Question about GPS
Garmin external power problem
It says i have lost external power how do i fix this problem
  • 210 Answers
Plug the charger back in ..... if you dont want it to show the message every time the charger is removed , this can be turned off in the sttings
Posted on Mar 29, 2014
Garmin 1490 lmt
Use a volt meter and make sure the voltage at the oulet inthe car is at least 12.5-13.8 volts DC
Apr 27, 2012 | Garmin Nuvi 1490LMT GPS Receiver
Battery power trouble
I have discovered an intermittent problem on my 10 year old 295 when powered by batteries.
It appears that the chrome plating is de-laminating from the battery contacts that are either side of the back panel attachment hole. At first glance it looks perfect but if you run a fingernail or other small item across the face of the contact you will see and hear a movement as if there a a loose layer of foil over it. This is causing all manner of faults including 'external power lost, shut-down in 30 seconds' when the external power was not even connected at all!
Jan 03, 2009 | Garmin GPSMAP 295 GPS Receiver
Garmin gps error message external power lost
forgot password for garmin 205
Dec 31, 2008 | GPS
How do i charge garmin nuvi 250 on my computer
HI,
I have the problem solved I at first had this problem after about 5 minutes of messing with my GARMIN NUVI and having many electronic gadget I thought about diffrent buttons to hit at the same time heres how you charge your NUVI with a computer and a usb cable
1st: make sure your NUVI is OFF then plug in the usb cable from the computer to the NUVI, after you hear your computer ding from new device connected, and the NUVI displays the computer icon move to step 2
step 2: if you have xp go to START and MY COMPUTER. with vista its START then COMPUTER button on the right side
step 3: with MY COMPUTER window open hold the NUVI power switch to the ON position and RIGHT CLICK the NUVI device logo (blue triangle) and select EJECT .. ( DON;T HIT SAFiLY REMOVE)
step 4: when you see GARMIN display on the screen you can letgo of the power button on the NUVI ****** if you unplugthe usb it will display message stating EXTERNAL POWER LOST SWITCHING TO BATTERY POWER***** while it is plugged to the computer the battery meter will disaper
Nov 09, 2008 | Garmin nuvi 250 GPS Receiver
Cannot register Garmin Nuvi 250 purchased today
Can anyone help me in registering garmin nuvi 255W? Also, once I connected the USB, I keep getting "External Power Lost". Is this always the case as the USB is connected?
Oct 31, 2008 | GPS
Streetpilot c340
Usually when it says External Power Lost, it has lost the signal between the power cord and the unit (the car was turned off while the unit was plugged into the socket and on or you pulled the plug out while the unit was on). If you are receiving this message and one of the above situations has not occured, you may have a problem with the cord, the fuse or the vehicle's power socket. Under what circumstances are you receiving this message?
Apr 11, 2008 | Garmin StreetPilot c340 GPS Receiver
GPS GARMIN 340 turn it off by itself.
Does the unit comes on by itself once power is applied to the unit? If it doesn't come on by itself, then there is a problem with your power supply. The unit is designed to detect when an external power supply is applied and turn itself on. It is also designed design to detect if you unplug the unit from the external power supply. It will say "Lost external power, shutting down in 30 seconds". BTW are using Garmin cables?
Dec 25, 2007 | Garmin StreetPilot C330 GPS Receiver
GPS Logo
78 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
