Question about Electrical Supplies
How can i get a wire harness and a wire diagram for my dayton 10,000 watt generator it has a honda 20 hp engine
Dog ate wire
I have a harbor freight predator 7000/8750 watt generator i need a wiring diaghram for that generator since my dog ate part of the wiring harness if you could help i would appreciate it
I would go to NAPA and get a butane soldering iron
some wire strippers, rosin flux core solder, shrink tube and a heat gun. Then ..
Don't just look for wiring diagrams for that generator; but,
do some google search on how generators are wired.
That will help you sort out the issue.
you don't wont to wire it wrong, run it and burn up a coil .
Ed
Feb 20, 2017 | Electrical Supplies
Produces no power
Check for a blown fuse or any loose wires
Feb 05, 2011 | Porter Cable 10,000 Watt 20 Hp Portable...
Low voltage, freqency appears erractic but engine speed is constant, auto idle surges
called hunting. Adjust the air fuel ratio crew until it stabilizes, The tur idle to specs.
Nov 19, 2009 | Porter Cable 10,000 Watt 20 Hp Portable...
There is absolutely no voltage output. What
My generator has a switch to turn on the output, you must turn it "ON" to get power.
Jun 10, 2009 | Northstar Generator 20 Hp, 13,000 Watt,...
Not generating power
The engine is not running the welding transformer. It may be a fuse, drive belt or gear wheel. Or the transformer is shorting out. Check these points in this order if the last one maybe you will have to replace the transformer. The transformer is 2 coils to stop them shorting out where normal electric wire is cover in plastic or rubber the coils are coated with enamel as are sum cooking pans. If this is damaged in any way it will short.
Apr 08, 2009 | Hobart Welders 500433 Champion? 10,000...
Cranks fast but wont start
Hi, You did a good job of diagnosing your problem. Gas in bowl and dry plugs, starts with fluid, But, to quote you, "won't go through carb" . If you feel confident, you should disassemble and clean the carb, as that is going to be the problem. As a tip, if the genset is going to sit make sure to turn off the fuel flow to the engine and run till the engine dies. They do not like to sit any length of time with fuel in the carb. Good Luck, this should Fixya!
Mar 02, 2009 | Northstar Generator 20 Hp, 13,000 Watt,...
Porter-Cable generator won't power anything; engine runs, low rpm
You have a simple problem and it has nothing to do with the octane, honda's love better gas, thats all I use in all my equipment and even my 4000 psi pressure washer runs better and cooler with higher more efficient octane, Your problem is in the carb, clean and service it, make sure the air breather is clean (soap and water only if it is a foam unit and do not spray it with any oil) then check for water in the gas by draining the tank into a large clear glass container 1/2 gal at a time. and after all this is done and needs to be done anyway, change the spark plug run the unit and make sure the throttle up solenoid is adjusted properly or even working if this unit is equipped with one. good luck
Dec 22, 2008 | Porter Cable 10,000 Watt 20 Hp Portable...
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
