The display has been scrambled on different occassions reset ckt breaker usually solved the problem, this time it did not work.. the unit has power because the light works. The faint display when you set the timer counts down but the unit does not work... the unit was manufacured in January of 04.. Thanks
We regularly repair such control units for
customers nationwide by mail for $39.95 postpaid in about a
week or so with a one-year guarantee.
Assuming your model number is DMT2420 (since that's the category under which your query was posted) then you likely also need a new secondary interlock (bottom door switch).
Door switch
or mount trouble is usually caused by slamming the door or by opening
the
door while it's cooking without hitting the Stop pad first.
If you have a different model, please reply back or contact me directly with the correct model.
If you want to send your control panel assembly in for repair, you can note on the repair form that you need a new door switch and we'll throw one in at no charge.
Feel free to contact me directly (and please remind me of your
full model number from the tag on the unit) for more information & help.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
I believe we spoke on the phone today. You are M.C., right?
If so, then I'm pretty sure you do also have a bad lower door switch or
its mount may be damaged or misaligned. (It's usually the switch).
I have placed a note on our incoming unit list to throw in a door switch at no charge when your unit arrives.
We're
rating of our answer here at FixYa.
We're
Thanks for you help i do not think i have a door switch problem because the light goes on and off with openning and closing the door.. So basically its the control module display that is the problem?? is there a part # so i can see what the item is new instaed of a refurbished or repaired unit? Thanks agaim for all your help
