Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Frigidaire dryer, model leq1452kso, does not start
Dryer does not start. all lights to the right, ie. drying, cooling down, press saver, etc., flash and beep 3 times, all at the same time and does not start
    Sergeant:
  • 361 Answers
Some of these dryers have a fuse on them , I think that what it is or bad switch so ck for power to it ,
Posted on Mar 28, 2014
  • 36 Answers
SOURCE: Duet Dryer will not start, Press control on, Start, then it beeps
try tripping your circet breakers dont assume that just because it lights up both lines are working you can have a partial tripped breaker and just be getting 110 to the drier its easy enough to just go ahead and reset the breakere if that dont work get back to me
Posted on Dec 28, 2007
VOTIT
  • 2071 Answers
SOURCE: Whirlpool duet dryer
The dryer uses multiple thermostats to regulate the temperature. When the temperature is higher than the preset limit of a particular thermostat, the thermostat breaks the circuit and the heater goes off. When the temperature cools enough, the thermostat closes the circuit again and the heat can come on.
Most dryers have a choice of temperature settings, therefore a separate thermostat is used for each setting. The selector switch or timer control then routes the circuit through the appropriate thermostat.
If a thermostat fails, it may prevent the heat from coming on, This happens because the thermostat does not close the circuit when the temperature falls below the operating temperature of the switch. It is a simple matter to test a thermostat; it should show continuity when the switch is cool and no continuity when it is warmer than its rated temperature.
A thermostat can also fail by being always on, no matter what the temperature. This switch would show continuity whether it was hot or cold. In this case, the heater would not shut off and the the dryer could dangerously overheat. As a safety precaution a second thermostat is used, a thermal fuse. The power will be cut to the heating circuit if the maximum safe temperature is exceeded. In most cases, this is a one time fuse. The heater circuit will not function until the fuse has been replaced. Of course, it will be necessary to determine and repair the underlying cause of overheating or the fuse will just cut out again.
The thermostats are usually grouped together. The are typically oval in shape and about an inch and a half in size. They may be on the blower housing, under the lint trap or inside the vent line. There should be two wires connected to each thermostat.
Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or change.
To test the thermostats or fuse, set the multitestester to the ohms setting X1. Touch one probe to each terminal. You should get a reading of either zero or infinity. At room temperature, the thermostats should have a reading of zero. When the thermostats are heated to their limit temperature, they should switch off and you should get a reading of infinity. The fuse should be tested at room temperature for continuity.
serve?bfmid=37924989&siteid=38910744&bfpid=1292788&bfmtype=standardClick Here to Order a Multitester from Ace Hardware
Hope this may help you;
DON'T FORGET TO RATE;
Posted on Sep 09, 2008
SolutionGuy
  • 331 Answers
SOURCE: When I shut the door and push start all it does is
Hi Judy,
When you press the start button, the computer runs through a self-diagnostic prior to actually starting the wash cycle. The initial diagnostic has shown that the door latch assembly has failed and should be replaced.
The part number is 8182634 and can be purchased at your local appliance parts retailer or online where you can shop around for the best price.
The repair is very easy. With the door open look at the 6:00 o'clock position of the door boot. Lift up the rubber a bit and you'll see a spring in there... the spring on either end is connected to a steel band. With a pair of needle nose pliers, grasp one end of the steel band where it's connected to the spring and pull down and toward you. Now completely remove the band and set aside.
With a "Torx" bit, remove the 3 screws from the door latch located at the 3:00 o'clock position. Now, starting again at the 3:00 position, ease the boot off of the lip of the washer front. Pull just enough to gain access to the latch. Now reach inside and pull the latch out through the opening.
Remove the 3 wire looms from the old latch and install them on the new one. Now tuck the new latch back into the machine and hold it in position while re-installing the screws you remove earlier.
Replace the boot carefully. Make sure that it fits back over the lip EVENLY. Now re-install the steel band making sure to position the spring back at the 6:00 o'clock position.
There ya go! It's fixed! Thanks for using FixYa.
SG
Posted on Mar 26, 2009
frederiquema
  • 76 Answers
SOURCE: Our Cabio top load has started to beep multiple times
U probably have a problem with the wirings.
Posted on Oct 26, 2009
  • 129 Answers
SOURCE: Duet front load dryer want start. When I press the
REPLACE BOARD
Posted on Jan 31, 2010
My frigidaire dryer GLEQ2152ES0 runs but no heat ?
Good Morning Friend,
I understand that you are receiving an "AD" error code on your Frigidaire dryer, model# GLEQ2152ES0. I also see that your dryer is not heating. The "AD" code states that your appliance is in an auto dry cycle. I suggest resetting your dryer, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
-Best Regards-
WP
Jun 09, 2014 | Dryers
I have a Fridgidaire Model LEQ144ZES0. Dryer will run for about a minute, shut off, then the display lights on far right Drying,Cool down,Prees Saver, Clean lint filter flsah 6 times and then thr Start...
