Question about Sony VAIO Computers & Internet
Window is not starting up it shut off it self i have tried 3-4 times but it does not start
  • Sony Master
  • 27,725 Answers
Check to see if there are any keys stuck/depressed.
If so, use a paperclip and fit it underneath the key and gently pry the end that is stuck.
Make sure the laptop is off before attempting this.
Observe where the boot process ends and starts over.
In most cases, this will give an indication where the problem occurs.
If the laptop reboots early on in the process, for example when it is detecting the hard drive, chances are good it is a hardware issue.
If the reboot occurs further along in the process, like when it is loading operating system files, there may be an issue with operating system software.
Test all power and data leads that attach to your hard drive SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty
Make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty.
even something as small as faulty fan lead can cause you problems
computers need all of the data and power to travel through every working device and to have an end for a computer to be able work properly.
Motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all power and data leads make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
Check your computer ram modules for secure dust free seating you might even remove the ram modules to check for dirt on modules and in the module socket and cmos battery make sure it has charge and they are dust free and securely seated some motherboards cmos batteries are soldered in
If your computer runs long enough scroll to bottom toolbar(bottom of screen) right click select task manager
applications you will see whats running
if you see anything you dont need running select end nowand you might uninstall that specific
program if you or computer does not require it to run and
some unnecessary programs that could be running your computer over its limits causing memory dumps
also under processes see what is ticking over in the background you might have a virus again if you see something you
dont need to be and users you will see who is using your computer You might need to add more computer ram
if you're not sure if a module is right for your system use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules.first you will need to select the manufacturer from a drop down list then select your product line
from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
You should always ask for a guarantee on the compatibility of the ram before making any purchase
Might be getting hot
check you CPU make sure its securely seated and has thermal grease
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
Capacitors look like small metallic canisters and they are found in many different computer components including computer monitors, computer motherboards, video cards, power supplies and a variety of other consumer products.
A bad capacitor can cause a variety of computer problems, but if you can identify the faulty capacitor you may be able to replace it and save your computer.
Capacitor Capacitors, sometimes also called condensers, are used to store energy in an electric field.
In the context of computing, capacitors are used to block the direct current being circulated around the motherboard.
A typical capacitor should last up to 15 years, but some computer manufacturers use substandard capacitors resulting in shorter lifetimes.
Computer Problems
When a capacitor has gone bad on a computer you may experience a large range of problems. The computer may have trouble booting up, or it may shut down without notice after running for only a short period of time.
The most common problems associated with faulty capacitors are that they cause unexpected computer crashes and general reliability issues ranging from read/write issues to distorted screen images.
Identifying a Bad Capacitor
To identify a bad capacitor you will need to open your computer case and locate the capacitors on your motherboard.
A bad capacitor may exhibit swelling at the top or the base of the capacitor or it may sit at an awkward angle with the motherboard, so compare the various capacitors in your computer in terms of size and placement.
Additionally, a bad capacitor may have a funny smell or it may have a brownish residue leaking from the top or the base.
Prevention
Manufacturers claim that capacitors may go bad because a computer is not receiving enough power from a power supply, because of an overclocked processor or because a computer is operating in an environment with too much heat or humidity.
However, some capacitors prematurely fail due to faulty work on the part of the manufacturer.
If you have a bad capacitor be sure to do research as to the lifespan of other products made by your manufacturer.
Identifying bad capacitors
http://www.youtube.com/watch?v=ngA4k32jLGc
Capacitor replacement
http://www.youtube.com/watch?v=s0Pn2tEjY04
How to check a capacitor
http://www.youtube.com/watch?v=U4tnHA0phcc
Replacing a leaking capacitor
Could be a problem with the Hard Drive or the Hard drives PCB
http://www.onepcbsolution.com/
Posted on Mar 29, 2014
Windows loads up bios beeps once repeatedly
Make and model of laptop will reveal bios error codes
Aug 17, 2015 | Computers & Internet
Samsung hls4266wx xaa
my lg p999 cell phone is not working
Feb 24, 2014 | Televison & Video
My computer was left on as it always is. When i went back to it my windows had shut down and now it wont reload. it ask's me to start windows normal? or to start in safe mode or to start the last knows...
Seems that some Windows files got corrupted hence the Windows cannot load properly.
If you have a Windows installation CD, put that in start your machine and try to do a Windows repair rather than an installation.
If you don't have a Windows CD, but you have a restoration CD that came with the laptop, use that to restore your computer to the factory settings.
Thanks for using Fixya!
Nov 19, 2010 | Acer Aspire One PC Notebook
Starts then it wont start back up
if it starts and warms up does it shut it self off or do you shut it off an then won't restartif it shuts self off may be runnining it self out of gas wwhen it shuts off try spraying a little starting fluid in breather and see if it will recrank if it does you have a fuel problem if it does not start you have an electicly problem such as a bad coil poss
Jul 29, 2010 | 2005 Yamaha YZF-R1
Pc can shutdown anytime while i useing it
make sure it is not overheating and that your ram and processor have a good connection.
Jun 21, 2009 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
Latitude d 600 locks up
Dear we have provid the solutation for best my self
just do it
1.click the start
2.click ran
3. type recent
4.click ok
secon option is use for
1.click the start
2.click ran
3. type temp
4.click ok
this two setps in all file is come to desktop in open the new windows and afrer Remove the all file.
99 % you problem is solve but not solve your problem just install the antivirus program with latest update and your pc or laptop full scan
and remove the all virus ............ok .
Mar 28, 2009 | Dell Latitude D600 Notebook
MSI K8TNeo2-F v2.0
This is not too uncommon scorcher63.
From what you stated, when windows does start it only goes so far & than re-starts it's self, like loading in a loop. Than at times it loads the start up options.
For reasons unknown, your windows (startup files) are corrupted. Easyest way to fix this is. Put you windows CD in the cdrom, shut down the system. Start the PC & press the F8 key every 2 seconds. A boot menue will load. Use the up & down arror keys & choose the cdrom drive. You will see (to boot from cd press any key), press the space bar. The cdrom will startup. Windows will start to load. You want to repair windows. This option will re-install windows but will leave most of your personal data alone. Like My Documents your username. Some programs "may" need to be re-installed. After installation is complete remove the windows cd & shut off the PC. Start the Pc, windows should load. Run Windows Update. If you have a antivirus program please do a full system scan. Run windows Defrag program.
scorcher63, if you have more question just post them here.
Feb 21, 2008 | MSI K8T Neo2-F Motherboard
Computers & Internet Logo
37 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
