Question about Canon imageRUNNER iR C4080 Color Copier
6 3/4 envelopes in bypass
Too small
  • 73 Answers
According to how many you are doing, you can tape them to a larger piece of paper.
Posted on Mar 29, 2014
How do i use canon ir4080i to print on A4 envelope ?
place the envelope, face up, in the manual feed/bypass and select the proper envelope when prompted on the screen. select the bypass from the touch screen (paper select) or from the print driver
Feb 17, 2015 | Canon Office Equipment & Supplies
How to print #10 envelopes on a Xerox 3610 printer?
Solution : Print on Envelopes You can print envelopes from the Bypass Tray only.
Guidelines for Printing Envelopes
  • Print quality depends on the quality and construction of the envelopes. Try another envelope brand if you do not get desired results.
  • Maintain constant temperatures and relative humidity.
  • Store unused envelopes in their packaging to avoid excess moisture and dryness which can affect print quality and cause wrinkling. Excessive moisture can cause the envelopes to seal before or during printing.
  • Remove air bubbles from the envelopes before loading them into the tray by setting a heavy book on top of them.
  • In the print driver software, select Envelope as the paper type.
  • Do not use padded envelopes. Use envelopes that lie flat on a surface.
  • Do not use envelopes with heat activated glue.
  • Do not use envelopes with press and seal flaps.
  • Use only paper envelopes.
  • Do not use envelopes with windows or metal clasps.
To Load Envelopes in the Bypass Tray:
  1. Open the Bypass Tray.
  3. Move the width guides to the edges of the tray.
    NOTE: If you do not load envelopes in the Bypass Tray right after they have been removed from the packaging, they can bulge. Flatten them to avoid jams.
  4. To load envelopes, select an option:
    • For Number 10 envelopes, load the envelopes with the short edge going into the printer, flaps down, and flaps to the right.
    • For C5 envelopes, do one of the following. If the envelopes wrinkle, try another option.
      • Insert envelopes with the print side up, flaps closed and down, and flaps going into the printer.
    • NOTE: When loading Monarch or DL envelopes, remove the Multipurpose Tray.
  5. On the printer Control Panel, press the Menu button.
    NOTE: To navigate through the menu, use the Up or Down arrow buttons.
  6. Navigate to Tray Settings, then press OK.
  7. Navigate to the Bypass Tray, then press OK.
  8. Navigate to Tray Mode, then press OK.
  9. Navigate to Panel Specified, then press OK.
  10. To return to the previous menu, press the Left arrow button.
  11. Navigate to Paper Type, then press OK.
  12. Navigate to Envelope, then press OK.
  13. To return to the previous menu, press the Left arrow button.
  14. Navigate to Paper Size, then press OK.
  15. Navigate to the required envelope size, then press OK.
Phaser 3610 Support Drivers
Apr 09, 2014 | Xerox Office Equipment & Supplies
How do i print envelopes on the panasonic DP 8035
most copier that is printing in envelope are done on bypass, set the paper size of your envelope ex 4 x 6 then place the envelope on the bypass.
Apr 25, 2010 | Panasonic Workio DP-4530 Copier
Lanier LD135. How do I program it to print
Envelopes thru bypass only....once they are set youl need to set the bypass to envelopes at the machine either thru user tools or by pressing bypass then the # key and selecting envelope or custom size and entering the size of your envelopes.
Back at the computer go into print proprties and select paper souce bypass the printdriver will use the machine settings unless ou tell it otherwise
Feb 24, 2010 | Lanier Office Equipment & Supplies
I have a Mac computer. I can't choose to print an envelope and use the bypass tray at the same time. So how do I print an envelope?
on the copier insert the envelope face down
under customer size settings for the bypass enter the size of the envelope # 10 envelope is the biggest you can select select the application you are using and make the correct selections for envelopes in the application
Sep 30, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Ricoh laser printer will not correctly print my envelopes - need someone to help me calibrate the printer or the word program to effectively print envelopes
what model? you must tell the printer what envelope type is in the bypass (must use bypass) usually type 10. also must tell word in print properties to feed from bypass, again usually type 10 envelopes
Aug 04, 2009 | Computers & Internet
Need EASY directions to print envelopes!
At the print que select the bypass tray as the paper source and envelope as paper type and make sure to set the envelope size like # 10 or whatever size they are. Make sure not to print envelopes with windows.
-Carl, please let me know if this helps.
Apr 20, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
How to print envelopes aficio ricio mp c4500
On an MP-C4500, envelopes must be printed using the bypass tray (the fold-out tray on the right hand side). Put the envelope in face-down and tighten the two fences so the envelope is snug.
When printing the envelope, make sure the print driver is set for the correct envelope size. If envelopes tend to jam in the printer, try setting the bypass paper type for thick paper.
Nov 19, 2008 | Ricoh Aficio GX5050 GelSprinter InkJet
Printing envelopes from gestetner 3502P
What size are the envelopes?
Envelopes have to be fed through the bypass. #10 envelopes are not recommended to run through the copier. There too small to feed through the fuser rollers and they will jam.
Sep 03, 2008 | Office Equipment & Supplies
Can't print envelopes
Solution Title: How to print on COM10 envelops from the Bypass tray (PCL6) using a Windows 2000 O/S Resolution/
Solution
thumbsup.gif Fixed! thumbsdn.gif Did not fix. Resolution Role: Fix
Critical Message: The Envelope must be placed in the Bypass Tray face down (flap side up) and Long Edge IN. In Microsoft Word (Word 2000)
    1. Under the Tools tab, select Envelopes and Labels.
    2. Enter your Delivery and Return addresses.
    3. Click on Options
    4. Under Envelope Options; [Envelope size], select Size 10 (41/8 x 91/2 in)
    5. Under Printing Options, select Portrait (LEF) - Long Edge Feed
        • As Feed from, select Tray 5 (Bypass)
    6. Click <OK>
Within the WorkCentre Pro 123/128 print driver
After opening up the print driver [<Start>, <Settings>, <Printers>, double-click on the WCP 128 PCL6 driver], click on Printing Preferences under the General tab.
  • Under the Paper/Output tab
Set the following features as follow:
    • Job Type: Normal Print
    • Paper Size: COM10
    • Output Size: Same as Paper Size
    • Image orientation: Portrait
    • Image Rotation: OFF
    • 2 sided Print: 1 sided Print
    • Stapling: None
    • Output destination: Center Output Tray
    • Offset Stacking: None
  • Under Tray/Layout
  • Set Paper Source to Tray 5 (Bypass)
  • Click on Bypass Tray Settings
    • Paper Type: Heavyweight (1 or 2)
    • Feed orientation: Portrait
  • Click <OK>
  • " on Specify Paper Type and select Heavyweight (1 or 2)
  • " (Apply> and <OK>
  • " <OK> again
In Microsoft Word under Envelopes and Labels, Click <Print> to send the information to the printer.
Note: This setup represents one way of printing envelopes. Other ways setting up some features in a different manner will work as well.
Solution v1.3.20.0 312637.How to Print on COM10 Envelops From the Bypass Tray (PCL6) 2006-04-05 21:57:29
Nov 02, 2007 | Xerox WorkCentre PRO 128 Copier
Canon imageRUNNER iR C4080 Color Copier Logo
24 people viewed this question
old marine
old marine
