Cars & Trucks Logo
d
david stidham Posted on Mar 28, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Brake lights work during the day but not at night 2000 chevy venture
Dealer said i need a new wirering harness
downhille
Level 3:
  • Master 400 Answers
  • Posted on Mar 28, 2014
downhille
Master
Level 3:
Answers
400
Questions
Helped
99505
Points
1167
Perhaps they are right, but I cannot imagine needing a new harness unless you had an accident, or a fire that damaged it. I suggest you check the lamp connections and the ground connections at each tail light. I'll bet it is the ground connection, where it hooks to the body. I hope this helps you find your problem.
5 Related Answers
Anonymous
  • 69 Answers
  • Posted on Oct 24, 2008
SOURCE: Brake light problem
back feed causing the brake light to ground off of the head lights caused by bad ground or possible short
inf12
Harry Daehling
  • 13 Answers
  • Posted on Feb 08, 2009
SOURCE: need wiring diagram for taillights on 2000 chevy venture van
d7d3cd6.jpg3a50d5e.jpg80738de.jpg8d3e722.jpg GOOD LUCK
Anonymous
  • 3533 Answers
  • Posted on May 12, 2009
SOURCE: how do you reset power sliding door on 2000 chevy venture
there should be information in your owner manual telling you how to do it if you have miss place your owner manual try this website to see if you can down load one for your car its www.edmunds.com and i hope i was able to help you Michigan Man
Anonymous
  • 84 Answers
SOURCE: need to add 13-4a freon to my 2000 venture chevy van. Where is the pressure hose located?
passengers side under the hood.....by the firewall.....
Anonymous
  • 395 Answers
  • Posted on Dec 13, 2010
SOURCE: Brake lights work but tail lights won't work with
The Tail lights and Instrument lights are usually on the same circuit so both will go out if the fuse for the circuit blows. Check for a blown fuse for this circuit and replace if out. If fuse continues to fail, check the tail light or side globes for a faulty globe and replace if necessary. Also check for any chafed wires that could be shorting to the body causing the fuse to blow.
2000 chevy truck 3500 check wiring on fuel pump harness
images for 2000 chevy truck 3500 check wiring on
How to Install New GM Wire Harness on Fuel Pump Module ...
? 3:10
https://www.youtube.com/watch?v=FffdzqknP3k
Apr 20, 2012 - Uploaded by Airtex Pumps
This video is about how to install a new Airtex fuel pump module into some GM ... fuel pump and gas tank to a 98 internal fuel pump and gas tank on my truck 88 gmc. the wires are a little different. .... Check the power & ground at the pump. ... CHEVY SILVERADO FUEL PUMP CHANGE OUT.2500HD 2001.
How to test an electric fuel pump - YouTube
? 13:54
https://www.youtube.com/watch?v=Q3ZiTsKCdO8
Feb 3, 2012 - Uploaded by ScannerDanner
2001 GMC 3500 8.1L engine with no fuel pressure. In this video I am showing how to test the fuel pump electrical circuit using atest light and scan tool. ... seconds on the ground wire. when i unplug the harness from the the fuel pump .... need help newfuel pump chevy venture 2004 runs for a few days then ...
How to Install Fuel Pump E3947M in 1997-2000 Chevrolet ...
? 5:53
https://www.youtube.com/watch?v=9LLLRVnItbI
Applications: 2000-97 CHEVROLET/GMC C, K 1, 2, 3 TRUCK 262... Please check out our 'How to Install New GM Wire Harness onFuel Pump ...
01 chevy venture brake lights not working
i had that problem on my caddy what i did was checked the fuses and check the wireing harness for the lights mice could of chewed them up check that and see if there either blew or see if there chewed sorry if not much help
99 chevy venture i have no tail lights, no turn signle lights, or brake lights, do i have bad turn switch?
It sounds like a bad connection on the rear wire harness. Check all your connections working forwards from the rear light system.
The heater doesn't work very well on my 2000 Chevy Venture van. I'm wondering if I should try replacing the thermostat. Or, it is all computer controlled now.
If heat gauge reads normal, stays in the middle, then you do not need to mes up with the thermostat. I own a 2000 Chevy Venture and changing the thermostat was not fan.
It may be the Temperature Control Module, which you can buy for $45 and replace without problem, or may be an partially obstructed heating core. The GM Dex-Cool antifreeze, the read one, has additives, but if you do not flush the radiator every 2 or 3 years, can result in partially clogged heater core. I have done on my car twice till now, and replaced with green Prestone, on my own risk. Hope this will help. If need more information let me know. A have the Haynes manual for Chevy Venture 2000, and I am a car dealer.
1helpful
How do you change the electronic flasher on a 2000 chevy venture
Turn on 4 way flashers if they work & listen for flasher clicking. Or if they dont work but one side of turn signal does turn it on. Once you locate where it is hidden under dash it justs unplugs then plug new one into the harness.
Turn signal doesn't work when headlights on
It sound like you have a grounding problem, does the headlight on the left seem dimmer than the right? Check the ground wires and the light sockets for corrosion.
1helpful
2000 Pontiac Montana Brake Lights.
the boards in the tail lights have issues the plugs melt and they screw up the grounds. if your dash light signal indicators or on steady at night then chances are you will need new harnesses and light board assemblies
Chevy venture
Solution to your problem ... 1- I purchased from 1aauto.com a pair of Circuit Boards for my Chevy Venture 2003 for 85.00 $ ..free shipping 2 - I Installed them both , all lights now were not working at all. So I checked them and they were all burned ...So I purchased new ones ....Everything was working fine now but now my signal lights were not working left and right .....Checked the fuse box next to the passenger side door .... It was burned . Changed the fuse / Signals are working fine now ....All is good I just did this yesterday evening August 12, 2008 Conclusion ..Change everything going forward so you do not need to run around like I did from one store to another!
  1. Circuit Board : New
  2. Bulbs : New
  3. Fuses : New
Thank you
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
