Question about Nordic Track C2255 Console (treadmill)
Nordictrack c2255 Lubrication
    Problem Solver:
Hi
I have Nordictrack c2255 having software issue. Display is showing upside down and I think it needs to be reprogram
Posted on Dec 25, 2014
Keeps stopping. I turn off power and restart but it stops again after a few seconds. How can I reset it to quit stopping after a few seconds.
Hope the speed sensor have some problem may dust on it or the treadmill need lubrication. Most of the treadmill stop after some kilometres reading indicating that its time to lubricate it. After lubrication you have to reset the counter.
check the link bellow using the search tab find out details of NORDICTRACK A2350. and follow those instruction.
www.electro-medical.blogspot.com
Nov 01, 2015 | Nordic Track NordicTrack A2350 Pro...
How do I lubricate the c 1800s nordictrack
the only lubrication that needs done is between the walking belt and the deck. if a roller is squeaking either front or rear you can try using wd40 on the bearings on either side
Oct 21, 2014 | Nordic Track Nordictrack C 1800s Treadmill...
My NordicTrack X7i cannot locate my computer IP address
Reset the treadmills and try again. Follow the section troubleshooting owner manual. or download from www.fitness.manualsonline.com
GO TO http://whatismyipaddress.com/ip-lookup and test again
God bless you
Oct 14, 2013 | Nordic Track C2255 Console (treadmill)
Belt stops while using nordic track c2255
this happen to due the lack of maintenance according the schedule manintenance. see the video and proceed.However if after you did, the problem remain,is TIME to replace the old board deck. God bless you
Mar 26, 2013 | Nordic Track NordicTrack A2350 Pro...
9500 pro
see the video and lube the deck belt+rollers bearing. You must do it every 150miles aprox.
God bless you
Jan 21, 2013 | Nordic Track NordicTrack Elite 9500 PRO...
NordicTrack c2255
Ok, your controller is faulty. Double check that your reed switch is connected and adjusted. It is located at the pully on the front roller. It is just outboard of the pully. It points at a magnet that is glued into the plastic pully. It should be about 1/8" away from the pully. If that is ok follow the wire back to the controller, it only has two small black wires, It has a red two place connector that pushes on the controller board. These are rarely the problem. If you are under warranty, get both the controller and the reed switch. If I would guess, It is the controller that is your problem.
Nov 26, 2011 | Nordic Track Exercise & Fitness
My C2255 Nordictrack has been fine for the past couple of years until recently when it started turning off intermittently with no power to the console. Now, the console will not turn on at all. The...
If the console takes batteries, replace them. If this does not work or your console does not require batteries, check the reed switch or optic sensor. Reed Switch: Unplug the treadmill and remove the motor hood cover. The reed switch is mounted on the frame next to the front roller pulley. There is a magnet glued into the front roller pulley. When adjusting the reed switch, make sure it is pointing directly at the magnet. Move the tip of the reed switch within 1/8" of the magnet. Also, check to see that the wire is not damaged, and is connected to the console.
Optic Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk.
Oct 17, 2011 | Nordic Track C2255 Console (treadmill)
I have a nordictrack 2500r treadmill and when i run on it the belt sticks to the board underneath. Any assistance would be very much appreciated thanks
hi,
Your treadmill walking belt need lubrication. For lubricating use Teflon silicon lubricant. To know how to lubricate the treadmill belt watch the following video.
OK
Aug 20, 2011 | Exercise & Fitness
My NordicTrack EXP 1000 stops in the middle of a workout. Before it stops, I smell a rubber smell. 1) Does the tread need lubrication? 2) Is the motoer burning out?
my nordic track 1000 stops several times during the workout. I can step to the side and the belt may or may not start back up. The display continues to display the set machine. any suggestions?
Jan 03, 2010 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track C2255 Console (treadmill) Logo
186 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
