Question about HP Computers & Internet
Hp pavillion a850y
We had a Power surge alert in our area through the night from our power company, so we closed down all systems and turned back all our electronics this morning. Everything came back on except my PC which is a HP Pavilion a850y unit. I had turned the unit off before I switched off the Power Surger. But when I turned it back on this morning I then pushed the PC ON button and nothing happened, the Screen did go on! I looked at the back of the unit and a little green light was blinking. I was told it was the Power unit, so I replaced it and still no power! Could the problem be the ON button? Please help! Thanks Paul D.
    Scholar:
    New Friend:
  • 77 Answers
It is unlikely to be the switch itself. Check that the memory is seated correctly on the motherboard, as it won't boot without it. Otherwise it sounds like the motherboard itself is shot. Sorry for the
Posted on Mar 28, 2014
4 Suggested Answers
Jim1969pa3
  • 152 Answers
SOURCE: hp drivers for XP
Hello!
Well I found this
http://www.bioticaindia.com/nvidia-geforce-go-7150m.html
But I have no way of testing it.
And let me know if this works so I can help out the next guy!
Jim
Posted on Apr 15, 2009
gcsltd
  • 239 Answers
SOURCE: HP Pavillion won't bring monitor back from sleep mode
hi...if u can read " no input signal" from ur screen, this means that ur monitor is ok..
Look if u have power buttons on ur keyboard.. try to wake it from there.. some pc may have shortcut keys to bring back the pc... look @ ur pc docs on the internet for more info...
However if it's a hardware issue, it may be that ur RAM memory needs to be cleaned
Posted on Feb 05, 2010
  • 10406 Answers
SOURCE: My laptop Hp Pavilion is
It seems like the battery is not getting charged.
When it is running on AC power, does the battery show as "charging" or as "100%-charged" ?
It may be necessary to replace the battery -- search on 'www.ebay.com' for a compatible replacement.
Posted on Dec 16, 2010
Panasonic Home Theater System ....No power
Likely a power surge hit your house while away. This happens when power turns back on or lightning hits close to your house. If insured, call insurance company about it. You may be covered for replacement or have deductible applied. Small appliances like this are most susceptible to power surge. There is not enough protection designed in.. The best protection is surge module on main breaker panel or buy a protected power strip to protect high value electronics.
Apr 16, 2014 | Panasonic Audio Players & Recorders
My hp pavilion dv7 keeps running after the lid is closed
Change the settings in the Power section to shut-down when lid is closed. Power Settings, Advanced Settings, Change setting to shut-down when lid is closed.
Oct 29, 2012 | HP Pavillion Dv7-6165us 17.3" Amd...
Screen stays blank, unit power surges on/off. It was turned off with the button last night. Unit will not reboot
Have you tried resetting the battery? Sometimes they can be loose and need to be taken out then put back in. If not I would try either a different charger or buy a new battery.
Jul 28, 2011 | HP Pavillion DV1133WM Notebook
Power to house went out during area power outage. Everything came back on except the computer? Tries to restart by holding power switch in, unplugged and replugged power cord - no response on monitor. ...
When the power is returned after a power outage it can cause a power surge and damage electronic equipment such as a computer. This is a reason to install a surge protection power board and connect your computer equipment to a surge protection board.
The switch mode power supply may be faulty and replacing it may get your computer operating again.
If you cannot DIY then ask a friend or take it to a computer repair shop.
Jul 14, 2011 | HP Pavillion s7420n PC Desktop
My monitor doesn't go on anymore. Las night I had a pop-up appearing on the screen. I closed my computer and started over again. I'm sure I didn't turn off my monitor. Everything went well until this...
First, check to make sure the power cable is plugged properly in the back of the monitor and into the surge protector. You can try a different power outlet, but if you're still having the same problem and the light isn't turning on, it's likely you've either blown the fuse inside the monitor, or you had a power surge and blown something inside the monitor. This happens when you don't use a surge protector and just plug the monitor into the wall.
That said, if the above doesn't work then you have a hardware problem with your monitor and it needs to be serviced.
Jan 11, 2011 | Computers & Internet
I turned my HP Pavilion 9000 series off last night and this morning I woke up to find all the lights on, the screen black and the indicator for the wireless internet showing orange instead of blue (it had...
Unplug the unit, and remove the battery. This will shut the machine off completely. You do not need to let the battery die out. Then power the unit on again. If the issue is gone, consider turning off hibernation ( power options inside control panel)
Sep 01, 2009 | HP Pavilion dv9000z Notebook
Can i install a ggeforce fx 5200in an hp a850y w/
As long as your PC has the proper pci, apg or pci-e slot then it shouldnt be a problem. You also have to look at the cards specs and make sure your PC has the right amout of wattage to power the card. Also make sure you have the right power connector inside the PC. I would think that card would have a 4pinn female molex connector. You should have an extra one inside your PC case.
Aug 01, 2009 | XFX GeForce FX 5200 Graphic Card
I have a hp pavillion a820n..i was watching youtube quickplaylist 1 day.Then the comp froze. I turned it off,and ever since havent been able to turn it back on.. I tried unplugging power cord and surge...
Check the cable going to your monitor and from the monitor going to the back of your computer, take it out and put it back in. Check also the power cable of your monitor.
Jun 02, 2009 | Computers & Internet
Hp pavillion dv9500 not turning on
some of the "boot" drivers might be lost jst check over it
Apr 04, 2009 | Computers & Internet
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
