Question about Arris SURFboard SBG900 Wireless Router (DHSBG900)
Open port on 6580
Att microcell wont work with new modem
  • 3,320 Answers
Where is port 6580?
Posted on Mar 29, 2014
My Linksys WRT310N Wireless Router was already configured to be an access point (in Access mode). I have three cables that were plugged into the back. Can you advise me on this.
to ensure faultless performance, when I've connected an AT&T 3G microcell I've found it's best to take the cat5 from the modem, into the microcell and then into the router. you use the yellow port on the router as input
Dec 07, 2016 | Linksys Computers & Internet
My phone never rings it goes directly to voicemail and doesn't notify my until later
you have poor reception get a att microcell or equivalent
Apr 11, 2015 | Cell Phones
How do I view my foscam camera remotely? I have a macbook, motorola surfboard 6580, and a foscam camera. I can view the camera on my macbook while I'm at home but want to be able to view while I'm away...
you need to go in your router and open ports for that for mobile you need to know what port needs to be open and what DVR you are using than you have to download and app to your Iphone, you also need to open port 80 and go to canyouseeme.org there you should be able to see your public IP if you already did the setup if you put that IP on your browser you should be able to see it in your note book but you have to be in a different network not the one you are using....tekgods.com..
I’m happy to assist further over the phone at https://www.6ya.com/expert/jaime_08785c7d726a554e
Sep 13, 2013 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
How to install to att 2wire 2701hgb modem router
Plug one end of an Ethernet cable into the modem's Ethernet output port and plug the other end into the router's single WAN/Internet input port.
Nov 09, 2017 | NetGear RangeMax Dual Band Wireless-N...
Connection
It is an old phone but you may be in a place where there is bad connection. I bought a MicroCell from ATT to increase the connection in my house and now i have five bars every time. Check it out if you have ATT: http://www.att.com/shop/wireless/devices/3gmicrocell.jsp?fbid=e75M58W-RnL
Jun 01, 2011 | LG KM555 Cell Phone
Setting up a small network using DSL and a DLink router
1.) The setup needs changing
2.) first off the dss-24 is a network switch not a router
3.) all of your pc equipment should be pluged into that device.
4.) chose one port as an uplink to your att modem
I think your problem is that the new modem is only giving out one ip address. So what ever first pc is turned on that is the one that grabs the address.
5.) you will most likly need a router to take the one ip address assigned via att then dole out additional ones. Remember the dss-24 is not a router. It simply connects everyone together. Each device still needs an ip address given from somewhere. Your old cable modem probibly did that but your new att dsl most likly does not.hence the new router will do that.....
to set it up do the following
2.) Find out the ip setup needed for your dsl service
A.) gateway ip
B.) primary & secondary dns server ip`s
C.) subnet mask
3.) get into the setup of your new router and then plugg in
all of these values using a fixed if address in the router
4.) connect routers wan port to one of the modems port. u may have to use a cross cable or straight look at the link lites to find out if they are talking to each other
5.) make sure that the routers lan side is setup for DHCP
6.) connect one lan port off the router to an uplink
of the dss-24. Then reboot everything
7.) viola it should all work internet on evey machine and file sharring.
Apr 27, 2010 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
D-Link DIR-600 Router got a new account with att and my dlink wont work. it worked fine untill I had to set up a new account because of a late payment. I tried the install disc but no go all green lights...
Turn off everything and wait for a few minutes and turn on the modem and wait for the lights to be steady then turn on the router and lastly the PC... make sure also that the connection of the modem to the router is correct ( modem should be connected to the WAN/Internet port on the router)
Mar 27, 2010 | D-Link DIR-600 Router
I'm having problems tring to connect to ATT HS DSL, flashing green light but can not connect to internet, what settings on DSL-2640B do I need???
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Jan 07, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Modem says no dial tone, phone line is ok. Also USB ports wont work with flash drives.
plz check your pc for viruse then post your findings for further help
Jun 06, 2008 | Computers & Internet
Arris SURFboard SBG900 Wireless Router (DHSBG900) Logo
23 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
jimmy Leo
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
