Question about Garden
Hinomoto n249 My Hinomoto tractor seems tohave an electrical shortThe fuses on the dash are not blown and it starts fine but no lights or gannon movement wher should i start looking?
  • 742 Answers
Check all the wiring for green wires, also check fuses that are inline on the wiring harness. Check switches for loose connections. Check at battery for loose connections or broken wires.Hope this helps, plese post solved on fixya.com.So I get credit for a solved problem if it does. If not, check back and give me more info.
Posted on Apr 24, 2014
SOURCE: no electric
There's a 20 AMP fuse hanging under the fuel tank on the right side of the tractor. I just bought 5 from Auto Zone for $3. Hope this helps. derek
Posted on Jun 23, 2009
Mike258
  • 1498 Answers
SOURCE: I have a Craftsman 17hp....tractor was working
Hey there,
Amps? Are you sure you weren't measuring voltage?
Either way the number is low indicating a depleted battery.
Try a jump. Just like you would a car with a dead battery. Be careful, it's a lot more cramped so take care to avoid a short. The result should be instantaneous. It's worked for me numerous times.
And it will not damage your tractor.
Best regards,
Mike
Posted on Aug 09, 2009
  • 110 Answers
SOURCE: I have CraftsmanLT1000 lawn tractor, Smokes heavily.
First check the oil, not only the level but the smell
if its overfull and it smells like gasoline then the problem is that your carb is dirty or the float is sticking and flooding the engine with gas. If the oil is at the correct level then the problem is more likely the valve stem seals, as the engine warms they leak. I presume you have checked the airfilter is clean? The choke is comming off completely when you move the throttle cable? The LT 1000 is the entry level rider in the sears line. The engine usually starts wearing out in about 50 hours use. Remember the sweetness of low price is long forgotten with the bitterness of low quality!
Posted on Nov 15, 2009
rwvanlue
  • 486 Answers
Many times a dirty air filter will cause this on this style of engine. When the filter is plugged, it creates a 'rich' fuel condition, and the engine smokes heavily, the excess carbon is drawn into the air filter, and plugs it even more.
check spark plugs, air filter, fuel filter, choke linkages (for full choke/no choke operation) and crankcase oil.
Crankcase oil can become fuel contaminated, thus overfilling the crankcase and filling the crankcase breather with raw oil/fuel, and this is drawn into the air filter, plugging it, and starting this senerio.
If there is fuel in the crankcase oil, drain completely, and refill with fresh oil. Then you need to look towards the carb for an inlet needle sticking, broken, worn.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 16, 2009
nova2nv
  • 197 Answers
SOURCE: 21 hp electric start Craftsman lawn tractor, B&...
Have your mechanic set your intake/exhaust valves at .004 when piston is 1/4 inch past top dead center on compression stroke.
Posted on May 22, 2010
Cranking but No start on Hinomoto tractor if any one can help please.
Go to the basics which are: Fire, Fuel. and Compression.This should Get you in the ballpark.
Aug 25, 2017 | Garden
Looking for free download oh manual for hinomoto e182.
Feb 15, 2016 | Sewing Machines
I have a 2000 toyota rav4 no power to outside lights electric locks dash lights clock, radio car starts fine also car will not go into gear new battery is in there 6 months
so if battery is charged to 12.6vdc rested
you do have blown fuse(s)
so why not buy a 10 buck voltmeter and find it.
KEYON
we measure both sides of fuse (to ground) for 12vdc.
0v is blown fuse.
easy huh< fuses that look good can be in fact bad.
use a meter and win. every time.
Oct 19, 2014 | 2000 Toyota RAV4
I need to find out wher and how to fix the fuse on the front dash light
If you do not know where the fuse is, how do you know it needs "fixing"?
If your dash lights are not working, there is a possibility that there is a blown fuse. However, you need to realize that blown fuses do not cause electrical problems. Electrical problems cause blown fuses. So if you replace the fuse, it will likely just blow again if you do not fix the problem that caused it to blow.
On the other hand, there are several other things that could be keeping your dash lights from working that has absolutely nothing to do with the fuse.
With all that said, the fuse that protects your dash light circuits is a 7.5 Amp fuse that is located in the Instrument Panel Junction Block at the left side of the dash. It is marked "PANEL"
Mar 22, 2012 | 2002 Toyota Sienna
I have a 97 Bravada that won't start. When I turn the key on the radio and other accessories turn on but the dash never turns on and the truck won't start. It turns over just fine. I checked the...
Yes, it is electrical alright. But probably not due to the fuel pump, I would bet the pump won't turn on as long as the dash won't, cause the ignition system is not on. It's probably either a blown fuse for the ignition or a bad ignition switch. So check all your underhood fuses.
May 14, 2017 | 1997 Oldsmobile Bravada
Garden Logo
132 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
