Pro 435pu Trying to connect macbook to pioneer elite pro-435pu via HDMI cable. when i goto menu->option to activate HDMI input, I can't click on "HDMI Input" option to enable the terminal. Says 'Current settings do not allow selection and adjustment' on the bottom. Please help
    Sergeant:
  • 361 Answers
That should find it automatically just turn your computer on and tv and set to hdmi 1 or whatever it should be there shoud no have to set anything up if it is a newer macbook pro or something , goto youtube if this does not work
Posted on Mar 28, 2014
My problem is getting a "This signal is not supported message" on an HDMI input into a Pioneer PDPR05G media receiver.
No need to understand - just read the message, It clearly states that the unit will not accept that particular signal because its electronics are not configured to deal with it. And that is it - end of story.
Basically, you cannot force a square peg into a round hole.
Mar 13, 2017 | Pioneer Televison & Video
Pioneer elite 2006 50" tv How can I change from
You can't change the resolution on the television itself. You change the resolution on whatever you have connected to the television. Let's say it's a cable box or a blu ray player you've got connected to the television. First off you have to connect it to the television with a component (green, blue, red, white, red) cable or an hdmi cable. Then you make sure it is only connected to the television with either a component cable or an hdmi cable. This may sound ridiculous but there are some people that have their cable boxes and blu ray players connected to their televisions three different ways ( an hdmi cable, a composite cable, and a component cable) when they only need to have it connected one way.
Select the proper input on the television. Set the cable box or blu ray player's resolution to 1080i or 1080p (in the case of the blu ray player if it the tv will allow it).
Apr 05, 2011 | Pioneer Elite PRO-1140HD 50 in. Plasma...
I have a Pioneer Elite Plasma TV style 435PU. I have Directv. I can't seem to get the television picture to come on because I accidentally hit a switch on the Directv remote control called "input" and I...
What you have done is change the input source. It will toggle through various modes like component, HDMI1, HDMI2, S-video etc., You should take a look behind the tv and see which input you have connected it into(usually HDMI 1 or HDMI2) then keep pressing the input button till it toggles back to that particular input.
Sai.
Mar 28, 2010 | Pioneer PDP-5060HD 50 in. Plasma...
Macbook Pro wont connect to Vizio tv
disconnect hdmi cable and shutdown pc, completely power it off. plug your hdmi cable back in to your pc and power it up. it should properly detect your tv. i use projector mode. tv must stay on while performing this procedure.
Feb 11, 2010 | Apple MacBook Pro Laptop Computer with...
How do I get TV to recognize audio from laptop....
Try the following:
1. Select System Preferences from the Apple Menu.
2. Select the Sound icon.
3. Click the Output tab at the top of the window
4. Highlight the option that is not the Internal Speakers.
5. Make sure the Output Volume is not set low and that the Mute checkbox is unchecked.
6. Close the Sound window. (via Red Radio Button, Top/Left of window).
Try it again and see if you get sound this time.
I hope this helps. Regards,
Feb 05, 2010 | Apple MacBook Pro Laptop Computer with...
I cannot get the Input 3 HDMI port to work. The Input 3 Componet videoworks, but when I unplug the componet video and put in HDMI port nothing works. I do have something else in the HDMI Input 1 port...
Hi.
To start ensure that each time you connect or disconnect the HDMI ports both TV and connected device are off.
Also ensure that HDMI input is active, as detailed here.
HDMI connectors carry voltage, and connecting the HDMI cable while TV or device is on may easily damage the HDMI port, making it unusable.
The HDMI 3 and Component 3 are separate input. The component input may work, and HDMI port may still be defective.
To test the port do the following:
Disconnect TV power cord, and connected device (eg. Receiver, DVD etc.).
Leave units disconnected for five minutes.
While power is disconnected, test connecting on port three a device that was previously working on HDMI 1. Also use a cable that you know is working.
Connect back power with HDMI cable already connected. If HDMI 3 is still not detected, then the port is defective.
In that case ring Pioneer at the number listed on the owners manual.This model is often advertised as only two HDMI inputs. Call Pioneer to ensure the third port can be enabled.
Dec 26, 2009 | Pioneer PDP-4350HD 43 in. Plasma...
How do I connect my macbook pro to a Pioneer Elite HDTV?
Newegg.com carries a mini-dvi to hdmi cable that
Item#:N82E16812200375 it's listed as "StarTech MDVIHDMIMF Mini DVI to HDMI Video Cable Adapter for Macbooks and iMacs"This should hook directly into one of your HDMI connectors on your HDTV.
Hope that helps
Oct 31, 2009 | Apple MacBook Pro Laptop Computer with...
Digital Audio Output Problem
connect the optical line from the DTV box to the audio system directly.
Sep 24, 2009 | Pioneer Elite PRO-1540HD 60 in. Plasma...
Receiver: Pioneer Elite 72TXV Verizon
Called Verizon automated help desk. They rebooted DVR remotely and solved the problem.
Mar 28, 2008 | Pioneer Audio Players & Recorders
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
Electro Med Services...
