Question about Fujitsu Fi6130z Sheetfed Scanner
Scratch on glass
Line on scan
  • 210 Answers
Replace glass or try to remove the scratch if its showing up on every scan
Posted on Mar 29, 2014
Blue line on scanned page in epson 1500
You either have a scratch on your glass, or your scanner is going bad.
1. Clean the glass, then scan again. If you still have that line, Wipe the hell out of the glass and blow air through the calibration holes. If that doesn't work, take it back and get a replacement. The scanner is not working correctly.
Apr 03, 2014 | HP Scanjet 8250 Flatbed Scanner
Horizontal line on all pages after scanning
Open the cover and clean the glass on the top and the glass on the bottom. Use a soft cloth. You can slightly dampen the corner of the cloth with water and rub them clean. Inspect the glasses for deep scratches.
www.scan-r-store.com
Aug 14, 2012 | Fujitsu fi-6130 Flatbed Scanner
My canon 6080 leaves a thin black line on everypage scanned. is there a way to fix this?
Clean the glass thoroughly with a damp cloth. Dont use solvents. Check if the glass is scratched, if scratched you may need to replace it.
S. Mohan
Aug 26, 2010 | Canon DR-6080 Path-Through Scanner
What causes a line down the middle of copied pages
There is something on your scan glass. My guess is you are getting the line on your copies when you run the original through the document feeder. If you get lines through the document feeder but not on copies made off the glass then it is a dirty scan glass. There is a thin glass strip where the document feeder feeds the original. Usually something like white out that did not dry smears off an original and ends up on this thin strip of glass. Scratch it off with your finger nail and use some glass cleaner to resolve the problem. The scan glass is about 1/2 an inch to an inch wide and will be on the same side of the machine that the copier feeds the originals in on.
May 24, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
When i used the auto document feeder to scan, a line appeared vertically on the page when scanning is completed.
Check for a spot on the narrow glass, could be white out, or even a staple scratch, you need to clean that glass and also wipe the white guide that sits over the glass.
Oct 13, 2009 | Brother MFC-9440CN Laser Printer
Black Line when using sheet feeder
Open the cover over the scanning area and check the narrow strip of glass to the left of the platen glass. See if there is any foreign material there (dirt, whiteout, etc) and clean it gently with a damp cloth. You may find a piece of clear plastic covering that area. It's there to keep the glass from getting scratched. If the plastic is heavily scratched at that point, it can cause the line you're seeing. Removing the plastic will clean up the scans.
Jan 16, 2009 | Canon MultiPASS F80 All-In-One InkJet...
Black vertical lines on faxes sent using auto document feeder
If you lift up the lid on your scanning device you will notice a glass strip about 1 inch thick and then the large area of glass used for flatbed scanning. The 1 inch strip is used for ADF scanning. Because your papper is moving across the glass strip, any dot, smudge or scratch will affect your scanning and cause verticial lines down the page. Sometimes the dot is not visible to the eye. Get some glass cleaner that has alcohol in it and thoroughly clean the glass strip and it should solve your problem. If it turns out to be a scratch on the glass then cleaning won't help.
Nov 15, 2008 | HP Photosmart 375 InkJet Printer
Line on far right of scanned documents
Most likely the scanner has dirt on the glass that is over the imaging array or the glass may be scrached. If the glass is scratch, the imaging CCD array need to be replaced. If you do not scan the rear of your documents, you can swap the upper with the lower in the case that one is scratched.
The imaging array are the green long bars, one at the bottom of the paper path halfway inside the scanner and the other is above it. Look closely for a small spot of black toner or dirt stuck
on the glass. Take a soft cloth, wet it with water or alcohol if needed and clean the glass.
Pass you finger over the glass, try to feel if all of the toner or rubber residue has been removed.
You might try looking at the specific area were your documents image is getting the line. It will
help you pinpoint where you should clean. CAREFULL not to push on the glass as this
might break it. Hope this helps.
Otaron
Sep 08, 2008 | Kodak Digital Science 2500D Path-Through...
Streaks in image scanned by Canon DR-2580C Path-Through
The staples cannot reach the sensors. They could have scratched the glass above the sensors. Clean the glass with IsoPropyl alcohol. Try scanning a few images to find if the scratch marks are on the same place on all images. Once confirmed that the glass is scratched, you can change the glass. You need a technical expertise to change or call service staff.
May 29, 2008 | Canon DR-2580C Path-Through Scanner
Line on Scanned Documents
There is a spot on the thin strip of glass that sits next to the large scanner glass. Because you are moving the paper when using the feeder, a spot appears as a line. Shining a flashlight on the glass can help you locate it. You can scrape it off with a finger nail or clean it with a damp cloth.
May 09, 2008 | Office Equipment & Supplies
Fujitsu Fi6130z Sheetfed Scanner Logo
131 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Chris Larocque
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
