Question about Utilitech Pro 180-Degree 2-Head LED Motion-Activated Flood Light MST18
Light is installed and working but switch will not move from test
Utilitech pro #0459228 is installed and working but the switch will not move from test
    Top Expert:
  • Utilitech Pro Master
  • 34,206 Answers
The switch may be defective and will have to be replaced.
Posted on Mar 28, 2014
I HAVE A UTILITECH PRO 180 #0205881 AND IT BLINKS WHEN ITS ON
Usually when a motion sensor light blinks LED or otherwise it means that the motion sensor is shot. The light itself is most likely good and for whatever reason you got a bad sensor upon purchase.
Feb 21, 2014 | Utilitech Pro 180-Degree 2-Head LED...
Utilitech pro submersible pump has good electrical connection but pump won't start
There is a starting capacitor on the motor pump, check this out if faulty then replace it.
Dec 28, 2013 | Utilitech Plumbing
My Utilitech Pro will come on, after a few seconds it will blink twice and then will not come on again for several days.
Sounds like the sensor has failed. The controls are supposed to be on the underside, and kept dry.
Nov 24, 2013 | Utilitech Pro 180-Degree 2-Head LED...
My utilitech pro led flood light is now constantly flashing. I turned off the breaker for 10 minutes and it still flashes. There is no reset button only a test switch. Any ideas?
I know this is an old post but in case it helps someone else:
I had the same problem. On the sensor head (the bottom part of the light), you will see a plastic dome that can swivel about 360 degrees. Just behind that is a tiny dot maybe 1/8 inch in diameter. If you cover that dot with several layers of white tape the flashing stops and the light stays on. This defeats the dawn to dusk functionality because the light will always think its nightime, but I can always turn it off using the switch in the morning. The light is extremely bright when it is on, but many people struggle with the sensors never working right. If I hadnt already siliconed the light to my siding block, I would try to bypass the sensor altogether. For now the tape at least stops the flashing and I have light.
Oct 05, 2013 | Utilitech Pro 180-Degree 2-Head LED...
We installed 2 dusk to dawn lights and they keep flickering on an off, randomly, throughout the night.
They flicker because the light is reflected onto the photo cell. Sheild the photo cell from whatever may be reflecting the light such as a building wall or over hang.
Sep 16, 2013 | Utilitech Pro Home Security
I lost my instructions for my Utilitech #0357930 timer. I cannot get it to work; I can set it to start but not stop. Just need some directions. Buttons on it are On, Off, Day, Hour, Min, Enter, Pro
The AutoChron 81000 Programmable Wall Light Switch Timer is identical to the Utilitec #0357930 (AmerTac) TMDW50L. Here are links to manuals for models prior to and as of 2012.
Before 2012
As of 2012
Nov 28, 2012 | Hardware & Accessories
Installed Utilitech 192773. The lights work for test. Now nothing works.
Review the manual and wiring steps shown following link:
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
If timer has gone bad, buy new timer and return defect in new package.
Timer comes with limited 1 year warranty
Apr 07, 2012 | Intermatic Inc. ST01C Digital In-Wall...
I have tried to install the Utilitech timer but am having trouble. I have a ground, black, and red wire that were previously wired to a switch that controlled my outdoor garage lights. I tried to hook red...
Sounds like this was probably a three-way switch you are replacing as there is no neutral (white) wire in the box. If so, you can splice the white wire to the green wire in other three-way switch box; then hook the green wire in the box you are placing the timer to the white wire of the Utilitech timer.
Apr 17, 2011 | Intermatic & Self-Adjusting Wall Switch...
Utilitech Wall Timer #0192773 does not switch landscape lights on? Replaced Intermatic that had 3 wires. Black to Black, blue to black and red was capped. Utilitech came with 4 wires - black, white,...
Old timer: Intermatic EJ500 & ST01C timers have a battery. Battery operates the clock motor. Red wire is for 3-way circuit [a hallway with 2 switches is a 3-way circuit].
Utilitec timer, clock runs on 120Volt circuit instead of battery. So clock has to have power.
How to connect wires:
Black timer wire connects to hot wire from breaker box.
Red (or blue) timer wire goes to landscape lights.
White timer wire connects to white neutral wire [or if no neutral is available, connect to bare ground wire].
Green timer wire goes to bare ground wire.
How to find black hot wire and white neutral wire inside box
: Disconnect and separate wires so you can test. Use ordinary tester. Power is on. There is only 1 black hot wire inside each electrical box. Test each black wire to bare ground until tester light comes on > that identifies the black hot wire. Next, test black hot wire to white wires until tester light comes on > that is the neutral wire. Exception: This test does not necessarily work with 3-way switches since they reverse each time switch is thrown.
Sep 14, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Utilitech Pro 180-Degree 2-Head LED Motion-Activated Flood Light MST18 Logo
362 people viewed this question
Top Utilitech Pro Home Security Experts
Lawrence Oravetz
Are you an Utilitech Pro Home Security Expert? Answer questions, earn points and help others
