Question about Fujitsu Fi6130z Sheetfed Scanner
Vertical blue line on scans - Fujitsu Fi6130z Sheetfed Scanner
    New Friend:
  • 25 Answers
Could be dust or some kind of dirt in window or the optical unit. Clean both upper and lower window. Furthermore you need to take apart and clean the optics.
Posted on Apr 21, 2014
Why my t.v screen is one inch less from down side?
Vertical scan output section circuit fault.
Visit this site to get more details.
Feb 19, 2015 | Televison & Video
Picture went black except for partial green and blue lines &2 thin red lines
Vertical scan section circuit fault. Check and replace damaged component/s at its vertical scan output section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 17, 2014 | RCA MM36100 36" TV
Actually the model is cs-313050. its quite old. the problem is that the tv won't work in the way that when you turn it on (it won't even turn on anymore) there is nothing but a white or blue lineright in...
you didn't mentioned if it is a horizontal line but i think it is.
It seems that you have a faulty vertical I.C. that scan vertical line.Because you it is defective you've lost the vertical scanning thats why you have only a horizontal line on the screen.
You will confirm it by powering on the unit with your cable signal present.When the sound is present on every channel it is confirm that you have a problem on the vertical section. You must look for a qualified technician to solve the problem....
Jan 02, 2011 | Mitsubishi CS-40503 TV
There is a horizontal line in the mid
Hello
The vertical scan of your TV has failed. All picture tube type TVs have both horizontal and vertical scan sections to scan the picture on the secreen. When horizontal scan fails, you will see a vertical line at the middle of the screen, and if vertical scan fails, there will be a horizontal line through the middle of the screen. In your TV, the second stated has happened.
This may be due to an IC trouble or a voltage loss inside the printed circuit board of your TV. To rectify this fault you have to open your TV, and locate the vertical output section inside it. It is very easy to locate that section. There will be four wires goes from the deflection yoke; the coil fitted at the neck of the picture tube; out ot which, two will be thick and the other two will be thin. The thick wires are usually colour coded as red and blue. Colour coding may differ from set to set. Anyway you have to follow the tow thin wires, as they are carrying vertical scan signal to the yoke.
Following it, you will reach to a plug in point on the printed circuit board. Upside down the printed circuit board, and follow the track through which that wire connection goes, and finally you will reach to the vertical output section.
There may be transistors or IC used on that section. First check the voltage at the vertical output section. Voltage lose also may occur in this section. If it uses IC, check for any loose or bad solderings at the terminals of the IC. I advice you to resoder the suspected points by applying a little more solder, without shorting the terminals. In most cases this will solve the problem. If there is voltage, and there is no loose solderings and still the fault perists, replace the IC or transistors, whatever it may be, with same type and number.
If you want anymore asistance, fee free to contact me through Fixya. OK.
Dec 27, 2010 | Toshiba CF30F40 30" TV
Tv powers up, but just a thin blue strip on the screen??
which way ?
horizontal line suggests vertical amp failure - dry joints, etc.
vertical line is horizontal scan circuit failure - dry joints, component failure - don't run this too long or it will get expensive
Aug 10, 2010 | Televison & Video
Vertical lines when using document feeder to scan
you may have dirty glass on scanner or the feeder rollers are dirty or need replacement.
Jun 02, 2009 | Canon PIXMA MP750 All-In-One InkJet...
Vertical blue line from top to bottom
I was told by one of you that the reason was bad drivers and to remove the software and reinstall it again. Bad advise. The blue line is a sign of dust. We cleaned the unit and the blue line dissapeared. I wasted $15.99 for bad service.
Nov 03, 2008 | HP Scanjet 8250 Flatbed Scanner
Hitachi 42HDS69 Blue Vertical Lines
I think that you have dry solder joints on either the vertical scan board, the focus board, the line output stage, or the chroma panel. Hope this helps.
Sep 13, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Vertical blue line in display PS3
Alright, I do believe i have a solution. But i need to know the brand of TV you own, how old it is, and If your using an adapter, or the regular "Yellow, Red and White" cords.
Nov 29, 2007 | Sony Playstation 3 (PS3) Console
Fujitsu Fi6130z Sheetfed Scanner Logo
229 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Smidler
Level 1 Expert
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
