley
    13. Help on replacing dryer motor and some wiring tips for the 279827 motor
    14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
    15. Help for storing an appliance
    16. Important Disclaimer
    17. I dropped something down the lint filter area....help!
    18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
    19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
    20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
    21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
    22. Inglis, Whirlpool and Kenmore electric element changing procedures
    23. Inglis, Whirlpool and Kenmore dryers - air flow
    24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
    25. Inglis, Whirlpool and Kenmore style dryers - belt change
    26. Inglis, Whirlpool and Kenmore dryer general motor problems
    27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
    28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
    29. If your drum belt looks like either of these....change it!!
    30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
    32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
    33. Pilot flame help
    34. Sample wiring diagrams
    35. Test for ohm meter checking on electric dryers with no heat
    36. Taking apart an Duet or HE3 dryer for a belt change
    37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
    38. Timers and some common Auto dry troubles and solutions
    39. What is a grounded element?
    40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
    May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
    Heat element
    if your dryer isn't heating, it's possible that your heating element needs to be replaced.
    are either of these pictures of your dryer?
    Whirlpool dryer 1
    whirlpool dryer 2
    May 15, 2009 | Whirlpool WED5521SQ Electric Dryer
    Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
    8. Gas dryer smell
    19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
    Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
    Whirlpool LER7646E dryer is not heating
    Mounted on the element is 2 limits. If either is open their will be no heat. NOTE: both need to be replaced and they come in a kit:
    Dec 15, 2008 | Whirlpool LER7646E Dryer
    Whirlpool Dryer not heating
    This can be due to malfunctioning of any of these 4 devices..
    1)Heating element
    2)Thermal fuse
    3)Thermostat
    4)Timer motor
    For more info and troubleshooting checkout this link..
    http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
    Oct 22, 2007 | Whirlpool LER4634J Electric Dryer
    Whirlpool WED6200S Electric Dryer Logo
    50 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal DeAngelo
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
