Question about Asko W6021 Front Load Washer
Door not opening
Door wont open
  • Asko Master
  • 15,633 Answers
That usually means that it is not empty. The front of the machine under the door usually has a panel that you can take off. It has screws near the base. Take them out and remove the panel, then look for a drain plug. It is big and you will get lots of water on the floor if you remove it. Have a vacuum cleaner that works with water ready. Check it for debris when you open it. There is probably a lot of stuff in the drain filter. Clean it and see if you can activate the drain spin cycle. If not there may be a lever that allows you to open the door by hand.
Posted on Mar 28, 2014
Kia rio 5 door 2004 drivers door wont open. Removed cent lock fuse but still wont open inside or out
Sounds like a rod might be off inside of the door and the door panel will need to be removed to access the latch and get the door open. Once the door is open, have the problem fixed before you close it again.
Apr 13, 2016 | Kia Cars & Trucks
1994 lincoln town car passenger door wont open
HELP! How to open "stuck" door - New Edge Cougar Owners
www.newcougar.org > Forum > General > Problems
Mar 9, 2009 - 11 posts - ‎8 authors
Hello all, The driver's side door on our 2000 is "stuck" closed and wont open by key, keyless, ... 1994 Lincoln Towncar w/ 112576 CRUSHED
door help lincoln town car 1994 - YouTube
? 3:04
https://www.youtube.com/watch?v=5yzIfHFU9CI
Sep 18, 2011 - Uploaded by Frank connors
door help lincoln town car 1994 ... owners of Town Cars with hinges that are failing on the driver's door -- and sometimes on other doors also.
Lincoln rear passenger door wont open Questions ... - Fixya
www.fixya.com > Forum > Tags > rear passenger door wont open
Jan 05, 2016 | 1994 Lincoln Town Car
Why does my 973LM liftmaster remote will only open door bur wont close it?
Most garage door operators (openers) have infrared safety "beams". The door won't close, even with a wired push button, if something is in the way.
May 10, 2014 | liftmaster Chamberlain Garage Door Opener...
98 accord door handle broke door will not open
A non electric door, (which?) wont open,lock works ok, handle wont open the door.
What can I do to fix it.
well telling the door to us would help, and options.
so no electric locks,
there are 2 levers. one inside and one outside.
so you pull the door card (inside door covering)
and look at both locks , the inside pull, its it working?
then look at the key lock cylinder. is it connected still
and last are both connected to the latch mechanism.
one can cycle this latch lever inside the door shell.
if that fails the latch is busted.
all this is covered in the FSM ,why not read it.? (under body)
free , too.
http://hondatech.info/downloads/Auto/Manuals/Accord/
Nov 25, 2013 | Honda Accord Cars & Trucks
2006 jetta door wont open from inside or outside
link connector broken inside door, Remove door card and repair
Nov 16, 2012 | 2006 Volkswagen Jetta
Drivers door wont open
Chrysler2008 sebring drivers door wont open all other doors and central locking working including drivers door but will not open any suggestions..
Jun 01, 2012 | 2007 Chrysler Sebring Sedan
Door wont unlock once a wash cycle has begun
that is correct ,. pump water out then the door will open.
May 20, 2011 | Kenmore Elite 45986 Front Load Washer
Trunk wont open. latch does not work from inside
Make sure the drivers door is open and push the button on the drivers door to open trunk. Keep the drivers door open while you open trunk. If you close the drivers door before opening it, it won't open. Well this is what happens to our car. Don't know if it's a fault or the design but this does work for us.
Jul 03, 2009 | 1997 Saab 900
Driver side door wont open.
You can't.. you've got to open the door. sorry.
Jun 26, 2009 | 2001 Hyundai Tiburon
Washing machine door wont open
well, Either clip on the door is faulty or its the door interlock in which the door locks into easily replaced by undoing the clip pullling back the door rubber and replacing ..
Jul 19, 2008 | Washing Machines
Asko W6021 Front Load Washer Logo
27 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
marley mcelhinney
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