I understand that you are having trouble with your Frigidaire dryer, model# LEQ1442ES0, shutting itself off after about a minute. I see that the lights to the far right flash 6 times and then the start and cancel button flash 2 times. This also, only seems to occur when the weather is warm and humid. I suggest putting a dehumidifier near your dryer during the warmer months to see if this helps to draw the humidity away from the dryer. The humidity can cause your appliance to not run as it should. The other suggestion I have, would be to reset your dryer. You will do this by either unplugging it or shutting the power off at your home's circuit breaker for 3-5 minutes. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 27, 2014 | Frigidaire FASE7073LW Affinity 7.0 cu ft...
MY DRYER DONT START,she make a sound but not start
Hello Friend, thank you for allowing me to assist you!
I understand you are having trouble with your Frigidaire dryer not starting. Let's try resetting your dryer by either unplugging it or flipping the household circuit breaker to the off position. It is best to wait roughly ten minutes and then turn on your dryer. Confirm that the door is securely closed and select a cycle. If resetting the power does not correct the issue, then at this point, you may want to connect with a local servicer who will be best equipped to pinpoint the problem. You dryer may either be experiencing a communication error with the main control or the timer itself may not be operating correctly. If you don't know a qualified technician, you can use the service locator option on the manufacturer site to find one near you.
May 24, 2014 | Frigidaire FGR641FS Gas Dryer, White, 5.7...
Dryer is tumbling but no heat - when I reset it shuts off after about 10 min and the Drying, Cool Down, and Extended Tumble lights are all flashing.
Janet McDonald,
I understand that you are having trouble with your dryer not heating and not running a full cycle and shutting off with the Drying, Cool Down, and Extended Tumble lights flashing. What I suggest is to give your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back and try to start a cycle. If it does not complete the cycle and shuts off with the lights flashing, I suggest to either contact the manufacturer or a local appliance technician. This way you will be able to locate the cause of this issue and have it resolved.
-Best Regards-
Jan 14, 2014 | Frigidaire AEQ6700FE Affinity Electric...
Frigidaire Gallery model GLEQ2170KSO dryer turns off within a minute.
Hello allisonarena - Try reprogramming the dryer by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and then turn on the unit. If issue persists, then the dryer may possibly be experiencing more serious issues such as; wiring failure, faulty control board, thermal limiter, or defective door switch. I would recommend connecting with an experienced appliance repair tech to assist further and to reduce the risk of unnecessary parts.
Jun 12, 2013 | Frigidaire Dryers
Frigidaire model #LEQ1452KSO
I have a electric dryer LEQ1452KSO won't heat up...how can I locate the fuses?
Apr 10, 2013 | Dryers
Problems with frigidaire affinity dryer model gle02152es1.
Hello ljdixon226 - From what you have described the unit could possibly have a communication problem with the control panel. However, if the unit is not producing any heat please have a professional diagnose the heating element and the blower assembly as well. Either, or, could be faulty at this time. This is not a typical DIY job so please consult a professional.
Oct 08, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Have a Frigidaire Gallery Series front loading dryer and it keeps giving me an error(?) code, E68. When I start the dryer, it runs for a couple of minutes and then It starts beeping and flashing this code...
Sorry to read about your problem. this should be your E68 problem
You have a defective button on the control board.
The best thing to do is go into the diagnostic mode.
Turn the dial to Normal. Press and hold the Select and Pause/Cancel keys for 6 seconds, or until the Drying/Cool Down/Press Saver/Clean Lint Filter lights come on.
Then press the Start and Pause/Cancel Buttons 4 seconds. This puts you into the diagnostic mode to check the keys. Now, turn the dial 4 O'clock position, or 75. This will allow you to check all your buttons. As you press each key, it will light all the lights above it. When you press a key and it does nothing or the lights above any certain key stays on without pushing it, this button is stuck. If you can't clear it, you probably have to replace the control board.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Dec 21, 2010 | Frigidaire Dryers
About 12 to 20 minutes into the drying cycle, the dryer stops and all of the led lights start flashing (drying, cool down, press saver, clean lint filter". Also, the dryer doesn't seem to get warm,...
sounds like a restriction in the venting process, i would first disconnect the vent tube and run the dryer, if that clears the problem then I would clean out the vent tube. If not then I would take apart dryer and clean out all of the lint. Hope this helps Tim
Nov 26, 2010 | Dryers
No heat, but dryer runs
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 27, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
118 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
