Question about Nokia Cell Phones
Hi How do I remove back seat from 1991 V8 Toyota Soarer
I want to change the fuel pump
    Master:
  • 435 Answers
If you can't tell by looking, I'd suggest you order a repair manual for it, like a Chilton's manual. Something I used to do when I didn't know how to take something apart, was I went to the local U-pull it yard and found one similar to mine and took it apart. You learn the do's and don'ts fairly quickly, without damaging yours.
Posted on Mar 29, 2014
Toyota soarer twin turbo 1991 model running rough any ideas as to what may be causing my car to play up like this?
Hi Chris:
I'd start with standard maintenance procedures:
- Air Filter
- Spark plugs
- Fuel delivery system clean.
Depending on milage and maintenance history, a 1991 engine will be starting to display signs of age. Valves, timing linkages, rings, etc. age creeps up on them. "Rough" is usually associated with mis-firing. That leads it spark and fuel as the primary check, and then compression as the secondary diagnostic that I would be looking at.
Hope this helps.
Jun 22, 2015 | Toyota Cars & Trucks
Where is the fuel pump relay located?
Hi
It is located on the top of the fuel tank. I do think you can access it from the top (for example on the Toyota Corona you can remove the back seat and lift the tank lid). I understand you have to lower the tank. Check this out first before you start dismantling, maybe you can google and get workshop manual page.
Best of luck
Jacko from down under.
Oct 13, 2014 | 1991 Mazda MX-6
1991 honda civic fuel pump replacement
You will need to remove the back seats and you will see the fuel pump in between the back seats and trunk. Run the car, remove the fuel pump fuse to relieve the pressure and then the car will die. Remove the pipes to the fuel pump, replace it and refit the pipes. Pump the gas pedal a few times and start it up (remember the fuse!)
If it is inside the tank (the fuel pump), then you will see the tank is held on by straps. Take them off, have ajack under it and remove the filler neck and screws holding it to the car. Remove the tank, undo the central bit where wires and pipes come out and slide the fuel pump out, replace what you have just done and refit.
Hope this helps, please vote :)
Jul 28, 2010 | 1991 Honda Civic
I want to know where is located the fuel pump .toyota camry 1991
THE FUEL PUMP ON A TOYOTA CAMARY IS LOCATED IN THE TANK. IF YOU REMOVE THE LOWER SECTION OF THE BACK SEAT THERE IS A COVER ON THE FLOOR REMOVE THE BOLTS AND YOU CAN SERVICE THE FUEL PUMP THAT WAY, GOOD LUCK HOPE THIS HELPS.
Nov 26, 2009 | 1991 Toyota Camry
How do i access the fuel pump in a 1991 volvo 940T where is the tank located. Mike
The fuel pump is located in the fuel tank beneath the back seat which you can reach by removing the back seat.
Cheers.
Sep 06, 2009 | 1991 Volvo 940
Where is the pump located i was told under the back seat but also in the corner of the tank and i need to drop it to change the pump help me
Its physically inside of the fuel tank. You must remove the back seats to get to the little plate that has three screws and take that off to get to it.
Thanks.
Jul 02, 2009 | 1991 Acura Integra Hatchback
Will not idle
fuel pump is in the tank. first get a spark tester and see if there is spark.if there is ,get fuel spray into the throttle body and see if it starts then dies.that would mean a fuel problem.sometimes banging on the tank gets the pump working again.take the cap off and have a look inside.
May 23, 2009 | 1991 Toyota Camry
Cell Phones Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
