Question about Plumbing
Pentax smart head malfunction
The failed light blinking when the taps are closed and pump goes into failure. When it is reset the pump comes on and runs straight to fail mode again. Any advice?
3 Suggested Answers
SOURCE: pentax smart head loosing
hi i have a pentax water pump the smart head, it works very good .one day the pump did not come on when i turn the pipe on so i take off the switch i put it back on the pump came on water was flowing as normal when time to turn the pipe off the pump will not cut off so i switch it back off and call an electrician he check it and he said i need to change the circuit board in the pump so he did now the started to work only on the lower pipe but it takeing long to come on and cut off.the upper pipe when turn on the pump not coming on i open all the union to bleed make sure on air in the line but still having the same problem can this be the head it self need changing?
Posted on Jul 10, 2011
dr_lopez3s
SOURCE: My pentax water pump has
yes, buy a better pump that is not smart
Posted on Sep 26, 2012
2005 2KD Hiace, starts lazy,revs good when it starts but accelerator goes dead, check light comes on, then in about 2 minuets the engine dies. 093 code.
fault code is missing a letter and first number
so its P0093 large fuel leak
the fault list has list of what to check
http://www.obd-codes.com/p0093
Fuel injector failure, Fuel line common rail leak, Fuel pressure sensor malfunction
Fuel pump or lift pump failure, Fuel heater constantly on Fuel temperature sensor failure ,
Leaks at any point in the high pressure circuit Electrical connector corrosion or seating problems
Fuel pressure regulator malfunction Fuel filter plugged dropping the fuel line volume Injector pump leak
Fuel control actuator failure
Cascade overflow valve malfunction Short in the electrical harness at the injectors or to the ECM Fuel pressure limiting valve ECM failure
Copyright OBD-Codes.com
Jun 07, 2016 | Toyota Cars & Trucks
Pentax smart head
Check the pressure switch. Be sure you have enough water available. Check for a leak. What are you pumping. Is it pumping. I am not familiar with this pump so I am just listing some points to check. If it is a submersible well pump it can develop a lot of pressure.
Nov 29, 2013 | Plumbing
What causes a pentax smart head to cut off and on during use of water
There's not enough water running into the pump this is why its cutting out , hope this helps
Oct 09, 2013 | Plumbing
Code malfunctios c1441 minolta di 450
The copiers CPU is equipped with a self diagnostics function that on detecting a malfunction,gives the corresponding malfunction code on the touch panel.Resetting a malfunction:
- Press the trouble reset switch on the technical representative setting switches board to reset fusing and exposure lamp related malfunctions.(code: C400,410,420-expo;C500,510,520-fusing unit)
- For any other malfunctions,open and close the front door or turn OFF and ON the power switch.
C1441 CCD failure(clamp adjustment failure).
Reset the malfunction,check that the original glass is properly installed.Check for extraneous light and check to see if CCD Assy and mirrors are installed at the correct position.If the same malfunction is detected again,change image processing board.
Aug 14, 2012 | Office Equipment & Supplies
Pentax smart head loosing presure system has no leaks continuosly switcing on and off ,also not switcing on when washing maching starts its rins cycle ,have to press reset button to start pump again.
Jan 16, 2011 | Plumbing
My check engine light is on. Advance Auto Parts says it is the PO 325 Knock Sensor Malfunction Bnk 1 or Single Sensor. My Subaru is a 1996 Impreza. I also have a fast blinking left turn signal that...
  1. Knock sensor. Check all the wiring connections on the engine heads. Your sensor probably is failed (but see Overheating #3 below) .
  2. fast blinking left turn signal. The front bulb has failed, so replace it.
  3. oil temperature light. This may be an indirect result of #1, as the engine is not running properly and this can cause overheating (but see Overheating #3 below)
Other causes of overheating ...
  1. low oil level
  2. low coolant level. If you are losing coolant, the cause has to be located. The correct fill method is to top up the radiator, then repeatedly squeeze the top rad hose, to "burp" all the air out of the cooling system. You will hear the coolant squishing in the top of the engine. Keep burping until the coolant squishing noise stops.
  3. head gasket(s) may be failing, a not uncommon problem for your engine model. Check for oil in the coolant.
SD
Jan 07, 2011 | 1997 Subaru Outback
Green light is blinking, but I am unable to trun the power on.
rival smart pot 38651 crock pot all light blinking
to reset this you need to hold both thye right and left button for 30 seconds. the cause of this is from unpluging the unit when it is on also a power failure will cause this. if this does not work hold all four buttons in. they only tell you this if you get the right person at Jarden Consumer Solutions
www.crock-pot.com
Oct 30, 2007 | Rival 38601 Smart Pot 6-Quart
Plumbing Logo
52 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
