Bauknecht WA 3700 bearing replacement parts
My BAUKNECHT WA 3700 has become progressively more noisy when the drum is rotating and it seems the bearings are up for replacement. I found the inner/outer bearing and seal for 5-10 quid each online but I'm not sure whether I would also need the DRUM BEARING HUB which is around 77 quid on ransomspares. Does anyone know how likely it is that I will require the drum bearing hub. If it is required it is probably not worth repairing.
  • 139 Answers
SOURCE: bearing noise
Hi there im the wash docotor. With your zanussis once you have removed the back half of the pannel and the top pannel. you will have to then detach the motor wire plug. then the heater wires and also the there is a sensoer on the side of the drum that also has a wiring connection. Also detactch the earth wires Then here come the tricky part. if you look on the top of the drum you have a rubber pipe connected to it comming from the washer draw detach that its easy. Then you have to dicconect the door seal from the front of the machine by the door (do not dissconect from the seal from the drum as you dont have to . Then disconnect the the drain hose. once this is all done you have to disconnect the legs, from the drum side. these are easily done as the pegs come out easily if you push in the pips from one side you can either knock them out with a hammer but it is best to pull em out with either some long bent nose pliers or gripping em in such a way with a monkey ranch Best way og getting the drum out is once you have done all that is to turn the machine onto its back and lifting the casing off leaving the drum on the floor.
Posted on Oct 10, 2006
  • 1263 Answers
SOURCE: 2002 Mazda Protege 5 Hub Bearing Replacement
which hub the rear or front?
Posted on Sep 01, 2008
  • 124 Answers
SOURCE: noisy front wheel bearing
Yes the bearings can be changed on this truck. The bearing races will need to be removed from the rotor to do this use a punch and hammer once the rotor is removed. You will need inner bearing and race, outer bearing and race, and a seal, plus grease to pack the bearings. The hub on these trucks is the rotor. Please rate.
Posted on Dec 12, 2008
  • 14 Answers
SOURCE: Duet GHW9150P inner SS drum is actually loose but
go buy new washer the drum bearings have gone and it really is not worth repairing . it can be repaired but always found that it never lasts long once done.
Posted on Jul 07, 2009
SOURCE: Audi a4 1.9tdi quattro front wheel bearing noisy
hey codycarroll, if it makes you feel better; I did the same thing, my audi fell off the jack and the brake rotor(with the weight of the car on it) landed on my foot and then rested there....not fun for the next 2 minutes of extreme panic and pain!
Posted on Nov 07, 2009
my BAUKNECHT WA 709 709 SC washing machine doesn't work what should I do? no one could fix it
Aug 27, 2012 | Washing Machines
Don't understand the pictograms describing the washing cycles...
Type the model and name into a search engine..Some Bauknecht machines are also sold as Whirlpools...Check the website for them as well....Good luck...Nomess
Apr 18, 2010 | Washing Machines
Hi my Bauknecht GSI 5411 dishwasher seems to starting ok but then it stops after a couple of minutes. have checked the water supply tap as well as the filter and they seem to be ok. Please help
Set the machine to the end of the drying cycle, when it has finished, try pouring boiling water into the machine about a kettle full there is a sump level control beneath the removable filter (where all the **** gathers) if this has fat deposits on it this type of problem can occur.
Nov 05, 2009 | Bauknecht 24 in. GSX7551 Built-in...
English manual
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 28, 2009 | Washing Machines
Bauknecht washing machine fault
Had the same problem myslef yesterday. Have rung whirlpool this morning and they advise that the code F7 refers to a short circuit.
May 27, 2008 | Washing Machines
Bauknecht Washing machine
the bearings seem to be gone in drum
Dec 18, 2007 | Washing Machines
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
