Question about Crayola Crafts & Hobbies
The light will not come on, batteries are new. The light source seems to be a flat round disc.
2009 light box PIN 80-8256-0-990
2 Suggested Answers
  • 24 Answers
SOURCE: I do not know where
You put it i your computer. The computer reads the disc to set up your GPS system. If I'm wrong Read the manual.
Posted on May 04, 2011
Chargers green light goes off as soon as inserted in boards 3 pin connector and not charging. seems dead.
Hi testing battery voltage will not give an accurate reading on battery condition U need a BATTERY LOAD TESTER.it will check the condition & give U a true reading on there condition ,..if batteries r good the next thing to check is the control box the charger circuit runs into the control then to the batteries if control box is faulty this could b the problem .,with youre charger not charging . LOAD TESTER AVAILABLE ON E/BAY APROX COST $35 , Cheers
Sep 19, 2016 | Blue Health & Beauty
Where is the battery compartment in my ce electronical digital safe?
do you have a round lock pad. This model has 2 9 volt batteries under the key pad
http://bestbatterytips.com/change-replacement-batter/safes-with-electronic-locks-replacing-the-battery/
Lots of info here
  • How to open digital safe when battery is flat and key not ... www.youtube.com/watch?v=aqC9V7SDKdQ
    • BY KHTHHONL
    • 1 MIN
    • 417K VIEWS
    2012-11-09 · How to open a digital safe when the battery is flat and the ... How to open digital safe when battery is flat and ... How Secure Are Electronic Safe ...
  • Locked out of my Digital Safe [Archive] - PPRuNe Forums www.pprune.org/archive/index.php/t-357319.html PPRuNe Forums > Misc. Forums > Computer/Internet Issues & Troubleshooting > Locked out of my Digital Safe. ... CE (Chinese made) electronic security safe ... battery ...
  • LA GARD LG Basic digital electronic safe lock changing ... www.youtube.com/watch?v=M07EpfSmoAU
    • BY DEANSAFE
    • 3 MIN
    • 99K VIEWS
    2009-10-13 · For instructions on this and other electronic digital safe ... How to change the combination and battery on ... Basic digital electronic safe lock changing ...
  • User Manual for Safe EA25 Installation - Tayabally www.tayabally.com/digitalsafe/mannuals/Safe EA25 Installation... You should change the code as soon as possible after opening the ... BATTERY REPLACEMENT. This safe uses ... MAINTENANCE FOR KEY AND ELECTRONIC SAFE.
  • Elektronischer Digitaler Safe Electronic Digital Safe www.produktinfo.conrad.com/...799999/...DigitalerSafe_de_en_fr_nl.pdf · PDF file Electronic Digital Safe Version 12/08 ... (CE). Any usage other than ... Replace your batteries when both the red and green light illuminate. 1.
  • Instructions for an Electronic Digital Safe ' eHow www.ehow.com > Home > Home Safety > Home Safes Instructions for an Electronic Digital Safe By Shawn McClain eHow Contributor Pin Share ... Replace the used batteries with new ones. For most safes, ...
  • Apr 24, 2016 | Locks & Locksmithing
    My battery died on my 2009 equinox & after I charged it the stabilitrak off light came on and now the vehicle is VERY hard to steer,,any ideas????
    Heavy steering is an indication that the drive belt for the power steering is loose or missing. IT may be that that is the reason for a flat battery as the belt will also drive the alternator and the battery has drained down trying to supply the power to the electrical parts.. With a flat battery there may be a problem with the CPU program so use a code reader to reset it and then see if the light comes on.
    Mar 18, 2014 | 2009 Chevrolet Equinox AWD
    How to wire trailer plug
    hope this helps
    6 pin socket
    6 pin plug
    7 pin socket
    7 pin plug
    5 pin socket
    5 pin plug
    7 pin socket
    7 pin plug
    7 pin socket
    7 pin plug
    7 pin socket
    7 pin plug
    12 pin socket
    12 pin plug
    small 6 pin round plug & socket
    1 tail, clearance - brown
    2 left hand turn - yellow
    3 right hand turn - green
    4 stop - red
    5 electric brakes - blue
    6 earth - white
    small 7 pin round plug & socket
    1 left hand turn - yellow
    2 reverse - black
    3 earth - white
    4 right hand turn - green
    6 stop - red
    7 tail, clearance, side markers - brown
    roundskt.jpg round socket
    large 5 pin round plug & socket
    3 earth - white
    5 right hand turn - green
    6 stop - red
    large 7 pin round plug & socket
    2 reverse - black
    3 earth - white
    6 stop - red
    7 pin round heavy duty plug & socket
    1 earth - white
    2 left hand rear , clearance and marker - black
    3 left hand turn - yellow
    4 stop - red
    6 right hand rear , clearance and marker - brown
    7 reverse/auxilary - blue
    7 pin flat plug & socket
    2 reverse - black
    3 earth - white
    6 stop - red
    7_flatsocket.jpg flat socket
    12 pin flat plug & socket
    2 reverse - black
    3 earth - white
    6 stop - red
    8 battery supply - orange
    9 auxiliaries - pink
    10 earth - white
    11 rear fog lamp - grey
    12 auxiliaries - violet
    Feb 02, 2013 | 2004 Toyota RAV4
    Hooking up trailer lights i no longer have marker lights, running lights or dash lights. headlights 4 ways brake and signals all work any sudestions?
