Question about Thule 2000 Dodge Dakota - Club cab - Xsporter Truck Rack
Dim drivers headlight on high and low beam
Drivers side dim head light on both high and low beam i have replaced the bulbs and have checked the ground wire that is beside the batery with no change to the problem
    New Friend:
You're correct to ck the ground wire to the light bulb circuit first. good ground? how about voltage? assuming, since this problem started suddenly and has continued, not intermittently, as in a loose connection, I would next start looking at the light switch itself. Has anyone recently installed a sound system, or been into the dome light circuit, dash light's, etc?
Posted on Mar 29, 2014
Driver side headlight goes dim on high beam while passenger side is bright
bad connection or bad earth check all connection or bulb
Jan 24, 2016 | Cars & Trucks
Driver side low and high beam on but dim. Passenger side low beam normal but high beam on and dim
I would check for the groundwire continuity
Driver side - dim low beams and no hi beam - Subaru Outback ...
www.subaruoutback.org > ... > General > Electrical & Electronics
Oct 11, 2014 - Hi everyone, My drivers side headlights are dim on low, (car has separate bulbs ... When the headlight switch is turned ON, but for low beams, ...
Driver-side Low beam Not Working (electrical issue not bulb ...
www.hummer4x4offroad.com/.../showthread.php?...Driver-side-Low-be...
Mar 12, 2015 - 10 posts - ‎4 authors
The high beam continues to work on both sides...I pulled the Driverside headlamp fuse and then both left and right beams lit up but very dim.
High beams ok, but not low beam - one side only - TDIClub Forums
forums.tdiclub.com > ... > VW MKIV-A4 TDIs (VE and PD)
Jan 23, 2014 - My driver's side lights are working fine - high and low beams. ... But it definitely looks like the big lamp on the driver's side gets brighter when ..... Drivers side headlight is very dim on low beam and goes out when on high beam ...
Dim driver's side headlight (low & high beam) - GrandAmGT.com Forum
www.grandamgt.com > ... > Technical Q&A
Dec 11, 2002 - 6 posts - ‎4 authors
Jan 04, 2016 | Cars & Trucks
Left headlights
Check your connections at the wiring harness going to headlights for corrosion, sounds like high resistance somewhere, also make sure your ground wires are secure. It wouldn't be the alternator or the battery would be dead and not start the engine. Also shouldn't be any condensation in your head light assembly's or will cause bulbs to blow prematurely.
Feb 22, 2014 | 2002 Subaru Outback
One low beam head lights will not work, high beam works though
check for a damaged wire for the low beam. Also wouldn't hurt to check the ground wire as the high beam will try and ground through the low beam but not visa verse
Dec 29, 2013 | 1997 Chevrolet Blazer
1990 Honda CBR 250 RR low beam headlight not working but high beam still works
Hi, Anonymous if your headlight is not working, only one beam works, keeps burning out, blinking, dim or surges from bright to dim to bright the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chafed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/low beam switch.
6. Faulty ignition switch.
7. Fuse is good but no continuity on both sides.
8. Faulty headlight relay.
9. Faulty wiring between battery positive and headlight bulb socket.
10. Weak charging alternator/generator/lighting coil
11. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Headlights not working CBR250RR Highbeam works
High beam work low beam dont
1986 1999 Honda CBR250R CBR250RR Service Manual Moto Data Project
http://www.partsfish.com/page/oem-parts-for-honda
HONDA CBR250R Owner Manual
Sep 04, 2013 | 1990 Honda CBR 250 RR
2000 Kawasaki KLR 650 low beam does not work
Hi, Anonymous if your headlight is not working, intermittent, only one beam works, keeps burning out, blinking, dim or surges from bright to dim to bright the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
Low beam not working
2013 Kawasaki KLR650 Low Beam Headlight Bulb
Kawasaki KLR650 Service Manual
OEM Parts for Kawasaki
2000 Kawasaki KLR650 Owner Manual
Aug 16, 2012 | 2000 kawasaki KLR 650
2003 ford taurus has a head light that is dim . i checked the wires with a meter and i get 12 volts from side two side and middle wire gets nothing. because i can read 12 volts does that mean the ground is...
That sounds like you have 1 ground wire, 1 wire for the low beam, and 1 wire for the high beam. If the car has the standard halogen headlight bulb I would recommend replacing it and seeing if that fixes the problem.
Dec 20, 2011 | 2003 Ford Taurus
Honda Activa no high beam
Hi, Joan_simon if your headlight is not working, only one beam works, keeps burning out, blinking, dim or surges from bright to dim to bright the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
Motorbike experts why are my main lights not working Singletrack Forum
Honda Ruckus high beam issue
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
Honda activa 2009 Owner Manual
Apr 23, 2011 | Honda Activa Motorcycles
F 150 Head light issue
You know the fuse for the high beams is good ( Cab fuse panel fuse # 16 ) and the pass low beam fuse ( cab fuse panel # 26 ).
Might want to check cab fuse panel fuse #28 ( this is the driver's side low beam ).
If this fuse has power on both sides ( with the low beams on ) next you can pull the headlamps, and check for power at the connectors, but depending when the last bulb change took place, I would say you need need bulbs. ( need at least 1 for the high beam out )
Confirming with a meter at the headlamp would be a good idea, before spending the money.
The bulb connector has 3 pins.
Black wire is ground on both sides
Light Green w/ Black stripe wire is high beams on both sides
Driver Lo = Dark Blue w/ white stripe
Pass Lo = Dark Green w/ Orange stripe.
Nov 16, 2009 | 2002 Ford F150 Regular Cab
Right headlamp
Check the fuse for the passenger side.It is under the hood. it may not be making good contact. wiggle it a little bit and see if it makes any difference. if not, check where the the ground wires are connected to the chasis. See if thats not the problem.
Oct 31, 2008 | 2001 Buick LeSabre
Thule 2000 Dodge Dakota - Club cab - Xsporter Truck Rack Logo
80 people viewed this question
Top Thule Boating Experts
Tom Chichester
Kar Volk
Richard Warren
Richard Warren
Are you a Thule Boating Expert? Answer questions, earn points and help others
