Question about Samsung LN-S4051D 40 in. LCD Television
No power until I disconnect the main pcb
    Top Expert:
  • Samsung Master
  • 74,482 Answers
Main pwb fault. Replace it as card basis. Contact the authorized service centre for Panasonic. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Posted on Mar 29, 2014
Error 03130031-2618 in canon ipf 750
Error code 03130031-2618 is a voltage error. It could happens on these printers models: IPF6350, IPF6300, IPF6000, IPF8000, IPF8300, etc...
Solution 1:
  • Power off the printer.
  • Disconnect the power cable
  • Wait for 30 minutes.
  • Connect the power cable
  • Power on
Solution 2:
  • Check the power supply
Solution 3: The voltage of the print head is abnormal.
  • Replace the Printhead
Solution 4: Check for the cable continuity between the carriage relay PCB and the main controller PCB
  • Replace the cable.
    Replace the carriage relay PCB.
  • Replace the main controller PCB
Oct 26, 2017 | Canon Office Equipment & Supplies
Tip
ERROR CODES AND DESCRIPTION
2X Blink - Main Power Error
A 2X protection mode blink pattern can be activated due one of the
following defects.? Loss of REG12V (LVP)*
? Loss of -125V (Single Line)
? Excessive -125V Level (OVP)*
? Loss of Power-ON Signal
? Excessive PFC Voltage (OVP)
? Excessive PFC Temperature (OTP)*Low Voltage Protection (LVP)
*Over Voltage Protection (OVP)
For more check the following link. Use the search tab on the top right corner to find your product
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
on Feb 15, 2015 | Sony Kdl-32ex720 - Series 32" Ex720 Bravia...
Image runner getting this error code (E261-0000) / how do i fix it
Code
E261-0000
Description
The intervals of zero-cross signals deviate from the tolerance range while the fixing heater is supplied with power
Causes
The wiring is faulty (short circuit, open circuit). The main power supply PCB is faulty. The DC controller PCB is faulty.
Remedy
1. Connectors Are the connector J205 on the main power supply PCB and the connector J308B on the DC controller PCB securely connected? (zero-cross signal: J205-7 <-> J308B-1) NO: Connect the connectors securely. 2. Main power supply PCB, Main controller PCB Try replacing the main power supply PCB. Is the problem corrected? YES: End. NO: Replace the DC controller PCB.?
Best Regards
Jul 24, 2016 | Office Equipment & Supplies
Trip switch cuts out when i use washing machine
Main board power circuit fault.disconnect main PCB and reconnect power cable .you can identify the fault. Replace main pcb.
Sep 01, 2014 | Indesit Washing Machines
Machine error e03 20
Main Motor rotation 1. Drive Mechanism is defective.
2. Main Motor connector is disconnected.
3. Main Motor is defective.
4. DRV PCB connector is disconnected.
5. DRV PCB is defective.
6. SPC PCB connector is disconnected.
7. SPC PCB is defective.
8. LVPS is defectiv
Mar 18, 2014 | Panasonic DP-8060 MFP...
E010
IR330, step 1- this Error is the main motor fails to rotate normally, does the main motor rotate until E010 turn on? if yes go step 5, if no step 2- harness wiring connectors around the main motor normal? if no correct the wiring, if yes step 3- does the voltage of J102-B12 on the controller pcb change to 0 VDC while the main motor is rotating?, if no replace main motor ( main motor driver pcb), if yes step 4-is there 24 VDC generated between J204-3 and J204-4 on the composite power supply PCB, if no replace the composite power supply PCB, if yes step 5 is the voltage of J102-B11 on the DC controller PCB about 5 VDC during WMUP? if no replace DC controller PCB. if yes step 6- Is there continuity of the harness between the image processor PCB and DC controller PCB normal J714-A14 to J113-A7 also 714-A16 to J113-A5 if yes to if no replace the harness if yes replace the DC controller PCB and the Image processor PCB.
Nov 30, 2013 | Printer Essentials Canon Gpr-2...
CANON IR 1600 COPIER IT WENT OFF AFTER REPLACING POWER SUPPLY BOARD STIL COULD NOT WORK UNTIL I HAD TO REPLACE MAIN BOARD THEN IT CAME ON BUT WITH ERR CODE 354 I HAVE TRYED TO CLEAR IT ALL IN VAIN
the counter PCB or the serial no. PCB is not matching.Did u got the main board with the counter pcb attached.if not then u have to get the counter pcb of the same board or attach the serial no pcb and the counter pcb of the old board . u will get it if ur a rep .if not then u have to consult one
Jun 28, 2011 | Canon iR 2016i Black and White Copier
Have power (backlite) but no screen (menu or any control from side buttons) will not turn off.
