Question about Car Audio & Video
Which RCA's do i hook my amp up to on this deck?
  • kakima Mar 28, 2014
    What make and model is "this deck"?
  • 637 Answers
Make and model please.
Posted on Jun 18, 2014
Can u hook up a audio amplifier to a stock deck in a 2005 dodge Durango limited edition 5.7 ltr engine if u can? were do I go for a diagram? Or a manual or video
You need to look at the back of the stock deck to see if it has pre-amp outputs. That would be RCA jacks. If it does, then the RCA jacks would plug into the power amp Input using RCA cables.
May 23, 2014 | Cars & Trucks
Sony XM-GTR4A
contact sony .... or check your head unit is recieving
Mar 29, 2014 | Sony Car Audio & Video
I have an old kenwood stereo system I forgot how to hook up it is a ka-87 amplifier a kt-57 tuner and a double deck cassette player kx-57w .Can anyone help?
Connect the RCA Outputs of the Tuner to the RCA inputs for Tuner on the amp.
Connect the output of the Tape Deck to the Tape Input on the amp.
Connect the input of the Tape Deck to the Tape Output on the amp.
Select Tuner on the amp to listen to the tuner.
Select tape Monitor to hear the Tape Deck(s).
Dec 30, 2010 | Audio Players & Recorders
Were do i plug in the RCA cables from the amp to a factory radio? do i need any sort of adapters if my stereo dose not have inn or outputs? and where do i hook up the remote from the amp?
Most factory radios do not have RCA outs, but most will have a remote wire. Usually used for a power antenna option. Your remote wire from the amp could be hooked to the power antenna wire on the factory radio and it would work great for turning on the amp. As for the RCA inputs on your amp, you will not be able to use them without RCA outs on your factory deck. Although most amps offer a high level input alternative and will use the standard speaker level out on your factory deck. This means the rear channel speaker wires from your factory deck will be used to feed the signal to the amp. You will have to check the instructions and manufactorer recomendations for the amp you are trying to hook up. Have fun and good luck!
Mar 09, 2010 | Stingpro ST444 1850 Watts Complete...
Will a amp work with this deck
you can get a amp to work on any deck although u may have to rig it a little bit all u need is sound coming from the stereo and if u will take the rca one end and cut it and strip it u have a wire inside each one and then u have ground wires surrounding the inside wire twirl them up like 1 wire and then strip back the inside wire hook that one to front left pos wire and hook ground wire to front laft neg and do the other rca wire the same just hook it uo to front right or if it has rca jacks on the back of the stereo just hook ur rca wires into them and to the amp
Feb 24, 2010 | Pioneer DEH-1600 CD Player
My subwoofers will not play
go into the menu screen on the pioneer unit and go to setting if you have a loud function there turn it on.... if that doesn't activate the amp ...(did you hook up the blue wire from pioneer deck to amp and run it threw the car to the amp)..if no than your pioneer deck does not realize there is an amp present in system....... if yes scroll threw menu till you see audio look for Sub Woofer or Amp you may even have a button on pioneer deck marked SW go press it and turn amp to on this will provide signal from pioneer unit to amp if this doesn't work other thing could be you hooked RCA to AUX input (but if you have a SW for RCA plugs on back of unit make sure the RCA wires are in it) the loud or SW button should activate it (if there is only F and R for RCA plugs on back of unit use R hope this helps)
Mar 04, 2009 | Pioneer AVH-P4900 Car Video Player
How connect amplifire ??
You hook the amp up to the deck with rca cables red and white. you have output rca on the back of the deck also the blue wire labled remote also goes to the amp to turn it on and off.
Jul 19, 2008 | Blaupunkt London MP37 CD Player
Hooking the mra-f350 to my highs
You will only need to connect the door speakers to the MRA-F350. In short, the connections will be as follows:
Deck---->MRA-F350 amp---->Door speakers
...................................\---->Sub amp---->Sub(s)
Just make sure you use the optical digital output of the deck to connect to the optical digital input of the MRA-F350 amp, not the RCA preamp connections.
Mar 13, 2008 | Alpine MRA-F350 Car Audio Amplifier
ADF-243 Amp
What you need to do, is also run the rca cable from the back of the deck to the amp. The speakers are already powered by the deck. You can then hook up your subwoofers. The switches are for your own taste.. you adjust them as you go.
Jan 30, 2008 | Audiofonics ADF-243 Car Audio Amplifier
Car Audio & Video Logo
27 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
