Question about Epson Stylus R265 InkJet Photo Printer
Canon R265 keeps grabbing 6 sheets for printing one sheet
The r265 keeps grabbing 6 or 7 sheets at a time when I only want to print one copy off. It does not print on the other sheets, they all come through at the same time
  • 53 Answers
Paper has different thicknesses called Mils. Make sure you are using the correct paper for your printer. Paper that is thinner than is intended for your printer may sometimes cause it to take multiplesheets.
Posted on Jun 15, 2009
Hi, my canon ip2600 printer is grabbing multiple sheets of paper when printing instead of a single sheet at a time. It prints but some lines of print in the final result are to compressed to be almost...
the printer is grabbing multiple paper because the paper is stuck together in cold times the paper sticks together when you insert paper into the paper try try to make the papper loose
Mar 01, 2011 | Canon Pixma iP2600 Photo InkJet Printer
My praftically brand new Canon Pixma MP620 printer grabs more than one sheet of photo paper and stops printing picture on first sheet then garbles several pictures on a portion of the next sheet. I just...
check the printer's printing preferences on properties option.should be set to normal then check the printer rollers if its dirty where the papers pass thru, if the problem persists load only 1 paper every time you print for the printer not to grab more papers.i think it is in the feeder and the sensor maybe its dirty need to be cleaned up.
Feb 22, 2010 | Office Equipment & Supplies
Printer won't respond to scan command (pixma mp450) and keeps telling me the cover is open when it is clearly not!
Press the OK button to
exit the error, and do
the print head
alignment again (from
printing of the print
head alignment sheet),
while confirming the
following:
- Set A4 or LTR size
plain paper.
- Confirm that the print
is printed properly
(no smear or nonejection
of ink).
- Fill in all the
applicable boxes in
the printed sheet.
- Place the sheet on the
platen glass in the
correct position and
orientation.
Oct 08, 2009 | Canon Office Equipment & Supplies
COPIES PAPER BUT PRINTS BLANK SHEETS
You probably haveing poblems with laser shuter. call service
Apr 15, 2009 | Canon Laserbase MF6530 All-In-One Printer
When I print on my Canon MP730, it always prints out a blank page after every print job. How can I fix this?
SOLUTION(S): Reset the Sheet Feeder Gears
If the power fails while the paper is feeding or during a print job, the paper feed gears will lose their proper
alignment. The reason is that after the power is restored the paper feed gears will attempt to return to the
home position, which may not be possible if the paper stop cam is not in the correct position.
PROCEDURES
1. Remove the sheet feeder from the unit.
2. Remove the sheet feeder motor from the sheet feeder assembly.
3. Remove the drive gear from its spindle.
4. Realign the lifting tray gear and paper stop cam gear.
5. Reinstall the drive gear and sheet feeder motor.
6. Reattach the sheet feeder to the print unit.
7. Reassemble the unit.
Jan 11, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
CLC 4000 - Looks like Scratch marks in printed sheets
Is it from the copy board glass or the printer part? Doses it show up in all 4 color making a neg copy in each color. If it shows up in the same spot on each color it could be the opc or transfer sheet. Also does it repeat it's self down the page.... Marks can come from one of three places.... opc,transfer,fixing... Need more info...... To broad of a Question
Jul 23, 2008 | Canon CLC 4000 Copier
Printing
Placing one sheet at atime is worse usually as these units feed off a minimum level. Keep them topped up to at least no less than 10 sheets. The printers sound like the have a paper feeding issue. Could be a jam. Open unit, check for paper jam. Cheers lilacgerry xxx
Sep 13, 2007 | Canon PIXMA MP180 All-In-One InkJet...
Epson Stylus R265 InkJet Photo Printer Logo
107 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
