Question about Sharp Microwave Ovens
Sharp microwave...I can't find or identify the part I need
I have a Sharp microwave, model # R-1461...what I need is a small plastic tan colored piece that sleeves over the motor shaft and connects with the bottom of the glass tray and causes it to turn as the motor rotates.
The problem is that I don't know what to call this part, or the part number, or where to get it.
I've already tried the ''Parts Store'' on line to no avail.
HELP, PLEASE!
  • Sharp Master
  • 9,098 Answers
This is the "turntable coupler".
For model number R-1461, that part number is NCPL-B005MRF0 (note that those are zeros, not "ohs")
You can order this from Encompass here or you can call them toll-free at 866-779-5835.
Posted on Jun 16, 2009
What is the color of the sharp r-1480?
The Sharp model numbers indicate the cabinet color by the last number in the model number. 0=Black, 1=White and 2= Almond
Apr 18, 2014 | Sharp R-1480 Microwave Oven
Sharp R-1461a. What are dimensions?
The dimensions of your Sharp microwave model number R-1460, R-1461 and R-1462 are 29 3/4" in width 14 3/4" in height and 12 1/2" deep. Capacity is 1.1 cubic feet.
Sep 30, 2013 | Microwave Ovens
Sharp r520kst door won't stay shut
If the door will not stay closed it is the spring inside door, or the small plastic piece that holds the spring which is attached to the $80.00 piece called outer door.
To fix it, it is EASY and you do not have to even take the inside cover all the way off. Just remove the three sides of cover by gently slipping a plastic putty knife around rim to release the clips. Then attach the spring to the small hole below where the plastic piece used to be, which is located in the metal on the glass frame piece, use tweezers, hold the other end of spring as you place spring onto plastic door latch and set into place!
Snap the inside cover back on and YAY! FINI!
Aug 20, 2012 | Sharp Microwave Ovens
Roller Stay for Sharp Carousel microwave oven
u can try www.partstore.com
but the tray roller is pretty much univeraql if you have problems finding it for that model alost any sharp tray roller will fit the unti
i just grabbed one out of the dump for my personal un it and it works fine
Oct 09, 2009 | Sharp KB6024MK 1000 Watts Microwave Oven
How do I get our Sharp Carousel R-1611 off the wall. We don't have the manual and the Sharp site doesn't recognize the model.
You need to remove the hood (the grille cover above the microwave door and above the control panel) by lifting up on the bottom of the hood (the plastic should flex pretty easily) and popping it off. On the far left and right you should see two phillips screws, most likely bronze colored. You need to remove them (they are quite long) completely. The microwave will still be sitting on its support arms (which enter the chasis of the microwave from the rear). Once the screws are removed you need to lift the microwave up and pull forward - it should come off of the supports, but you might have to jiggle it a bit.
Don't forget to unplug the microwave and disconnect any ducting before lifting it off of its supports.
Mar 30, 2009 | Sharp R-1610 Microwave Oven
Sharp R-1510 Start Button Not Working
This may not solve your problem, but on my Sharp R315J microwave, the little plastic pin that pushes forward on the inside of the start button, had broken off and it wouldn't start. The Minute Plus button would start the microwave, so I knew the microwave worked, so I tried to find a piece of plastic that I could glue into the start button hole, because the part doesn't exist and you have to buy the whole door for $100 plus shipping. Nothing I could find was small enough, so I started looking for a new microwave.
While ouside doing lawn work I noticed a small bird tail feather and the end looked to be the perfect size. I snipped off the pointed end and then up about 3/8" to make a little rod to replace the plastic one that broke. It fit perfectly!!! I didn't even have to glue the inside end, it stays put even after repeated door opens. This is sturdy material and looks to last a long time. When it wears out, I have a cat, there's always a few feathers around. I hope this saves someone else a hundred bucks, like it did me.
Mar 09, 2009 | Sharp R-1510 Microwave Oven
Door won't latch/microwave won't turn on
The door does come apart. Open the door and where the hinges are, there are openings where the hinges enter the door, this plastic piece (goes all the way around the door) With a small flat blade screws driver VERY carefully pry it (plastic) off, once off, check the latch end for the spring, typical failure for a Sharp is the little tab that the spring hooks to on the door, the only way to repair this so it will last is to replace the door frame. they are not too expensive, about $50 or so Part# FCOVB166KIT
is the door frame assy
Jan 07, 2009 | Sharp R-1405 / R-140 Microwave Oven
Makes a loud humming sound and blows fuse behind controll panel
Most likely a shorted capacitor is causing the fuse to blow. Easy and cheap to fix.
Check with www.martinmicrowave.com or call toll free 1-877-894-0035 for parts info
Sep 02, 2008 | Sharp R-1460 Microwave Oven
Microwave Ovens Logo
90 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