Try disconnecting the tv button pcb interface connection to the mai board once switched on and try using your remote control functions. If there is still no menu or functions, this cancels out the buttons pcb, and the fault is the main pcb.The voltages are ok which you mentioned..12v..5v and the 24v invertor feed voltage so it will be the main pcb..If you had sound and remote functions i would have said it may be the Tcon as well as the main pcb.
If the remote works ok with tv buttons pcb disconnected, then the problem is the buttons pcb.However, you have no picture..i presume nothing at all including 'no signal message or menu screen'. Therefore, with no bulging caps and correct votages to the main pcb, you will be right to change the main pcb.
PLEASE DO NOT CARRY OUT ANY ELECTRICAL REPAIRS IF YOU ARE NOT COMPETENT TO DO SO..ALL MAINS PARTS ARE DANGEROUS..GET A QUALIFIED TV ENGINEER TO CARRY OUT ANY REPAIRS IF THIS IS THE CASE.
Feb 14, 2010 | Vizio L32 32 in. LCD HDTV
Error261 in canon copier
E261
0000 The intervals of zero-cross signals deviate from the tolerance range while
the fixing heater is supplied with power.
Main cause The wiring is faulty (short circuit, open circuit). The main power supply
Making Corrections
1. Connectors
J205-7 <-> J308B-1)
YES: End.
Feb 22, 2009 | Canon NP 7130 Black and White Copier
E60 error code
Found These Fault Codes On Internet, Hope This Helps, Daz
ALARM CODES
E00(E00)- Problems with water fill during washing
-Tap closed; solenoid valve, water distributor, wiring ,main PCB, pressure switches
E01(E00)- Problems with water fill during drying
-Tap closed; solenoid valve, wiring , main PCB, pressure switches
E10(E10)- Problems with water drain during washing
-Drain hose kinked, filter blocked, drain pump, water distributor, wiring , main PCB, pressure switches
E11(E10)- Problems with water drain during drying
-Drain hose kinked, filter blocked, drain pump, pressure switches
E20(E20)- Door open
-Cycle in Door delay, wiring , main PCB
E21(E20)- Fault in door delay power triac
-Wiring , main PCB
E30- Fault in electronic pressure switch
-Electronic pressure switch, wiring , main PCB
E31- Fault in electronic pressure switch circuit
-Main PCB (fault in electronic pressure switch circuit)
E32(E10)-Calibration error in electronic pressure switch
-Electronic pressure switch, drain pump, wiring , main PCB, filter blocked
E33- Incongruency between electronic pressure switches and safety switch 1
-Electronic pressure switch, safety pressure switch,wiring, main PCB
E34- Incongruency between electronic pressureswitches and safety switch 2
E35- Intervention of anti-overflow pressure switch
-Solenoid valve, water distributor, wiring, main PCB,anti-overflow pressure switch
E36- Water leakage (maximum number of resets exceeded)
-Water leakage, drain hose too low, pressure switch,wiring, main PCB
E40- Motor power triac short-circuited
-Main PCB (triac short-circuited)
E41- No signal from tachimetric generator
-Tachimetric generator on motor, wiring, main PCB
E42- Fault in tachimetric generator circuit
-Main PCB (tachimetric generator sensing circuit)
E43- Intervention of motor overload protection
-Motor, wiring, main PCB
E50- Insufficient heating during wash phase
-NTC sensor setting incorrect, heating element, wiring,main PCB
E51- Overheating during wash phase
-Heating element (to earth), main PCB (relays)
E52- Insufficient heating during drying phase
-NTC sensor setting incorrect, safety thermostat,thermostats, drying heater, wiring, main PCB (relays)
E53- Overheating during drying phase
-Drying heater (to earth), main PCB (relays)
E55- Fault in power relay for heating element (K3)
-Safety pressure switch 2, wiring, main PCB- 6 -
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
E61- Fault in drying NTC sensor(condenser)
-Drying NTC sensor (condenser), wiring, main PCB
E62- Fault in drying NTC sensor(duct)
-Drying NTC sensor (duct), wiring, main PCB
E63- Fault in 1/2 power thermostat
-Drying NTC sensor (duct), 1/2 power thermostat, wiring,main PCB
E70- Power triac to distributor motor short-circuited
E71- Fault in power relay to distributor loads
-Main PCB (relay open)
E72- No distributor position signal
-Water distributor motor, wiring, main PCB
E73- Incorrect timing on distributor contacts
-Water distributor, wiring, main PCB
E90- Fault in tank fill pump
-Hoses obstructed, tank fill pump, wiring
E91- Fault in tank drain pump
-Hoses obstructed, tank drain pump, wiring
E92- Fault in power triac to tank fill pump
-Tank fill pump, wiring, main PCB
Jan 04, 2008 | Zanussi ZWF1440 Front Load Washer
Samsung LN-S4051D 40 in. LCD Television Logo
18 people viewed this question
Henry  Thomas
Henry Thomas
