Question about Sole Fitness Sole F85 Treadmill
Sole F85 treadmill is making alot of noise when in use running on the treadmill and the spped of 4.5
Treadmill making loud noise
Fan not working
Your display pcb board needs replacement.....call sole for service
Dec 24, 2013 | Sole Fitness Sole F85 Treadmill
Electronic display in rotation
If youre meaning that the buttons do not function this could be caused by sweat getting inside. Replace electronics inside or entire console.
Sole F85 Hand Rail Incline Adjustment Switch is not working
The hand rail switch contacts can be worn out. The more likely problem is a broken wire by the arm. Remove the cosmetic covers by the hand rails and check for broken wire. If wires are not broken replace the switch.
Aug 12, 2013 | Sole Fitness Sole F85 Treadmill
Sole F85 treadmill fan and hand controls not working
There may be two problems, however, I would suggest you replace the main display pcb. That will fix the fan problem. If the handle bar switches still do not function replaces the switch and wiring.
Jan 30, 2013 | Sole Fitness Sole F85 Treadmill
Sole treadmill says "INITIAL" on the screen and won't run. This occurred after I removed the magnetic emergency stop switch.
Normally you must put the key in the hole, after you press the button start and ready.
However I recommend you to follow the instr. manual for easy start. Since that every manufacturer has a little diferrent mode of start. If you do not have it download free from
www.fitness.manualsonline.com
God bless you
Dec 17, 2012 | RTO Sole Fitness Package F85 Treadmill &...
F85's "low speed" error
Dear Sir:
1) Lube the deck belt very well, as your instruction manual indicate for maintenance.
2) Try to Run software calibration after you fix it. For easy diagnose and troubleshooting.
3) The elevation motor can be faulty for lack of maintenance too, again Run the software calibration.
sincerely. God bless you
Apr 13, 2012 | Sole Fitness Sole F85 Treadmill
Operating manual sole e35
go to www.iconservice.com for free download
or http://fitness.manualsonline.com
Good luck,sincerely. G-d bless you
ERNESTO CUADRA
MANAGUA,NICARAGUA
Dec 12, 2011 | RTO Sole Fitness Package F85 Treadmill &...
Sole Fitness Sole F85 Treadmill Logo
77 people viewed this question
Top Sole Fitness Exercise & Fitness Experts
Art Wilson
Art Wilson
Level 1 Expert
Electro Med Services...
Brett Duxbury
Brett Duxbury
Are you a Sole Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
