Question about 2002 02 Toyota Tundra Instrument Cluster Bulb-2002 Toyota Instrument
Want idle when I let off gas it want idle
  • 458 Answers
You most likely have a large vaccuum leak.You should be able to hear it under the hood with the engine running.I'm not sure if Toyota had gone to "drive by wire" in 2002,or if your truck still has an Idle Air Control motor.If it has a mechanical throttle cable(not "drive by wire",then it will have an Idle Air Control motor,which could be stuck or defective.
Posted on Oct 29, 2015
Wont start
If you can keep giving it gas and it runs above idle with no problem, then you have a blocked or bad idle control valve on the throttle body assembly. With your foot off the gas pedal, the large throttle plate inside the throttle assembly is closed, but some air is let in through the idle control valve or motor through a separate passage. This can get clogged with deposits over time and poor idle results. The valve is controlled by the engine computer. It is how the computer controls idle speed- more air if the idle control valve is opened wider, higher idle speed.
"...like its not getting any gas..." Oh yeah, it's getting gas, the injectors are still pumping gas into the cylinders, but it may not be getting any air. All the accelerator pedal does is control the air supply into the engine through the throttle body. So modern cars have an air pedal, not a gas pedal. Then the computer takes over and matches the correct amount of gas through the injectors to the known supply of air in the intake manifold. Neat system, eh? Sorry if I sound so pedantic, dale. check your idle control valve.
Apr 20, 2014 | 1997 Mitsubishi Galant
Does high idle consumes more gas??
obviously does, more RPM needs more gas
Mar 14, 2013 | Cars & Trucks
I have 1999Chevy suburban with 6.5 turbo diesel motor.it idles up and down and when driving the gas pedal is real touchy Wat is the problem and were do i locate the problem
Check the help links related to this problem.Click the link below to go through its troubleshooting procedure :-----Idles rough and quits when gas pedal is pressed less? http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html---------
Car won't start without hitting the gas pedal? http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-without-hitting-gas.html
-------Complete loss of brake pedal then all gets normal? http://repairhelpcenter.blogspot.com/2012/01/complete-loss-of-brake-pedal-then-all.html
------Car dies when gas pedal is pressed? http://schematicsdiagram.blogspot.com/2011/12/car-dies-when-gas-pedal-is-pressed.html
--------Pushing on the gas pedal, but the car slows down? Gas pedal to the floor and the car slows down?
http://technoanswers.blogspot.in/2012/02/pushing-on-gas-pedal-but-car-slows-down.html
After replacing brake rotors and pads, brake pedal remains on floor? http://technoanswers.blogspot.in/2012/02/after-replacing-brake-rotors-and-pads.html
accelerator pedal sensor? http://technoanswers.blogspot.in/2012/02/2009-chevy-impala-accelerator-pedal.html
For rough idle issues and problem troubleshooting,go through the help links provided below :----- van idles rough?
http://howtobyme.blogspot.in/2012/01/2004-ford-freestar-van-idles-rough.html
will not idle when cold?
http://technoanswers.blogspot.in/2012/02/ford-explorer-40-will-not-idle-when.html
runs lean and idles rough?
http://technoanswers.blogspot.in/2012/02/ford-runs-lean-and-idles-rough.html
Engine stumbles coming off idle when warm?
http://repairhelpcenter.blogspot.com/2012/01/engine-stumbles-coming-off-idle-when.html
Erratic idle on car?
http://schematicsdiagram.blogspot.com/2011/12/erratic-idle-on-car.html
Low idle when cold out side?
http://repairhelpcenter.blogspot.com/2011/12/low-idle-when-cold-out-side.html
Idle Air Control (IAC) Valve Replacing?
http://schematicsdiagram.blogspot.com/2011/12/gmc-idle-air-control-iac-valve.html
Engine quits at idle?
http://repairhelpcenter.blogspot.com/2011/10/engine-quits-at-idle.html
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
While stop engine idles like cylinder missing?
http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
This will help.
Thanks.
Mar 01, 2012 | 1999 GMC Suburban
I recently purchased a 1978 Honda Goldwing. It had some old gas in the tank so I removed the old gas and replaced the fuel filter. The bike was idling fair before now it's extremely high. Does this...
If the bike was idling OK when you ran it on the old gas, maybe the carbs were adjusted while the old gas was in the tank. The new gas could have cleaned the fuel system some and that's why your idle jumped. The fuel filter will definitely not cause your idle to go higher so no need to worry there.
Jun 28, 2011 | 1978 Honda GL 1000 (K3)
Will not idle but runs when you hold the gas pedal down when you let off the gas its spits and sputters then stals
you need to adjust the idle to run higher. its not to hard to do, you just have to locate the idle control. you can find it by looking under the hood while someone presses the gas a couple times, you should see it move. All you have to do is tighten the cable that is connected to it,.. a little at a time until you get the desired idle. careful not to over adjust it, or you will idle to high and waste gas, and over work the enjine on very hot day's or very cold day's.
Mar 09, 2010 | 1991 GMC Sonoma
Ford probe idle fluctuating
Sounds like you have bad gas. It can get strong mix of gas to give you the right idle, but when it has water mix, it will cause the car to fire like it should. This will then give you a low, rough, or just cutting off idle. Try mixing water remover in with the gas. You may have to drain the gas out or just drive it like it is until the tank is almost empty. Fill up with gas (from a different store) and you may want to change the plugs after the good gas is through the system. I'm not saying the plugs are bad, but there may be a lot of moisture beads from the water sitting causing rust.
Feb 21, 2010 | 1993 Ford Probe
Idle is high unless I tap the gas pedal
To me this sounds like the return spring on the carby has lost its strengh or your carburator needs a good clean as the throtle linkages could be dirty. I hope this helps.
Nov 02, 2009 | 1986 Chevrolet Corvette
Will not idle
two stoke I guees, eletronic choke if so then it is stuck, if not then if slide then slide stuck up a hair...carbs systems use Idle jet and main jet, the main jet is a taper jet with a tapper needle that adjust gas flow as the needle move up air flow across it draws more gas through the hole going to the float bowl but the idle jet is a fixed hole that has a air mixture screw nthat lets you trim the fuel air ratio for idle make sure the srew did not fall out, next a stuck float bowl can flood the idle with too much gas next the chock if half on can cause a high rich gas and cause huigh idle next a sticky throttle cable can cause high idle and just unhook throttle cable to check this the last thing is a points not electrong ignition system bike can cause high idle...air leake into the carb just like a vacum leak in a car can cause high idle...l.start with diss connecting trootle cable then check for needle jet seating then check for choke not stuck last is the float bowl level you get it study how a carb works and you nail this thats how I learned after 115 motorcycles I had seen alot of my own errors....rememeber high idle most likly is to much gas...now how is it getting to much gas is the question most likley
Jul 03, 2009 | 2003 Yamaha WR 250 F
Idle Problem After Refueling
Sounds like the valve in the gas cap has failed, try replacing the gas cap with the correct one listed for your vechicle
May 04, 2009 | 2001 Toyota Celica
2002 02 Toyota Tundra Instrument Cluster Bulb-2002 Toyota Instrument Logo
41 people viewed this question
Top GE Vehicle Parts & Accessories Experts
shadowpro
David Wiebe
Level 1 Expert
Are you a GE Vehicle Part and Accessory Expert? Answer questions, earn points and help others
