Question about Universal Remote Control Televison & Video
Lauson code I have this Lauson small remote, with nine buttons and I don't know how to search and memorize the frequence for the tv. can somebody help? it's quite handy, thanks
    Top Expert:
  • Universal Re... Master
  • 74,198 Answers
Programming procedure is too much to type in here by this window, and is not practical. If you wish to get details; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Posted on Mar 29, 2014
  • 50 Answers
SOURCE: emerson tv codes for GE RM-24930 4-Device Universal ...
check this site for your codes. (Jasco is GE)
http://www.jascoproducts.com/support/universal-Remote-codes.asp
Posted on Nov 18, 2007
dauphine
  • 207 Answers
SOURCE: Magnavox TV all in one remote code
http://www.urc.philips.com/
Posted on Apr 29, 2008
SOURCE: philips universal remote control SRU 1060 code for toshiba tv
Try with this.
Turn on the tv.
Press and hold the CODE SEARCH button until the red indicator stays on,then release the Code search button.
Press and release the desired mode button ( tv,vcr,etc. ) The red indicator blinks,then stays lit.
Enter the 4 digit code from the code tables.0517,0419,0512,0613,0719,0112,0506,0111,0618,0627,0437,0041,0094,0802,0313,0715,with one of this codes your tv can operate.
With your device on,press CHANNEL UP .If the device responds,no further programming is required.
Good luck
Posted on Oct 09, 2008
AvioriX
  • 689 Answers
SOURCE: PHILIPS CL034 UNIVERSAL REMOTE
Hi
I am attaching a link that you can obtain free user's manual which contains step by step instructions and code list. Click on the link below
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/1500115_AD_EN.pdf
Good Luck
Posted on Nov 10, 2008
Repair manual mountfield cultivater m1
Does this cable have a small lead end ? Turn it vertical and slide it
into a spiral shape on carburetor the cable should pass through a groove facing the operators handle. Don't cut the lead end in anyway it won't work for you if you do.
Apr 22, 2014 | Mtd Garden
Tv codes
If you wish to get more details, check the links given below. Setup code list and setup proceedings to many popular brand remote controls are given. Pull up older posts there. You can also make a search by type in the brand name of your device into the search box, can be located at the top right of the display window. More than Nine Lakh viewers cannot be wrong.
May 08, 2013 | Universal Remote Control DIRECTV Universal...
GREEN POWER LIGHT/BACKLIGHT ON. NO DISPLAY, NOTHING
If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine Lakh viewers cannot be wrong.http://electronicshelponline.blogspot.com/
May 07, 2013 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
How do I get my att&t u-verse remote control to recognize my 51 inch samsung TV?
The remote can't recognize the tv, it doesn't have that capability. If you want to use it to command that tv you must program it accordingly. Basically you must introduce the code that corresponds to the set of commands that your tv uses - if they are present in the remote.
This is the programming procedure:
1 - hold down the TV button on the Uverse remote. As you are holding the TV button, press and release the OK button. You know you have done this right when all the mode keys flash twice.
2 - Find the 4 digit code for your device in the User guide that was given you when the Uverse was set up, or online at
https://www.att.com/support_media/images/pdf/uverse/set-up-code-list.pdf
3 - At this point, the TV mode button should flash three times. Try to turn the TV off by pushing the power button. If it does not turn off, try a different code. If it turns off then turn it on with the remote and test the other buttons. If they don't work then try a new code.There are a lot of codes for Samsung in there, try them all until you find the one that has the best compatibility - most buttons that can be used.
4 - If none of the codes for your device work, try manually searching for a code. Go back and repeat steps 1 and 2. Then enter 922. Hold play as the remote cycles through various codes. When your TV turns off, push enter to memorize it. This generic code will provide just a basic control, if you really need full control then you will need another remote.
Jul 02, 2011 | Televison & Video
How do i set radio stations on my car stereo j.v.c. kd s6060
Select radio from the source and select FM as the band. Now use an auto search or a manual search and as the signal locks you can hold on the preset button ( start from1) to be memorized on the set. you can repeat this for all the other stations. Punch in the frequency if you know it and memorize.
Feb 08, 2011 | JVC Car Audio & Video
Purchased the Deluxe Universal Remote item# 175056 from the 99 Cent Only store however it's missing the instructions from Deluxe Imports the local distributor. Does anyone have any idea how to program...
The followings are using TV device as example:
If you know the TV code:
Turn on TV -> Press and Hold [Code Search] button until the indicater light is on then release -> Press [TV] button -> Enter the 3-digit TV code to see the indicater light off to complete.
(You may want to test it using the [Off.On] button to see if the TV is turned off.
If you don't know the TV code:
Turn on TV -> Press and Hold [Code Search] button until the indicater light is on then release -> Press [TV] button -> Press and release [Off.On] button as many as 200 times until the TV is turned off -> Press the [Enter] Button to see the indicater light off to complete.
Dec 08, 2010 | Televison & Video
Philips universal remote control SRU 1060 code for toshiba tv
Try with this.
Turn on the tv.
Good luck
Oct 09, 2008 | Televison & Video
Universal remote wont work with this TV
Questions: Who is "Sansui", the digital box ? or the TV? Is the "digital box=remote control"? turn on what you want to control.
Face the RC face down or away from TV,or whatever you want to control. Usually:: push & hold TV & SEARCH button until light blinks, two, three times? FACE THE TV and put the code for the [TV=Sansui ?] You said #189 try 0189 [zero,one,eight,nine]
2nd) TV power ON!,....HOLD down (and if you have a SEARCH) button and the tv power button on RC, two or three blinks, push up arrow once, press power button for TV on RC, nothing!, continue...up arrow, power button. when the TV turns off, you have found the code,. YOU MAY HAVE TO DO THIS 50-150 TIMES because the RC is looking through EVERY code!
Sometimes
Apr 26, 2008 | Sansui CDVD1300W 13 in. TV/DVD Combo
Codes for Philips 4 Device Universal Remote, Model US2-PM435S
Try this:
turn on the tv manually,then push and hold CODE SEARCH button until the red light stand still now release the button push and release the device button TV after that you got to push and release the ON/OFF button until the tv goes off stop.Now push the enter button to memorize the code check if the tv turn on with the remote.
You have to get some patience because you need to push the power button between 1 to 110 times.Good luck
Apr 17, 2008 | Philips 5-Device Universal Learning Remote...
RCA Universal Remote
If it is a RCA remote then look here:
http://www.thompsontv.com/rcarc.html
If not I need to know the brand.
Nov 02, 2007 | RCA Universal Remote 3 Device Remote...
Televison & Video Logo
128 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
