Question about Kenmore Dryers
I have to change the Heater element on Kenmore 1108564290 but I can't get it off.
Heater element is in a solid unit, not the newer style where the bottom half is removable.
  • Kenmore Master
  • 932 Answers
Brett, this tells me that you have an older unit and there is a 5/16th screw into a clip at the top of the heater box. There may or may not be a hole in the back panel above the heater box where you could put a nut driver through to loosen the screw, if there is not a hole you will need a stubby handle and nut driver to get to it or use a 1/4" drive ratchet with a 5/16th socket and reach in above the heater box to find the screw and clip. Once you have the screw and clip out, pull out on the upper half of the heater box until you feel it pull out of it's hole and then lift up on the whole box about an inch and pull out at the bottom to disengage the bottom clips and then pull the box down and out of the machine. You should also find a 5/16th screw or two that hold your heater frame into that box. Hope this helps!
Posted on Apr 02, 2014
2 Suggested Answers
Master_Tech
  • 770 Answers
SOURCE: HE 4 Removing Heating Element
post your email i will send you the manual on it.. also post the complete model number from the unit
Posted on Jan 26, 2008
Mzd2766geb maytag ref freezer door insulation frozen solid with ice
Even if the unit if issue free, this older design is still suseptable to moisture intrusion behind the inner liner. If your ice is below or around where the fointain area is, than you may be leaking water from the fountain behind the outer door shell. Since your outer door and inner liner are no longer avail, the best suggestion is to turn the entire fridge off, and let everything completely dry before re assembly. Once insulation gets imbedded with moisture and freezes, the insulation factor diminishes. Although your outer door insulation should be the newer style semi solid foamed in style, so moisture intrusion will not be any deeper than an inch or so. If the fountain heater has failed around the dispenser, you attract moisture to that area too. Pleazer Appliance...
Jan 06, 2015 | Maytag MZD2766GES Side by Side...
I have a kenmore oven. Just got an F2 error and the oven element will not turn off. Even when powered down, it heats back up when oven is in off position.
Range "Older Style"
F2 Oven too hot Replace relay board (if present) or oven temperature sensor
Range "Newer Style"
F2 Oven temp sensed; over 600F sensed by control in time of day mode, bake mode, or over 900F sensed in clean mode. Ohm test the oven temperature sensor, if OK, change power relay board.
Oct 17, 2012 | Kenmore 40494 / 40495 / 40499 Electric...
Does not heat
Hello there and thank you for choosing fixya
There are a few reasons why this is happening i have listed the most common items to check listed below
1st is the heating element this is the most common thing that fails
The heating elements are a common problem with dryers not heating and are an easy do-it-yourself repair. On the Newton style dryers, the heating element is located under the tub on the right in a round heater-can. To access it, first remove the front panel by removing the two screws on each side at the bottom of the front panel or if it's a newer model, prize the clips under the front panel. Then pull out the bottom of the front panel until the top clips release.This should release the top so that you can lift it up. Once up, you should see the heater at the back. Checking the heating element is the same for both styles. First disconnect power from dryer then unplug the wires going to the heating element. Next using your ohmmeter , check to see if you have continuity between the terminals on the heating element.
If you don't,have continuity the heating element is bad and needs replacing, if there is continuity the heating element is ok.
Mar 06, 2011 | Maytag MDE308DAYW Electric Dryer
Timer starts beeping and flashes F1
Hello there:
if this is the newer style oven then follow the gujide i have provided below and if it is a older style follow the guide i have provided below the first one ok
newer style
F1 Power to element relay energized during time of day display Wiring harness shorted or change power relay board (PRB)
Note: for double ovens, change second oven board
older style
F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad)
Jul 23, 2010 | Jenn-Air JGW8130A Electric Single Oven
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  8. Gas dryer smell
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Kenmore 84152
On a kenmore conventional dryer they had for a million years the heating element is on the rear of the machine on the right. Some newer models "princess type" have a lower front panel and a heater that just yanks out for easier servicing.
Jan 20, 2009 | Kenmore 84152 Electric Dryer
Kenmore..Few years old came with the house
Check the spade/lug wiring connectors under the unit at the motors They can work loose. These newer units only use the heating element for a short time. If you get it running again do not use tablet soap. Start your sink's hot water until its too hot to touch then start the washer, let the tank fill then open the door and pour in an additional gallon of hot sink water mixed up with liquid cascade soap. To get "Energy Star" compliance, They have made trade offs to use less water and energy. When mine is running it still doesnt clean very well at all. consider installing a small R.V. water heater under the sink or nearby.
Also make sure your drain hose is clear and has no kinks in it.
Jan 01, 2008 | Kenmore 24 in. 15142 Built-in Dishwasher
Dryers Logo
47 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
