Question about Xerox DocuColor 12 Printer
Please,how can I solve error code 7-502 and 7-503 for xerox dc12 printer
Xerox dc12 printer error code 7-502/503
  • 2072 Answers
SOURCE: xerox printer error code (04,025.46)
This is a print head position issue.
TRY FIRST (Solutions without parts):
1. Check that the wipe mechanism has homed. 2. Check the printhead position and verify that it has initialized properly / manually home the printhead and power cycle the printers power and check for the error to return. If not then the error was most likely due to non-process function (something out of sequence).
Part likely to be the cause:
GEARBOX AND MOTOR,PROCESS DRIVE - PL 4.0, Item 14.
Posted on Jan 21, 2008
  • 2072 Answers
SOURCE: Xerox DC12 Error: 7-286
Accurate on the code.
If the lift motor is not running in diagnostics, that is telling you one of 4 things.
In order of likelyhood.
1.The lift motor itself is bad.
2.The connector to the motor needs unplugged and plugged back in.
3, The source to the motor is out, therefore the power supply is bad.
4 The MCU, main processor board is bad.
I suspect the lift motor has failed.
Posted on Mar 03, 2008
SOURCE: Eror code 3-380 System Fault problem
Whenever switchon my Dc12 The mahinc ready within 5 minutes and final stage it shows the eror like "System Fault" error code 3 -380 Switch of your printer and on. How can I solve it.
Posted on Oct 18, 2008
SOURCE: Xerox DC12 Error code 9-355
mi da errore 3- 355 cosa devo fare?
Posted on Jun 10, 2009
darshanthapa
  • 3 Answers
SOURCE: xerox DC12 error code 3-380
your sensor in IBT unit is not lined up accurate with the white sticker in the film.....solution is - deassemble the ibt unit and reassemble it...worked for me....
Posted on Dec 02, 2012
Prize
Have a Xerox DC50 with error 9-378 drum cartridge count expired message.
How do i reset that. Please somebody
Mar 21, 2010 | Xerox DocuColor 12 Printer
Xerox DC12 system failure: code 10-361
I have found the Heating Tube 520 is dead, so the Roll doesn't hot enough. This problem was solved simply - by replacing the Tube...
Feb 11, 2009 | Xerox DocuColor 12 Color Copier
Oct 15, 2008 | Xerox DocuColor 12 Color Copier
Error code 9-343
all 9-xxx codes are xerographic problems,such as toner,drum,developer or auto density.install or replace one or the other.
Jun 30, 2008 | Xerox DocuColor 12 Color Copier
Xerox DC12 System Fault 6-355
06 codes refer to exposure lamp problems..(or scan) check lamp coming on, scan carriage position etc, don't have the code list, so carefully move the scan carriage up and down, make sure it moves OK
Jun 05, 2008 | Xerox DocuColor 12 Color Copier
SERVICE BOOK
If you go to www.xerox.com and to the support and download area.
Type in DC12 in the search and then to downloads and drivers.
Select documentation and there is a variety of user support documentation to download.
Dec 13, 2007 | Xerox DocuColor 12 Printer
Xerox DocuColor 12 Printer Logo
71 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
