Question about Chill Pill Audio Audio Players & Recorders
Not working used to light up and work ... now nothing when plugged in port
  • Chill Pill A... Master
  • 3,320 Answers
If the speakers used to work and now do not turn on either the power switch is broken or the battery is dead. Warranty or garbage can.
Posted on Mar 29, 2014
When I plug it in to charge it does nothing. No lights the gauge doesn't move . Any ideals ? She have had problems like this for years off and on . They send out a repair man and it will work for a short...
Could be the charger or the charger port. Do you have the offboard charger that plugs into the joystick or an onboard charger? I would suggest trying to find an offboard charger from a friend or your provider that you can borrow and plug it into the charger port under the front of the joystick to see if it will charge the batteries. the meter will not work if you use an offboard charger the lights on the charger will turn green when it is fully charged. when the charger is plugged into the joystick and you turn on the chair the lights should scroll indicating you have the charger inhibit function working and hopefully the chair is charging. If you can charge the chair with the offboard charger then look into buying one and using it instead of trying to get the onboard charger working Hope this helps
Mar 04, 2011 | Jet 3 Ultra Power Chair
I seem to have a touchy USB connection, when I first got the Belkin and plugged my printer(s) into it, nothing happened, no connection light etc, after about 3 days I got it to light up, and it was fine...
The issue might be the port is broken, please try using another port to see if the issue persists. If it doesn't then the port it was previously connected to is broken and probably have to be plugged in at a certain elevated angle to work
Jul 11, 2017 | Belkin Wireless Share Router (F7D3302)
One of my Acer Aspire USB port will not let me
It is most likely that the Port has been damaged by having the wrong cable plugged into it. If one Port is still working, there is nothing wrong with the Computer.
With a Flash light, look inside the Port to see if any of the Contact Points are bent or damaged. If they are, there is only a slight chance that the Port Can be Repaired.
It will probably be cheaper to buy a 4 Port USB Hub and use the one Port with it.
Good Luck!
Dec 22, 2009 | Acer Aspire One PC Notebook
Nothing works on my wireless mouse. Even the red
have you tried to charge it, if so you know there's an on/off switch on the mouse.
Nov 04, 2009 | Computers & Internet
Microsoft wireless mouse 3000; put in new battery, still nothing
nikcorra2488,
try this: plug in the USB key & check for the green light. Then go to start, control panel, & double click mouse (with whatever mouse works). Check the hardware tab and see it the computer is recognizing that the mouse is there. If it is there, it should be working fine. If not, then perhaps you need to reinstall the USB port drivers. Sometimes this will happen when you've upgraded from 1.0 to 2.0 USB ports.
Hope this helps.
-samson39
Jul 26, 2009 | Microsoft Wireless Notebook Optical Mouse...
The whole thing started when my keyboard stopped working. I unplugged it and plugged in the keyboard from my daughter's computer and it worked - yay! But, not so fast, then my daughter needed her keyboard...
USB port is plug-and-play, however, PS/2 port is not.
therefore, what you have to do is shunt down the computer and plug in the keyboard, then fire up the computer.
once you unpluged the keyboard. and plug it back again, the computer will not recognize the keyboard is attached, but it knows when the keyboard is disconnected.
Apr 01, 2009 | Gateway ( 7004449)...
Full red ring, when plugged into usb ports on front of machine
you can use the usb on the back of the console but its NOT reccomended
4 red lights on the console means the AV lead is disconected so push it in try again and if it doesnt work use the back USB port
Dec 17, 2008 | Microsoft Xbox 360 Console
Microsoft wireless notebook optical mouse 3000 Doesnt seem to work?
Okay, a coworker had this problem and it was a fairly easy fix, first, plug the USB reciever into a direct USB port, then pess the connect button on the underside of the mouse, when the red light starts blinking let go and then press it and hold, and at the SAME TIME press and hold the connect button on the receiver until both the receiver light and the mouse light turn on steadily, and voila!
Aug 04, 2008 | Microsoft Wireless Notebook Optical Mouse...
Top Chill Pill Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Chill Pill Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