    Depending on what connector you are using, here is a link to the wiring diagrams:
    http://www.etrailer.com/faq-wiring.aspx
    You may have to use an OHM meter to test the leads at the tow vehicle side to verify correct placement. Good ground is essential too.
    Jan 25, 2011 | Dodge Dakota Cars & Trucks
    I am connecting a trailer towing harness to my Nissan 2004 Titan (2wd), to tow my boat and need to know what the color codes to the parking, stop, and reverse wires are.
    if you go to the parts store they make them ready to plug in you will have to just unplug the tail lights and plug the wire harness inplace of it then itll plug back into the original spot.
    Apr 22, 2010 | 2004 Nissan Titan
    No light meter on Vivitar V3800N
    It may be that the batteries that came with the camera are dead. Double check the way you have them installed, both cells should have the positive side up as they sit in the cap. It is best to handle button cell batteries on the round edges rather than the flat sides. The battery cap for your camera should have open slots on the sides so you can place the batteries in using those openings
    Feb 01, 2010 | Vivitar V4000 50MM 35mm SLR Camera
    I need wiring to install a new radio in my 2001 f-150 acc-battery-ground what are the colors ?
    Abbreviations used :
    CJB ( aka Central Junction Box, cab fuse panel )
    BJB ( aka Battery Junction Box, Engine Compartment fuse panel )
    In the factory connector :
    Hot at all times from CJB Fuse #1 is pin #9, light green w/ violet stripe wire
    Hot in start from CJB Fuse #20 is pin 3, Red w/ black stripe wire
    Hot in Accessory or run from CJB Fuse #8 is pin 10, Black w/ Pink stripe wire.
    Grounds in the connector :
    pin 2, black
    pin 11 black w/ light green stripe
    pin 16 black w/ light green stripe.
    pin #1 light blue w/ red stripe is the instrument illumination, after the cluster dimmer switch.
    I would stay away from using the black w/ light green stripe, I seem to recall those are the shields for the speaker pairs.
    Bit late on the reply, just caught this one. If you don't have it don't, good luck
    Sep 30, 2009 | 2001 Ford F150 Styleside SuperCrew
    Tail brake lights
    u will need to remove the tail light assembly to change the bulb, Follow this procedure
    Remove the assembly
    1. Open your tailgate.
    2. Look for two (2) round flat black discs about the size of a dime (but thicker) on the inside of the body (between the red lens and the weather striping).
    3. Using a pair of pliers, pull out each of these two discs.
      • Note they are in tight and may require a fair bit of force to remove.
    4. Make sure the inner part of the disc also comes out. There are two parts to this system, a grommet and a plug:
      1. Push the plug backwards through the grommet.
        • The grommet fits into the actual hole in the body, and is spread by the plug, the pressure holding them in place.
      2. Carefully remove both grommet and plug.
        • The lens assembly will fall away from the vehicle when you pull out the second grommet so be careful.
    5. Note the wiring harness that connects to a plug inside. Beside that plug are two holders for the actual bulbs.
    6. Remove the holder by pressing the sides inwards and pulling. The light socket should come out.
    7. Replace with the correct bulb (The 2004 Dodge Caravan uses an 3057 bulb that has a flat base with 2 wires running over it. Check your manual for your bulb.)
      1. Pull on the old bulb to remove.
      2. Press the new build firmly in.
    8. Check the light:
      • Press the brake pedal.
      • Turn on the signal light.
    9. Make sure it lights before replacing the lens assemb
    Apr 12, 2009 | 2009 Dodge Grand Caravan
    Crafts & Hobbies Logo
    85 people viewed this question
    Top Crayola Crafts & Hobbies Experts
    Paul Carew
    ka4iup
    ka4iup
    cwradio73
    Are you a Crayola Craft and Hobby Expert? Answer questions, earn points and help others
